Primary Decision Factors: Data vs. Object Focus
Temps estimé :7 minutes 61 vues
At the heart of every system design lies a fundamental question: do we start by tracing data as it moves through a system, or by modeling the objects that act upon it? The moment you begin analyzing a business process, this decision shapes how clearly you’ll communicate with stakeholders, how well you’ll manage complexity, and how maintainable your design will become.
Too often, teams default to UML out of habit, even when the problem is fundamentally about data movement. I’ve seen this happen repeatedly—business analysts drawing class diagrams for a batch reporting system, only to find that stakeholders can’t read them. Conversely, I’ve seen DFDs used to model user interactions in an e-commerce platform, leading to ambiguous flows and missed state transitions.
This chapter cuts through the noise. Based on two decades of working with teams across finance, healthcare, and software development, I’ll show you how to choose between data flow modeling and object modeling—not based on preference, but on the actual nature of the system you’re building.
Core Decision Framework: Data Flow vs. Object Collaboration
When a system’s behavior is defined by how data moves, transforms, and persists, DFD is your best friend. When it’s defined by how objects interact, change state, and manage identity, UML wins.
Ask These 3 Questions to Decide
  1. Is the primary goal to document data lineage and transformation? If yes, DFD is likely better. Think batch processing, regulatory reporting, audit trails.
  2. Do objects have complex lifecycles, state changes, or interactions across multiple services? If yes, UML is the clearer choice. Think session management, order fulfillment, clinical workflows.
  3. Are stakeholders mostly non-technical (e.g., business analysts, auditors, operations)? If yes, DFD’s visual clarity often trumps UML’s detail.
This framework isn’t about one notation being “better.” It’s about matching the method to the problem. Let’s explore real-world scenarios.
When Data Movement Dominates: DFD Wins
Consider a healthcare claims processing system. Each claim flows through multiple stages: submission → validation → eligibility check → adjudication → payment. The data moves through predefined steps, with each process transforming the claim in a deterministic way.
Modeling this as a DFD Level 1 reveals the exact data flows, decision points, and store locations—critical for compliance with HIPAA and audit verification. A UML use case diagram might show “Process Claim,” but it doesn’t capture how the data changes at each step.
Use DFD when:
  • You’re modeling end-to-end data lineage for compliance or auditing.
  • Your system is batch-based or event-driven with little stateful object interaction.
  • Stakeholders need a clear picture of where data comes from and where it goes.
When Object Behavior Is Central: UML Wins
Now imagine an e-commerce platform. A user adds a product to their cart, logs in, applies a coupon, and checks out. The cart object persists across sessions, changes state (incomplete → checkout → paid → shipped), and interacts with payment, inventory, and shipping services.
Modeling this in UML using sequence and state diagrams reveals object lifecycles, message timing, and error recovery logic. A DFD might show “process order,” but it can’t show how the cart object retains state or how the user’s session impacts order status.
Use UML when:
  • You need to model state transitions, message sequences, or object collaboration.
  • The system involves user sessions, real-time updates, or distributed microservices.
  • Developers will use the model to generate code or define API contracts.
Decision Tree: How to Choose in Practice
Use this flow to guide your notation choice:
  1. Start with the data flow. Ask: “What data changes, and how?” If the answer is clear and hierarchical (e.g., “claim data is validated, then processed”), DFD is ideal.
  2. Then assess object complexity. Ask: “Do these objects need to maintain state, interact across time, or inherit behaviors?” If yes, UML is required.
  3. Check stakeholder needs. If business users are the primary audience, DFD’s simplicity often wins. If developers are the target, UML’s precision is essential.
  4. Consider scale and lifecycle. For legacy systems or large batch processes, DFD is easier to reverse-engineer. For modern, evolving systems, UML supports change better.
Real-World Examples
Project Type Recommended Notation Why
Payroll processing system DFD Clear data transformation: employee data → payroll rules → payment.
Online banking dashboard UML (Sequence + State) User session, balance state, transaction history—objects with state.
Supply chain inventory tracking DFD Material flow, batch status, warehouse transfers.
Healthcare patient monitoring UML (State + Sequence) Patient vitals change over time; alerts trigger object actions.
Regulatory reporting (SOX, PCI-DSS) DFD End-to-end data traceability is required for audit.
These aren’t rigid rules. In hybrid systems, you can use both—DFD for high-level data flows, UML for detailed object behavior. But never use one when the other is clearly better suited.
When to Model Data Flow vs Objects
Here’s how to apply the decision in real projects:
Use DFD When:
  • You need to prove that data flows from source to destination without loss or alteration.
  • Compliance requires a clear audit trail (e.g., financials, healthcare).
  • You’re analyzing a legacy system with no object-oriented structure.
  • The problem is procedural: “How does this data move through the system?”
Use UML When:
  • The system must maintain state across interactions (e.g., e-commerce carts, user sessions).
  • Multiple objects collaborate through message passing (e.g., microservices, real-time systems).
  • Code generation or API design is part of the workflow.
  • You’re modeling user journeys with multiple state changes.
Remember: DFD is about transformation. UML is about identity and behavior.
Common Pitfalls to Avoid
  • Overusing UML for simple flows. Don’t draw a class diagram when a DFD would be clearer. Over-complexity confuses stakeholders and adds no value.
  • Using DFD for stateful systems. You can’t model “cart is empty” or “order is pending” in a DFD—those are object states, best modeled in UML.
  • Ignoring stakeholder context. Never assume a business user can read a UML sequence diagram. Start with DFD, then refine for technical teams.
  • Forcing one notation on all phases. Use DFD in requirements; UML in design. Each serves its purpose at the right time.
When should I use DFD instead of UML?
Use DFD when the system is dominated by data movement, transformation, and lineage—such as batch processing, compliance reporting, or legacy system analysis. DFD excels at showing what data moves where and how it changes.
Absolutely. Use DFD for high-level data flows (e.g., context diagram) and UML for detailed object behavior (e.g., sequence diagrams). This is called hybrid modeling. The key is consistency: ensure processes map to use cases, data stores to classes, and flows to messages.
Is DFD outdated for modern systems?
No. DFD is not outdated. It’s still ideal for systems where data integrity and movement are critical—such as finance, supply chain, and healthcare. Modern systems may use UML for implementation, but DFD remains valuable for analysis and compliance.
Why do business analysts prefer DFD?
Because it’s visual, intuitive, and focused on what matters to them: data inputs, outputs, and transformations. A DFD doesn’t require object-oriented thinking. It’s a natural fit for stakeholders who need to understand how data moves through a system without getting bogged down in behavior or state.
When should I avoid UML?
Avoid UML when your system is purely functional or transactional with no persistent state. If your team is not trained in UML, or stakeholders can’t interpret sequence/state diagrams, DFD is a better choice. Also avoid it when simplicity and clarity are more important than detailed object interaction.
How do I transition from DFD to UML?
Start with the DFD context diagram. Map each process to a use case. Map data stores to classes. Map data flows to messages or attributes. Use tools like Visual Paradigm to maintain traceability. The goal is not to replace DFD, but to enrich it with object behavior where needed.
