Missing or Misleading Pools and Lanes
Время чтения: 8 мин. 77 просмотров
It’s tempting to skip pools and lanes when modeling a simple process. After all, the flow seems clear enough—start, do this, then do that. But that instinct leads to one of the most common causes of confusion: missing BPMN pools or poorly structured lanes. Without them, the model becomes ambiguous. Who is doing what? When does responsibility shift? It’s like a conversation without speakers—everyone assumes they know who said what, but they don’t.
I’ve seen dozens of diagrams where multiple roles share a single lane, or departments are crammed into one pool. It looks efficient at first glance. But in reality, it creates a responsibility modeling issue. A single lane can’t represent multiple stakeholders without causing overlap, ambiguity, and handoff confusion. Worse, when you try to automate or audit such a model, it fails quickly because the ownership isn’t clear.
Here’s what you gain from this chapter: a clear framework for when and how to use pools and lanes correctly. You’ll learn how to diagnose problematic structures, restructure legacy diagrams, and apply a consistent, stakeholder-friendly approach that enforces clarity. This isn’t about formalism—it’s about creating models that can be trusted, communicated, and executed.
Why Pools and Lanes Matter: The Real Cost of Ambiguity
Every BPMN diagram is a communication artifact. If it’s not clear who owns each step, it fails its primary purpose. Pools and lanes exist to answer one question: Who is responsible for this activity?
When you omit pools, the model collapses into a single-actor narrative—even if multiple departments or systems are involved. This isn’t just inaccurate—it’s dangerous. In one project, a “simple” order fulfillment process spanned procurement, warehouse, and finance. No pools. No lanes. The team assumed “the system” handled everything. When automation failed, it turned out no one had taken responsibility for the final approval step.
That’s an example of incorrect lane usage. Not every role needs its own pool. But each distinct responsibility—especially if it involves different departments, customers, or systems—should be in its own lane. This isn’t about design flair. It’s about preventing silent failures in execution.
When Pools Are Necessary
Use a pool to represent a major participant in a collaboration:
  • A department (e.g., HR, Finance)
  • An external organization (e.g., a bank, supplier, customer)
  • A system or application (e.g., CRM, ERP)
Always ask: Is this entity a distinct decision-maker or performer in the process? If yes, it should be a pool.
When Lanes Are Required
Lanes divide a pool into roles or sub-teams. Use them when responsibilities are split within a single organization or system.
For example, in an invoice approval process, the “Finance Department” might be the pool. Inside it, you’d have lanes like “Accounts Payable Clerk,” “Manager,” and “Auditor.” Each lane owns specific tasks.
Never use one lane to represent two different roles. It’s a recipe for confusion. If you find yourself naming a lane “Team A / Team B,” you’ve already failed.
Common Mistakes and How to Fix Them
Mistake 1: Using a Single Lane for Multiple Departments
Example: A single lane labeled “Operations” that contains tasks from Sales, Logistics, and Customer Service.
Why it fails: No one knows who’s supposed to own the “Respond to Customer Query” task. Is it sales? Support? Both?
Fix: Split the pool into separate lanes. If the process involves both internal departments and external partners, use multiple pools with clear lanes inside each.
Mistake 2: Lumping All Roles into One Pool
Example: An onboarding process where “HR,” “IT,” “Finance,” and “Manager” are all in a single pool with no lanes.
Why it fails: The flow appears to be internal and unified. But in reality, handoffs happen between teams. Without lanes, the model hides who is responsible for each step.
Fix: Create a pool for the organization (e.g., “Company”) and add lanes for each role: “HR,” “IT Support,” “Finance,” “Manager.” Use message flows to show handoffs between lanes.
Mistake 3: Using Message Flows in the Wrong Context
Example: Using a message flow between two tasks in the same pool without clear handoff intent.
Why it fails: It misrepresents the collaboration. Message flows should represent interactions between pools or between a pool and an external participant.
