Understanding the Methodologies
Estimated reading: 3 minutes 115 views
Have you ever spent hours drawing a diagram only to realize it didn’t help your team understand the system—just confused them? That’s a common trap when jumping into modeling without first understanding the underlying worldview. This section tackles that exact challenge by clarifying why DFD and UML aren’t just different diagrams—they represent fundamentally different ways of thinking about software.
As someone who’s worked with both for over two decades, I’ve seen how misaligned expectations can derail even the best-intentioned projects. This section is designed to help you move beyond “which one looks better” and instead ask: what problem am I really trying to solve? By grounding your choices in philosophy, history, and practical trade-offs, you’ll build a mental model that makes every decision feel intentional—not just a ritual.
You’ll learn not just how to draw either DFDs or UML diagrams, but when each truly shines. This is where the real power of modeling begins: not in syntax, but in perspective.
What This Section Covers
Here’s what you’ll unlock as you progress through this foundational section:
  • Data Flow Diagrams vs. UML: Fundamental Philosophy Differences – See how DFDs focus on data transformation through processes, while UML centers on objects interacting over time. We’ll walk through a real-world example side-by-side to show how each worldview shapes the model.
  • The Evolution of Each Notation: Historical Context – Understand how DFD emerged from batch-processing needs in the 1970s, and how UML rose from the complexity of object-oriented systems in the 1990s. Knowing their roots helps predict modern use cases.
  • Core Strengths and Limitations of Each Approach – A side-by-side analysis of expressive power, scalability, learning curve, and tooling. You’ll also hear from practitioners about where each model starts to fail in real projects.
  • When Notation Choice Actually Matters Most – Learn the high-leverage moments—like requirements workshops or compliance reviews—where picking the wrong diagram type can cost days or even weeks in rework.
By the end you should be able to:
  • Explain the key philosophical divide between functional decomposition (DFD) and object modeling (UML)
  • Distinguish DFD structured analysis vs UML based on their historical and technical roots
  • Assess when DFD or UML is better suited for a given project based on data flow complexity or behavioral depth
  • Briefly compare modeling approaches using real-world examples of the same system modeled both ways
  • Identify high-impact decision points where the right notation choice prevents future friction
  • Recognize that the best model isn’t always the most complex—it’s the one that aligns with your team’s mindset and problem domain
Lên đầu trang
