When CMMN Excels: Knowledge-Driven Workflows
Время чтения: 8 мин. 50 просмотров
When you’re modeling a process where the next step isn’t known in advance—where decisions depend on a clinician’s judgment, a claims investigator’s findings, or a fraud analyst’s pattern recognition—BPMN becomes a poor fit. The rigid flow of BPMN assumes predictability. CMMN doesn’t. I’ve seen teams waste months trying to force a case investigation into BPMN’s decision gateways and gateways, only to end up with a 40-node spaghetti diagram that no one can maintain.
CMMN use cases shine where knowledge, context, and human judgment are central. These aren’t rare exceptions—they’re the norm in domains like medical diagnosis, insurance claims, and legal investigations. The right model isn’t the one with the cleanest flow, but the one that reflects how work actually happens.
Here, you’ll see real CMMN examples from fields where structure is a myth and adaptability is mandatory. You’ll learn the exact conditions under which CMMN outperforms BPMN, and how to use it without overcomplicating your models.
Why CMMN Excels in Unstructured, Knowledge-Intensive Scenarios
Let’s be clear: CMMN isn’t for every process. But when a process hinges on expert interpretation, evolving data, and unpredictable decision paths, CMMN becomes not just valid—it’s essential.
Consider this: in a hospital emergency room, the patient’s symptoms evolve in real time. The treatment path isn’t fixed. It changes based on lab results, imaging, and the doctor’s assessment. That’s not a flow—it’s a case. And that’s precisely what CMMN was built for.
The power of CMMN lies not in dictating the path, but in enabling the right people to make the next move at the right time. It’s guided by rules, not rigid sequences.
The Core of Knowledge-Driven Work
These are the defining traits of knowledge-driven work:
  • Unpredictable next steps – The outcome of a task influences what comes next.
  • Expert judgment required – Decisions are made by people with domain knowledge, not predefined logic.
  • Dynamic data dependency – New information (e.g., test results, documents) can trigger new tasks or change priorities.
  • Parallel or non-linear progression – Multiple tasks may run simultaneously or in any order.
  • Task initiation driven by events – A task appears only when a condition is met—like a new document arriving or a diagnosis confirmed.
When any of these apply, asking “When to use CMMN?” is the right question. If these don’t describe your process, BPMN may still be the better choice.
Real CMMN Examples: Where Adaptability Wins
Healthcare: Patient Diagnosis and Treatment Planning
A patient arrives with abdominal pain. The diagnosis isn’t a single path—it’s a case. The doctor doesn’t follow a fixed flow. Instead, they assess symptoms, decide on imaging, request lab work, and interpret results in real time.
Here’s how CMMN models this naturally:
  • Stage: Initial Assessment – Tasks: Patient Interview, Vital Signs Check.
  • Stage: Investigation – Tasks: CT Scan, Blood Test, MRI, EKG.
  • Stage: Treatment Decision – Tasks: Specialist Consultation, Treatment Plan Draft, Patient Consent.
Each stage is triggered conditionally. A new lab result might reopen the investigation stage. A negative CT scan could bypass MRI. CMMN doesn’t force a sequence—it allows dynamic control.
BPMN would require dozens of parallel paths and complex gateways. It becomes unreadable, unmaintainable. CMMN? Clean, clear, and accurate.
Insurance: Claims Investigation and Fraud Detection
A claim for a car accident arrives. The claims adjuster doesn’t start a workflow. They open a case. The next steps depend on the damage, driver statements, police reports, and even social media checks.
Here’s how CMMN models this:
  • Stage: Document Collection – Tasks: Request Police Report, Gather Photos, Collect Statement.
  • Stage: Damage Assessment – Tasks: Inspect Vehicle, Estimate Repair Cost.
  • Stage: Fraud Risk Assessment – Tasks: Check Claims History, Analyze Driver Behavior, Run AI Risk Score.
Each task is only available when its precondition is met. If the police report is missing, the damage assessment can’t start. If the fraud score exceeds a threshold, a new stage—Fraud Investigation—is triggered.
This is a textbook CMMN use case. The process isn’t linear. It’s responsive. The model reflects reality, not a fantasy of predictability.