Fix: Only use message flows between separate pools. If the handoff is internal, use a sequence flow. If it’s external, use message flow with a clear sender and receiver.
Mistake 4: Ignoring the Business Context
Example: A lane labeled “System” that contains tasks like “Send Email” and “Update Database” without any human actor.
Why it fails: It confuses business process modeling with technical implementation. The model becomes unreadable to business stakeholders and unusable for handover or audit.
Fix: Replace abstract labels with business-facing actions. Instead of “Send Email,” use “Notify applicant of status.” If technical actions are necessary, model them in a separate technical process or use a sub-process with clear business outcome.
Step-by-Step: How to Correctly Structure Pools and Lanes
  1. Identify all participants: Who is involved in the process? List each distinct role, department, or system.
  2. Group by ownership: Assign each participant to a pool. A single pool can contain multiple lanes.
  3. Create lanes for roles: Within each pool, define lanes for each distinct role performing a task.
  4. Assign tasks to lanes: Each activity must belong to exactly one lane. No ghost tasks.
  5. Use flows correctly: Use sequence flows for internal order; message flows only between pools.
  6. Review for clarity: Walk through the process. Can you identify who does what? Who triggers the next step?
Apply this method to any process, no matter how simple. It’s not overkill—it’s the foundation of a trustworthy model.
Before and After: A Real Example
Consider a loan application process. Before correction, the diagram had one pool with a single lane labeled “Operations,” and all tasks were in a sequence flow. The model implied a single actor was making all decisions.
After correction:
  • Pools: “Customer,” “Loan Department,” “Credit Bureau,” “Finance Team”
  • Lanes: “Customer” (only “Submit Application”), “Loan Department” (e.g., “Review Application,” “Approve/Reject”), “Credit Bureau” (e.g., “Verify Credit Score”), “Finance Team” (e.g., “Issue Loan”)
  • Message flows: “Send to Credit Bureau,” “Receive Credit Report,” “Notify Customer of Decision”
The result? A clear, auditable model where responsibilities are visible, handoffs are explicit, and the flow reflects real collaboration.
Best Practices for Long-Term Clarity
Consistency beats perfection. Even if a model isn’t perfect, it should follow a shared standard. Here are three rules I use in my own work:
  • One role, one lane: Avoid splitting roles across lanes. If a person performs two functions, model them as two separate lanes.
  • Label lanes by role, not function: Use “HR Manager,” not “Approver.” It’s more specific and stakeholder-friendly.
  • Use color coding only with purpose: If you use color, define it in a legend. Avoid relying on color alone to communicate responsibility.
Remember: A well-structured pool and lane diagram isn’t just about clarity—it’s about accountability. If a process fails, the model should help you trace responsibility, not obscure it.
Do I need a pool for every process?
No. Use a pool only when collaboration between distinct entities is involved. For a single-actor process (e.g., “Process a customer complaint”), you can use a single pool with one lane labeled “Support Agent.”
Can I use multiple lanes in one pool?
Yes—this is standard practice. For example, a company pool can have lanes for “Sales,” “Marketing,” “IT,” and “Finance.” Each lane owns its tasks.
What if a task involves multiple roles?
Assign the task to the primary responsible lane. If multiple roles contribute, model it as a sub-process or use a shared task with a note. But never split one task across multiple lanes—this creates ambiguity.
Can I use message flows within a single pool?
Only if the message represents a communication between roles within that pool. But it’s rare. If the message is internal, use a sequence flow. Use message flows only when the sender and receiver are in different pools.
Why is my diagram still unreadable after adding lanes?
Check layout. Ensure lanes are aligned, flows don’t cross, and the process flows left to right or top to bottom. Cluttered layout undermines even the best structure.
Should I model the customer as a pool?
Yes—especially in customer-facing processes. It forces you to consider their role, actions, and expectations. A customer pool is not extra; it’s essential for a complete journey model.
