Industry and Domain-Specific Guidance
Estimated reading: 3 minutes 82 views
Many teams jump straight into modeling without asking the right question: What does this system actually do, and who cares about how it does it? You’ve already learned the core differences between DFDs and UML—but now it’s time to apply them where it matters most: in real-world systems.
This section cuts through the abstraction and shows you how top industries—finance, healthcare, e-commerce, manufacturing, and real-time systems—actually use DFDs and UML in practice. You’ll discover why some domains rely on DFDs for their clarity in data lineage and compliance, while others turn to UML for its precision in object behavior and state transitions.
By the end, you’ll stop asking “Which one should I use?” and start asking “What does this domain truly need?” With real examples drawn from actual system designs, you’ll learn to match the right diagram to the right context—without over-engineering or under-modeling.
What This Section Covers
Explore how modeling choices shift across domains, with practical guidance tailored to system type and regulatory demands.
  • Financial Services: DFDs for Compliance and Audit Trails – See why transaction systems in banking prioritize DFDs for clear audit trails and compliance with standards like SOX and PCI-DSS.
  • E-Commerce: UML for Session Management and Microservices – Understand why shopping cart state and microservice coordination are better modeled with UML’s sequence and state diagrams.
  • Healthcare: DFDs for Patient Data Flows, UML for Clinical Workflows – Learn how HIPAA-compliant data flows and clinical episode modeling require both DFDs and UML in tandem.
  • Manufacturing/ERP: DFDs for Material and Process Flows – Discover why material bills, production sequencing, and inventory tracking align naturally with DFD structure.
  • Legacy Modernization: DFD First, UML Second – Master the proven sequence: analyze legacy systems with DFDs, then redesign with UML for modern architecture.
  • Real-Time/Embedded Systems: UML Dominates – See why UML’s timing and state diagrams are essential for embedded systems, where DFDs fall short on timing and interrupts.
  • Identify whether DFD or UML is better suited for a given industry or system type.
  • Apply DFDs to trace data lineage in regulated environments like financial modeling DFD vs UML scenarios.
  • Use UML to model complex state transitions in e-commerce session management and clinical workflows.
  • Implement a dual-notation strategy in healthcare system modeling notation for both compliance and care delivery logic.
  • Apply DFDs to map material and process flows in manufacturing systems with high accuracy.
  • Guide legacy modernization using a DFD-first, UML-second approach for smooth transition from procedural to object-oriented design.
Whether you’re modeling a bank’s transaction pipeline or a hospital’s patient journey, the right diagram isn’t just about style—it’s about clarity, compliance, and communication. This section equips you with the judgment to choose wisely.
Lên đầu trang