Law Enforcement: Criminal Investigation Case Management
An incident report is logged. The investigation is not a flowchart. It’s a living case. New leads, witness statements, forensic reports—each can open new investigative paths.
Key CMMN elements in play:
  • Case File – Holds all evidence, statements, and photos.
  • Stages – Initial Review, Forensics, Interviews, Suspect Profiling, Prosecution Preparation.
  • Entry Conditions – No task starts until its condition is met (e.g., “After 3 witness statements are received”).
  • Sentries – Events like “New Evidence Received” or “Suspect Identified” can trigger new tasks.
This model adapts as new information arrives. It doesn’t require a pre-defined path. It exists to support discovery.
When to Use CMMN: A Decision Framework
Ask yourself these four questions. If you answer “yes” to three or more, CMMN is likely the right choice.
  1. Does the next step depend on human judgment or new data?
  2. Are multiple tasks likely to run in parallel or out of order?
  3. Can new tasks be added dynamically during execution?
  4. Is the process outcome uncertain until completion?
If yes to most, don’t force it into BPMN. You’ll only create a fragile model that breaks under real-world conditions.
CMMN vs. BPMN: Decision Matrix
Criteria CMMN BPMN
Best for Adaptive, knowledge-driven work Repeatable, rule-based processes
Control flow Constraint-based (conditions, events) Sequence-driven (flow, gateways)
Task initiation Triggered by conditions or events Follows defined flow
Flexibility High – tasks appear dynamically Low – must be predefined
Use case Medical diagnosis, fraud investigation, incident response Order processing, approval workflows, payroll
Common Pitfalls When Modeling with CMMN
I’ve reviewed hundreds of CMMN models. The most common mistakes aren’t in the notation—they’re in mindset.
  • Over-engineering stages – Too many stages make the model hard to read. Keep it to 3–5 unless justified.
  • Ignoring entry/exit conditions – Without clear criteria, tasks can start too early or never at all.
  • Confusing tasks with actions – A task should be a unit of work. Avoid breaking it down into sub-tasks in CMMN—use a subprocess if needed.
  • Forgetting the case file – The case file is the central repository. It’s where all documents, data, and decisions live. Omit it, and you lose traceability.
Remember: CMMN is not a flowchart. It’s a case plan. The goal is not to show every step, but to show when a step can happen.
When CMMN Isn’t the Answer
Let’s be clear: CMMN isn’t a replacement for BPMN. It’s a tool for different problems.
Don’t use CMMN when:
  • The process is highly predictable (e.g., invoice approval).
  • There’s a fixed sequence of steps with no variation.
  • Automation and system integration are the primary goals.
  • Teams are not trained in knowledge-centric modeling.
If your process resembles a kitchen recipe—same ingredients, same steps, same outcome—BPMN is more efficient and easier to automate.
What are some real-world CMMN examples?
Real-world CMMN examples include medical diagnosis workflows, insurance claim investigations, criminal case management, customer dispute resolution, and software defect triage. These all require human judgment, evolve with new data, and can’t be rigidly sequenced.
When to use CMMN instead of BPMN?
Use CMMN when the process is adaptive, decision-driven, and depends on expert knowledge. When the next step isn’t known in advance, and new tasks emerge based on data or events, CMMN is the correct choice.
Can I use both BPMN and CMMN in the same system?
Yes—this is common in mature organizations. Use BPMN for predictable workflows (e.g., order fulfillment), and CMMN for the adaptive parts (e.g., exception handling, investigations). You can embed a CMMN case as a subprocess in a BPMN process.
What’s the biggest mistake people make with CMMN?
Trying to make it a flowchart—forcing a linear path. CMMN is about control through conditions and events, not sequence. The model should reflect flexibility, not rigidity.
How do I know if I’m modeling a case or a process?
Ask: “Would the same steps happen every time, regardless of context?” If yes, it’s a process. If the path depends on data, decisions, or external inputs, it’s a case.
Is CMMN harder to learn than BPMN?
Not inherently. But it requires a shift in thinking—from flow-based to constraint-based modeling. Once you understand that the case plan defines *when* tasks can run, not *what* they are, it becomes intuitive.
