Evolving Models: Keeping CRC Thinking Alive During Maintenance
Время чтения: 7 мин. 56 просмотров
How do you maintain clarity and adaptability in a system that’s been in production for years? The answer isn’t just in the UML diagram—it’s in the CRC design maintenance mindset. Too often, after a system moves from CRC cards to formal UML, the team abandons the collaborative, responsibility-driven rhythm that made the model meaningful. This isn’t just about documentation; it’s about preserving the intent behind the design.
My experience working with teams across startups and enterprises shows that once the model is formalized, the risk of losing insight into *why* certain responsibilities exist is real. The model becomes static, and the team starts treating it as a contract rather than a living guide. But it doesn’t have to be that way.
By integrating CRC practices into maintenance cycles, teams keep their software responsive, understandable, and maintainable. This chapter shows how to preserve the collaborative spirit of CRC—even long after the class diagram is complete—through ongoing modeling, regular design reviews, and consistent responsibility tracking.
Why CRC Shouldn’t Be Left Behind After UML
UML diagrams are excellent for documentation, but they’re often too abstract to capture the real reasoning behind design decisions. CRC cards, on the other hand, were never meant to be permanent—they were tools for discovery, for alignment, and for clarity.
When teams transition to UML and then discard CRC practices, they lose the opportunity to revisit design intent. A class diagram may show a PaymentProcessor class with a method processPayment(), but it doesn’t explain why that responsibility was assigned or who else was involved in the decision.
That’s where ongoing modeling comes in. Revisiting CRC principles during maintenance keeps the team grounded in the original collaboration. It ensures that changes are not just structural, but contextually sound.
Reinforce Intent, Not Just Structure
Every time a change is made to a class or its behavior, the team should ask: What was the original responsibility? Who collaborated on this? Is this still valid?
Revisiting these questions through a CRC lens prevents drift. It turns maintenance from a mechanical update into a thoughtful review.
A simple habit: when reviewing a change, create a 1-page CRC snapshot of the affected class and its collaborators. This isn’t for documentation—it’s for mental alignment.
Integrating CRC into Maintenance Workflows
Integrating CRC into maintenance doesn’t mean reverting to paper cards. It means preserving the *thinking pattern*—responsibility-driven, collaborative, and behavior-focused—within modern workflows.
Use CRC in Design Reviews
When evaluating a change, use CRC as a quick check-in. Before approving a new method or modifying a class, ask:
  • What responsibility does this method fulfill?
  • Who else should be involved in this behavior?
  • Is this responsibility still valid with the current context?
This isn’t about redoing the full CRC card—just a 3-minute mental exercise to assess design integrity.
Reinforce Responsibility-Driven Updates
Every time you refactor or extend a class, treat the change as a new CRC session. Ask:
  1. What new responsibility is introduced?
  2. Does this responsibility belong to this class—or should it be split?
  3. Who else should be involved? Can the collaboration be simplified?
This process keeps the model honest. It resists the temptation to add methods just because the code is there.
Example: Refactoring a User Authentication Class
Imagine a UserAuthService class that has grown to handle password validation, token generation, email verification, and role assignment. During a maintenance review, the team uses a quick CRC to assess:
Class Responsibilities Collaborators
UserAuthService Validate credentials PasswordEncoder, EmailService
UserAuthService Generate authentication token TokenGenerator
UserAuthService Assign role post-verification RoleManager
Now the team sees that the class is handling multiple responsibilities. The CRC reveals that it’s a *collaboration hub* without clear ownership. This insight leads to splitting the class into AuthenticationService, TokenService, and AuthorizationService.
That single CRC snapshot prevented a design anti-pattern that would have caused maintenance headaches later.
Tools to Keep CRC Thinking Alive
Modern tools don’t have to replace CRC—they can amplify it. Here’s how to use them to preserve the spirit of CRC in maintenance:
  • Visual Paradigm’s CRC Mode: Use the built-in CRC card editor to create lightweight cards even after the class diagram is complete. Attach them to the class as notes or comments.
  • Version Control with CRC Snapshots: Save CRC templates as Markdown or JSON files in your repo. Use them as part of pull request templates to ensure every change is evaluated through a CRC lens.
  • Design Review Checklists: Include a “CRC Integrity Check” section in your design review form. Ask: “Does this change align with the original CRC responsibilities?”
Checklist: Maintaining CRC Integrity
Use this checklist every time you update a class or add a feature:
  1. Revisit the original CRC card for the class.
  2. Is the new responsibility consistent with the original intent?
  3. Does the collaboration pattern still make sense?
  4. Have we introduced new responsibilities that should be in another class?
  5. Have we documented the change using a revised CRC card?
If you can’t answer these in under three minutes, the change might need more discussion.
When to Revisit CRC During Maintenance
Not every update needs a full CRC session. But certain triggers indicate it’s time to go back to the roots:
  • When a class grows beyond 50 lines of code.
  • When you find yourself asking, “Why is this here?”
  • When a new developer struggles to understand a class’s purpose.
  • When a feature spans multiple classes and the collaboration feels unclear.
These are not signs of poor code—they’re signals that the responsibility-driven updates model has drifted. A quick CRC session can realign the team and clarify intent.
Conclusion: The Maintenance Mindset
Great software isn’t just built—it’s maintained with care. CRC isn’t a phase; it’s a philosophy. The goal isn’t to archive design decisions but to keep the team connected to the reasoning behind them.
By embracing ongoing modeling, using CRC in design reviews, and applying responsibility-driven updates, teams ensure their systems remain adaptive, understandable, and robust—even years after the initial design.
Don’t let the UML diagram become a tombstone. Keep the CRC spirit alive.
How often should we revisit CRC cards during maintenance?
Not every change requires a full CRC session, but revisit CRC thinking whenever a class grows, a new feature spans multiple classes, or a developer expresses confusion. Use CRC as a mental checkpoint, not a ritual.
Can CRC still be useful in large, mature systems?
Absolutely. In complex systems, CRC cards help teams re-clarify intent. They’re especially useful during refactoring, onboarding, or when resolving long-standing ambiguity in behavior.
What if the original CRC cards don’t exist anymore?
Reconstruct them. Use the current class diagram and the team’s memory to create a new CRC card. The act of rebuilding is often more valuable than the card itself—it re-creates shared understanding.
How do I convince my team to use CRC in reviews?
Show them the cost of drift: unclear responsibilities, duplicated logic, and longer onboarding. Use CRC as a diagnostic tool—not a burden. Start with one small case and measure the improvement in clarity and decision speed.
Is CRC still relevant in automated testing and CI/CD pipelines?
Yes. CRC thinking translates into better test design. When you know a class’s responsibility, you write better unit and integration tests. Use CRC to define test scenarios and verify behavior alignment.
Can I automate CRC card generation from UML?
Not perfectly—but you can use UML as input. Tools like Visual Paradigm can auto-generate CRC-style summaries from class diagrams. These aren’t replacements for human-driven analysis but serve as starting points for discussion.
