Diagrams That Don’t Match Stakeholder Language
Время чтения: 7 мин. 50 просмотров
Too many BPMN diagrams fail not because of syntax errors, but because they speak a language only developers and process engineers understand. I’ve seen teams spend weeks building a «perfect» model—correct notation, flawless flow, clean layout—only to present it to business stakeholders who look confused, nod politely, and walk away without real engagement.
That’s not a modeling problem. It’s a communication failure. The real issue isn’t the diagram’s structure—it’s the vocabulary used to build it. When we label activities “Process Request v2.1,” or use event types like “ErrorEventDefinition,” we’re not modeling the business. We’re hiding behind technical jargon.
BPMN stakeholder communication mistakes aren’t about bad tools or poor layout. They stem from modeling without context. The diagram becomes a black box for business users, who can’t trust it, can’t validate it, and ultimately don’t believe it. This undermines every effort toward process transparency, automation, and continuous improvement.
Here’s what you’ll learn: how to reframe your modeling mindset, align BPMN with business language, and ensure diagrams become shared artifacts—not just technical documents. You’ll see real examples from actual workshops, and practical techniques to remove jargon from BPMN so non-technical users can understand, engage, and own the process.
Why Business Stakeholders Don’t Trust Your Diagrams
Let’s be clear: business stakeholders aren’t opposed to process models. They want clarity, visibility, and control. But when they see a diagram full of system IDs, internal codes, and cryptic abbreviations, their instinct isn’t to engage—it’s to disengage.
They’re trained to trust language they use every day: “customer submits application,” “verify identity,” “approve or reject.” They don’t think in “Task_007” or “SendEmailEvent.” They think in actions that make sense in their world.
When a process model uses terminology that doesn’t match daily conversations, the result is a mismatch between documented behavior and actual workflow. This creates a gap. And worse—when the process fails, no one knows why because the model doesn’t reflect reality.
Real-World Example: The «System ID» Trap
On a recent project, a team modeled a loan approval workflow with activities like:
  • “Execute Rule Engine: R201”
  • “Trigger Audit Task: AT_44”
  • “Persist State to DB: STAGE_3”
When presented to business users, the response was silence. After a follow-up walkthrough, it turned out “R201” stood for “Risk Scoring Rule 2.0,” but no one had explained that. The model was technically accurate—on paper. But in practice, it was meaningless to the people who ran the process.
Simple fix? Replace “Execute Rule Engine: R201” with “Score applicant’s credit risk.” Now the step makes sense. The stakeholder can confirm: “Yes, that’s exactly what we do.”
Practical Strategies for Aligning BPMN with Business Language
Modeling isn’t about technical correctness alone. It’s about clarity. If the model doesn’t reflect the language of the people who live the process, it won’t be trusted—or used.
1. Start with the Stakeholder’s Vocabulary
Before writing a single activity, ask: “What do our stakeholders call this step?” Use their exact words. If they say “verify identity,” don’t write “validate user credentials.” Don’t assume they mean the same thing.
Run a quick workshop. Have business users describe the process in plain English. Capture their phrases. Build the model from those words. The result? A model that feels familiar, not foreign.
2. Replace Codes and IDs with Meaningful Labels
System IDs, internal version numbers, and internal code names have their place—but not in the main process model. They belong in metadata or references, not in the flow.
Instead of:
  • “Task: HR_SCE_003”
  • “Event: Error_404”
Use:
  • “Approve leave request”
  • “Notify manager of error”
The goal is not to eliminate all technical detail. It’s to make the main flow understandable without needing a decoder ring.
3. Use Business-Facing Decision Logic
Gateways often become the biggest source of confusion. A simple “Yes/No” decision in a model can be labeled with technical logic like “(Status == ‘Pending’) AND (DaysSinceLastUpdate > 7).” That’s not business language.
Instead, label the decision path with natural language:
  • “Is the application older than 7 days?”
  • “Has the customer responded to the reminder?”
For complex rules, keep the logic in the model but use a reference (like a DMN table) and label the gateway with a plain-English summary: “Determine approval eligibility.”
4. Document Business Context in Annotations
Annotations aren’t just for explaining syntax. They’re for capturing intent.
When a stakeholder says, “We only approve if the applicant has no criminal record,” that’s not a task—it’s a rule. Use an annotation to record it. Keep the model clean, but make the logic traceable.
Example:
Approve application
  → [Annotation: Applies only if applicant has no criminal record in last 5 years]
Now, when the process is reviewed, that rule is visible and verifiable.
5. Test with a «Non-Technical» User
Before finalizing a diagram, ask someone without a technical background to walk through it. If they struggle to explain a step, the label is too technical.
Ask: “Can you describe this step in your own words?” If they pause or say “I don’t know,” the label fails. Revise it until it makes sense without explanation.
BPMN Diagrams for Non-Technical Users: A Checklist
Here’s a quick checklist to ensure your diagrams are accessible to business stakeholders:
  • Every activity uses verbs and nouns from stakeholder language (e.g., “submit,” “notify,” “approve”).
  • Every gateway uses plain-English decision criteria (e.g., “Is the customer’s address verified?”).
  • System references (like IDs or code names) are moved to a separate reference table or metadata section.
  • Annotations explain business rules, exceptions, and assumptions.
  • Terminology is consistent across all diagrams in a process family.
Apply this checklist to every model. It won’t fix all problems—but it will prevent the most common ones.
Aligning BPMN with Business Language: A Framework
Here’s a simple framework I use with teams to reframe their modeling approach:
  1. Identify the audience—Is it business users, IT, or both?
  2. Map their language—Find 3–5 key phrases they use in daily work.
  3. Build the model using only those words—No exceptions.
  4. Test with a non-technical person—If they understand it on first read, you’ve succeeded.
It sounds simple. But I’ve seen teams spend months refining a model that still failed this test—because they modeled “how the system works,” not “how the business thinks.”
Remember: a BPMN model is not a technical document. It’s a conversation. If the conversation is in a language the other person doesn’t speak, the model is useless.
How do I handle technical terms that are unavoidable?
When you must include technical terms (like “API call” or “workflow engine”), pair them with a plain-English explanation. Use an annotation, or label the activity in two parts: “Call customer database (API)”.
Can I use business language in the model and technical details in the documentation?
Yes—this is best practice. The BPMN diagram should convey business logic. Technical implementation lives in a separate document or metadata section. Keep the model focused on the process, not the code.
What if stakeholders use different terms for the same step?
Facilitate a consensus session. Let stakeholders debate and agree on a shared language. The goal is not to please everyone—but to align on one clear term.
Is it okay to use acronyms if they’re industry-standard?
Only if the audience understands them. If in doubt, spell it out on first use. For example, “Customer Relationship Management (CRM)”.
How do I handle processes that are both business and technical?
Use a two-tier approach. Model the business process first, using business language. Then, in a separate diagram or appendix, show how the technical implementation supports it. Keep the main model focused on stakeholders.
Should I retrain stakeholders to use BPMN terms?
No. The model must speak their language. Forcing them to learn BPMN jargon defeats the purpose. Your job is to translate business reality into BPMN—not the reverse.
Remember: the best BPMN model isn’t the one with perfect notation. It’s the one that makes the business say: “Yes, that’s how we do it.”
