Inconsistent Use of Direction and Flow Conventions
Время чтения: 6 мин. 65 просмотров
When I first started working with BPMN, I was handed a diagram that zigzagged across the page—left to right, then top to bottom, then back again. It wasn’t just messy. It felt like reading a story where the narrator jumps between timelines without warning. That’s what inconsistent BPMN flow direction issues do: they break the reader’s mental model and make the process feel unpredictable.
Flow direction isn’t just about layout. It’s a core convention that guides how people interpret sequences, decisions, and handoffs. When teams mix left-to-right and top-to-bottom flows without clear rules, they create diagrams that are technically correct but practically useless.
This chapter is about fixing that. You’ll learn how to identify inconsistent BPMN conventions, apply consistent flow standards, and build team-wide practices that make your models clearer, more reliable, and easier to maintain.
Why Flow Direction Matters
Flow direction is not arbitrary. It’s a visual signal. Most readers expect processes to unfold from top to bottom or left to right—much like reading a book. When that expectation is broken, cognitive load increases.
Consider a decision point where one outcome flows right and another flows down. The reader must pause and reorient. That pause becomes a mental hurdle every time. Over a complex diagram, these breaks add up.
BPMN itself doesn’t mandate a single direction. But the BPMN diagram direction standards set by the OMG and popular in enterprise modeling tools strongly favor top-to-bottom for internal processes and left-to-right for collaboration diagrams.
Common Patterns of Inconsistency
Here are the most frequent signs of flow direction issues:
  • Same decision node sends one branch left, another down.
  • First flow goes left-to-right, second flow switches to top-to-bottom.
  • Sub-processes flow in opposite directions from their parent.
  • Message flows between pools use inconsistent angles or directions.
These inconsistencies confuse the reader. Worse, they create ambiguity in execution logic—especially when automated.
Establishing Team-Wide Flow Conventions
There’s no one-size-fits-all rule. But there are standardizing BPMN flow principles that work across most domains.
Start by selecting a primary flow direction:
  1. Top-to-bottom (Recommended for most internal processes): Best for sequential workflows like order fulfillment, case management, or approval chains.
  2. Left-to-right (Recommended for collaboration diagrams): Ideal for cross-functional or multi-pool processes where multiple parties are involved.
Once chosen, apply it consistently across all diagrams in your repository. This includes sub-processes, event subprocesses, and embedded decision points.
Visual Clarity Over Flexibility
Some modelers argue that “the diagram should flow naturally.” But natural flow only matters when everyone agrees on what “natural” means. Without a shared standard, “natural” becomes personal preference.
Example: A process starts with a “Check eligibility” task that flows left. But the next step is “Approve application,” which flows down. Why the shift? No reason. It’s just a layout choice—yet it breaks the reader’s mental map.
Here’s a better rule: Flow direction should be consistent within a single diagram, regardless of complexity.
Before and After: Fixing Inconsistent Flow
Let’s look at a real-world example.
Before: Mixed Flow Direction
A loan approval process starts with a top-down flow but shifts to left-to-right after the “Evaluate Risk” gateway. One branch goes right, another down. The handoff to the “Credit Check” task appears disconnected from the main line.
This design doesn’t break BPMN’s syntax, but it confuses readers. Is the risk evaluation a side activity? Is the credit check dependent on it? The answer isn’t clear.
After: Unified Top-to-Bottom Flow
Revised version: All steps now flow top to bottom. The “Evaluate Risk” gateway splits into two paths: one goes down for “Low Risk,” the other down for “High Risk.” The “Credit Check” task is now clearly below the decision node.
Now, every step follows the same visual rhythm. Readers can trace the process in one continuous motion. No mental reorientation. No ambiguity.
This is what standardizing BPMN flow looks like in practice: clear, predictable, and reliable.
Practical Steps to Fix Your Flow
Here’s a simple checklist to audit and correct flow direction issues.
  1. Define your team’s flow convention: Choose top-to-bottom or left-to-right as default. Apply to all new diagrams.
  2. Review existing diagrams: Identify any mixed flows. Flag them for refactoring.
  3. Refactor with consistent flow: Realign elements so all major flows move in the same direction.
  4. Document the standard: Add a section in your modeling guide: “All processes follow top-to-bottom flow unless a collaboration diagram justifies left-to-right.”
  5. Use tooling to enforce: Many BPMN tools (like Visual Paradigm) allow you to set default flow direction. Enable it to reduce manual errors.
Don’t underestimate the power of a single rule. A team of 10 modelers, all following the same flow direction, will produce diagrams that feel like parts of the same system—even if they never collaborate directly.
When to Use Left-to-Right Flow
Left-to-right flow isn’t just for collaboration diagrams. It works well when:
  • Modeling a customer journey across touchpoints.
  • Showing handoffs between departments where direction matters (e.g., HR → Payroll).
  • Representing parallel or alternative paths that don’t fit naturally in a vertical stack.
But if you switch to left-to-right, ensure consistency. Don’t make one diagram horizontal and another vertical without a strong reason.
Key Takeaways
Bad BPMN diagrams don’t just confuse readers—they undermine trust in the entire process model. Consistent flow direction isn’t about aesthetics. It’s about clarity, correctness, and shared understanding.
Remember: BPMN flow direction issues are avoidable with a simple team agreement and consistent application. The goal isn’t perfection. It’s predictability.
Start small. Pick one diagram. Fix the flow. Show your team. Repeat. Over time, you’ll build a culture where clarity is valued over creativity.
Should all BPMN diagrams use the same flow direction?
No—but consistency within a diagram is essential. Use top-to-bottom for internal processes. Use left-to-right for collaboration or customer journey models. Stick to one per diagram.
Can I mix flow directions if it improves readability?
Not without risking confusion. Even if it “looks” better, mixing directions breaks the reader’s mental model. If a layout feels awkward, restructure it using one consistent flow, not multiple.
What’s the most common flow mistake in BPMN?
Mixing top-to-bottom and left-to-right flows without intent. This often happens in larger diagrams when modelers improvise. The result is a fragmented, hard-to-follow process.
How do I enforce consistent flow in a team with diverse experience?
Create a lightweight BPMN modeling guide. Include a flow direction rule: “All processes use top-to-bottom flow unless otherwise specified.” Share examples. Use tool validation features to flag inconsistent flows.
Do BPMN standards require a specific flow direction?
No formal standard mandates direction, but top-to-bottom is the de facto default in practice. The OMG’s reference diagrams use vertical flow. Follow that pattern for maximum readability.
Should I restructure old diagrams to fix flow direction?
Yes—especially if they’ll be reused or shared. A small investment in restructuring saves time, reduces errors, and strengthens team alignment over time.
