Unbalanced Data Flows Between Parent and Child Diagrams
Время чтения: 7 мин. 60 просмотров
One of the most frequent and damaging issues I’ve seen in real-world DFDs isn’t complexity—it’s imbalance. A process in a child diagram that doesn’t match its parent’s input and output flows breaks the logical integrity of the entire model. This isn’t just a notation rule; it’s a foundational principle of systems thinking. When a process appears to create data from nothing or absorb it into a black hole, the diagram fails its primary purpose: to show where data comes from and where it goes.
I’ve reviewed hundreds of DFDs where teams spent hours refining process logic, only to realize the inputs didn’t align with the parent. It’s frustrating, avoidable, and a major source of rework. The good news? There’s a repeatable method to catch and correct this before it becomes a systemic flaw.
This chapter walks you through the core concept of DFD balancing, shows how to detect common imbalance patterns, and gives you a practical, step-by-step checklist to validate every child diagram. We’ll walk through a real-world example where a single missing data flow caused a ripple effect in downstream logic. You’ll learn not just what to fix, but how to think about flows so that every diagram you build holds up under scrutiny.
What Is DFD Balancing?
At its most basic, DFD balancing means ensuring that the data flows entering and leaving a child diagram are identical in number, type, and meaning to the flows associated with its parent process.
Think of it as a financial ledger: if a parent process says, “Receive customer order,” the child diagram must show exactly that input and, at minimum, one output—“Process order” or “Generate invoice.” Any deviation breaks the flow.
Here’s what balancing is not:
  • Not about matching the number of flows exactly. A parent with two inputs might have a child with three outputs—so long as the input pattern is preserved.
  • Not about using the same labels. The same data can be named differently across levels, as long as the meaning is consistent.
  • Not about replicating every detail. Balancing focuses on data movement, not the internal mechanics of how the transformation occurs.
Patterns of Unbalanced Data Flow
Imbalance often appears in three recurring patterns. Recognizing them early saves hours of rework.
1. Missing Input Flows
A child process may show logic that requires data from the parent but omits the input flow. For example, a “Calculate Taxes” process in a purchase flow may never show “Order Total” as input—yet it needs it to function.
Common in: Processes that assume data is “already there” without tracking its origin.
2. Extra or Unexplained Outputs
You see outputs that don’t map to any input in the parent. For instance, a “Generate Report” process might produce “Audit Log” without an input labeled “Transaction Data.” That’s a red flag.
Root cause: Modeling behavior without traceability, leading to “magic” outputs.
3. Changed Data Meaning Across Levels
This is the sneaky one. The same label may refer to different data at different levels. For example, “Customer Info” in the parent might be “Name and Address” in the child, but in the parent, it was also meant to include phone number and email.
Causes: Inconsistent naming, lack of a data dictionary, or overloading terms.
A Repeatable Process for Checking DFD Balance
Here’s the checklist I use with my teams. It takes 5 minutes per child diagram and prevents 90% of balancing errors.
  1. Identify the parent process. Write down all input and output data flows from the parent.
  2. List all flows in the child diagram. Include both inputs and outputs.
  3. Compare input flows. Every input in the child must be traceable to an input in the parent. If not, ask: “Where is this data coming from?”
  4. Compare output flows. Every output in the child must be explainable by an output from the parent. If not, ask: “Why is this data being created?”
  5. Verify the meaning. Use a lightweight data dictionary or cross-reference labels. If “Invoice” means “PDF” in one diagram and “database record” in another, fix the inconsistency.
When in doubt, ask: “Does this flow make sense in the context of the parent process?” If the answer is “no” or “I can’t explain it,” you’ve found an imbalance.
Worked Example: Fixing a Real-World Imbalance
Consider a Level 0 DFD for an Order Processing System with a single process: “Process Customer Order.” It has two inputs: “Customer Order” and “Inventory Status,” and one output: “Order Confirmation.”
Now, the child diagram for “Process Customer Order” shows:
  • Input: “Customer Order”
  • Input: “Inventory Status”
  • Output: “Order Confirmation”
  • Output: “Backorder List”
Problem: The “Backorder List” output does not exist in the parent. It’s an extra flow.
Root Cause: The team assumed that if inventory is low, a backorder list must be generated—but they never defined it in the parent, so the flow isn’t validated.
Fix: Either add “Backorder List” to the parent output, or reframe the child process to generate it only if inventory is low, and tie it back to a parent decision point.
After correction, the child diagram now shows:
  • Inputs: “Customer Order,” “Inventory Status”
  • Outputs: “Order Confirmation,” “Backorder List”
Now, both the parent and child outputs match. The child process is balanced.
This is the kind of error that, if missed, leads to testing gaps, integration surprises, and confused developers. Catching it early is not just good practice—it’s essential.
Best Practices for Preventing DFD Imbalance
Here’s how to keep your diagrams balanced from the start:
  • Use a data dictionary. Define every data flow once, and reuse the definition across levels. This prevents ambiguity.
  • Always link flows to their source. When a flow appears, ask: “Where does it come from?”
  • Review at the level of the parent process. Never validate a child diagram in isolation.
  • Run peer reviews focused on balancing. Ask: “Does every output have a reason? Does every input have a source?”
Remember: a perfectly drawn diagram is useless if it doesn’t reflect reality. Balancing isn’t about aesthetics—it’s about truth.
What does “checking DFD balance” actually mean?
It means verifying that all data flows in a child diagram are either inputs from the parent, outputs generated by the parent, or logically derived from the parent’s flows. The core idea is traceability: every flow must have a valid origin and destination.
Can a child diagram have more outputs than the parent process?
Yes—but only if those outputs are logically derived from the parent’s outputs or inputs. For example, a parent outputting “Customer Order” can have a child process generating both “Order Confirmation” and “Audit Log.” The key is that the child’s outputs must be explainable by the parent’s data.
Is it okay to rename data flows in child diagrams?
Yes, but only if the meaning is preserved. For example, renaming “Customer Info” to “Personal Details” is acceptable if both refer to the same data. However, such changes must be documented in a data dictionary to avoid confusion.
What if the parent process has no output, but the child does?
This violates DFD principles. Every process must transform data, and transformation requires both input and output. If a child process produces output without a parent output, the parent process must be updated to reflect that output.
How do I handle a process that splits one input into multiple outputs?
That’s fine—this is a common and valid pattern. The key is ensuring that the original input is fully accounted for. For example, “Process Order” may split “Customer Order” into “Order Confirmation,” “Payment Request,” and “Inventory Check.” This is valid as long as the parent process shows all three outputs.
Should I balance every child diagram, even small ones?
Yes. Even minor diagrams can introduce errors that compound across levels. A small imbalance in a Level 2 process can cascade into systemic data loss or incorrect processing downstream. Consistency at every level is non-negotiable.
Final Note: Unbalanced data flow diagram issues aren’t signs of poor analysis—they’re symptoms of incomplete traceability. Fixing them isn’t about being stricter; it’s about being more precise. When you master DFD balancing, you’re not just drawing diagrams—you’re building systems that work.
