Pitfalls to Avoid When Writing User Stories
Temps estimé :8 minutes 53 vues
Too many teams treat user stories as mini-requirements documents, leading to misalignment, wasted effort, and missed value. I’ve seen teams spend hours refining a story that’s technically precise but fails to reflect user needs—because they focused on syntax over substance. The real danger isn’t the format; it’s the mindset behind it. A user story isn’t a task list or a technical specification. It’s a conversation starter. When you confuse structure with substance, you lose the very purpose of Agile storytelling.
What you’ll learn here isn’t just a checklist of errors. You’ll see how three recurring user story pitfalls—technical bias, missing value statements, and over-detailed content—actually stem from the same root: misunderstanding the story’s role as a collaboration trigger. I’ve worked with teams who thought a story was complete when it included code snippets, only to realize they’d missed the user’s actual goal. This chapter delivers practical fixes grounded in real-world experience, not theory.
By the end, you’ll recognize bad user story examples not just by their flaws, but by their symptoms: silence in refinement sessions, test failures after delivery, or stakeholders asking, “Why did we build this?” You’ll learn to spot these patterns early and turn them into value-driven conversations.
Common Pitfalls in User Story Writing
1. Technical Bias: Writing for Engineers, Not Users
One of the most frequent user story pitfalls is writing from a technical perspective instead of a user’s. I once reviewed a story that said: “As a backend developer, I want to optimize the query using an index on the user_id field.”
That’s not a user story. That’s a task disguised as a story. It doesn’t describe a user need—it assigns work to a role. The real user here? Probably a customer waiting for faster page loads.
Bad user story examples like this often begin with technical roles: “As a database admin…” or “As a DevOps engineer…” They may be accurate, but they fail the most basic test: Does this improve a user’s experience? If not, it’s not a story—it’s a ticket.
Fix it by rewriting with a real user role and clear value. For example: “As a customer, I want the search results to load in under 1.5 seconds so I can quickly find what I need.” The technical implementation (indexing, caching) becomes part of the acceptance criteria, not the story itself.
2. Missing the Value Statement: “I want” Without “So That”
Stories without a “so that” clause are like sentences missing a main verb. They describe an action but not why it matters.
Consider this: “As a user, I want to log in with my email and password.” It’s technically correct, but what’s the value? The user wants to access their account. The real need? To continue their workflow, protect sensitive data, or avoid losing progress.
Bad user story examples like this often surface in refinement meetings. The team agrees, “Yeah, we’ll do this,” but later discovers the login feature doesn’t address the actual user journey—like resuming a draft or securing a purchase.
Always ask: “Why does the user need this?” Replace generic “I want” statements with purpose-driven “so that” clauses. For example: “As a user, I want to log in so that I can securely access my personal profile and continue my shopping cart.”
This change transforms a feature into a value proposition. It aligns the team around outcomes, not just outputs.
3. Over-Documentation: Turning Stories into Specifications
Another common pitfall is overloading a user story with too many details, turning it into a specification. This happens when teams try to anticipate every edge case in advance.
Example of a bad user story example: “As a user, I want to submit the form with my full name, email, and date of birth, where the email must contain an @ symbol and at least one dot, the name must be between 2 and 50 characters, and the date must be in YYYY-MM-DD format before 1900-01-01 and after 1900-12-31.”
The story is now filled with technical rules and validation logic. It’s not a conversation prompt—it’s a contract. That’s a red flag. The acceptance criteria should be kept simple and open to discussion.
Instead, write: “As a user, I want to submit my personal details so that I can register for the service.” Then, use the acceptance criteria to explore the rules during collaboration.
Keep the story short. Let the details emerge during refinement. A story that tries to define all possible paths is not a story—it’s a specification in disguise.
Checklist: Do You Have a Valid User Story?
Use this checklist to audit your stories during refinement. If more than one item is missing, consider rewriting.
  • Role is real and specific: “As a user” is too vague. “As a new customer in the UK” is more actionable.
  • Action is clear and observable: “I want to save my draft” is better than “I want to store my data.”
  • Value is clear (“so that” clause): The story must answer “Why is this important?”
  • Acceptance criteria are testable: No vague terms like “fast” or “good.” Use measurable outcomes.
  • Story is small enough to estimate: If it takes more than a few days to implement, split it.
When Technical Details Are Needed
Technical context isn’t always bad—just use it in the right place.
Acceptance criteria are where you can include constraints, such as “The login form must be accessible via keyboard navigation.”
But never embed them in the story itself. The story must remain a promise to a conversation. If you’re writing technical rules in the main story, you’re likely confusing implementation with intent.
Use diagrams, models, or acceptance tests to document complex logic. The story stays simple. The discussion happens through collaboration.
Case Study: From Bad to Good
Let’s walk through a real example from a banking app.
Bad user story example:
“As a user, I want to transfer money to another account using my mobile app, where the amount must be greater than 0.01 and less than 100,000, and the destination account must be valid.”
This is a technical specification disguised as a story. The user doesn’t care about limits—they want to send money safely.
Revised user story:
“As a customer, I want to send money to another person so that I can cover a surprise expense quickly and securely.”
Now the team can explore: What’s the fastest way? Is a photo of the recipient needed? Do we need an approval step? The technical limits are now part of the acceptance criteria.
This version invites discussion, not just implementation.
What If I Already Wrote a Bad Story?
Don’t panic. Every team writes flawed stories at some point. The key is to catch them early.
During backlog refinement, ask: “Does this story deliver a real user benefit? Is it small enough to be done in a sprint? What conversation should it trigger?”
If you can’t answer these, rewrite it. The story should never be a dead-end. It should open doors.
What is the biggest user story mistake in Agile teams?
Writing stories from a technical perspective instead of a user’s. Teams often use developer roles or focus on implementation details, which kills collaboration and misses the user’s real need.
How do I fix a user story that’s too technical?
Reframe it around the user, not the job. Replace “As a developer…” with “As a customer…” and add a “so that” clause. Let technical details move to acceptance criteria or diagrams.
Why do bad user story examples persist in backlogs?
Because they’re easy to write and seem complete. But they lack a value statement and invite premature technical decisions. They’re often written without team input, leading to misalignment later.
Can a user story be too short?
Yes—but only if it lacks context. A story like “As a user, I want to log in” is too vague. It should include a goal: “so that I can access my account.” The shorter the story, the clearer the value must be.
Should acceptance criteria be part of the story?
No. The story is the “what.” Acceptance criteria are the “how we know it’s done.” They belong in the acceptance section, not in the story body. Keep the story clean and conversational.
How do I know if my story is small enough?
Ask: “Can this be completed in a single sprint?” If not, break it into smaller stories based on user value. A story should deliver a single, testable outcome that matters to the user.
