No Logical Progression Between DFD Levels
Время чтения: 7 мин. 66 просмотров
Imagine a system where a user submits a form, and the data flows through a series of steps. On the Level 0 DFD, you see one process: “Process Order.” At Level 1, you expect to see a breakdown of that single step—validating inputs, checking inventory, and creating a record. But what if Level 1 shows “Send Email,” “Update Dashboard,” and “Log Error”—none of which are part of the original order process?
This mismatch is a classic symptom of poor DFD level progression. The decomposition doesn’t reflect the parent process; instead, it introduces unrelated actions. This breaks the logical flow and makes the model unreliable for analysis, design, or communication.
Over 20 years guiding teams through complex data modeling, I’ve seen this repeated across industries—finance, logistics, healthcare—where a misaligned decomposition leads to misdirected development, missed data requirements, and stakeholder confusion. The fix isn’t about better tools. It’s about disciplined, traceable DFD decomposition.
This chapter walks you through what a proper progression from Level 0 to Level 1 should look like, how to identify flawed decompositions, and a tested technique to verify that every process on a parent diagram is fully and correctly decomposed.
What a Proper DFD Level Progression Should Look Like
Every process on a higher-level DFD must be decomposed into child processes that refine, not replace, its function. The child diagram should explain how the parent process actually works—without introducing new, unrelated responsibilities.
Consider the Level 0 process: “Process Order”. This is a high-level abstraction. The correct decomposition at Level 1 should reveal the internal logic—what actually happens when an order is processed.
Here’s how it should look:
  • Validate Order Inputs – Check if all required fields are present and conform to format.
  • Check Inventory Availability – Query stock levels for each item.
  • Create Order Record – Store the order in the database with status “Pending”.
  • Trigger Payment Processing – Pass order data to the payment module.
Each of these child processes directly contributes to the outcome of “Process Order.” There are no gaps, no magic, no side effects. This is clean DFD decomposition alignment.
Now contrast it with a common trap:
  • Update Customer Dashboard
  • Send Confirmation Email
  • Log Error (if any)
  • Process Order (repeated as a sub-process)
Here, “Update Customer Dashboard” and “Send Confirmation Email” are not part of order processing—they are follow-up actions, often part of a different process like “Notify Customer.” Introducing them here breaks the parent-child DFD relationship.
How to Catch Misaligned Decompositions
Don’t rely on intuition. Use a structured cross-check method to ensure that every process in a parent diagram is properly decomposed.
Here’s a simple, field-tested technique I’ve used in audits and design reviews:
  1. List all processes on the parent diagram—no exceptions. For Level 0, this is often just 1–3 processes.
  2. For each process, go to its corresponding child diagram (e.g., Level 1 for Level 0).
  3. Verify that every function in the parent process is represented by one or more processes in the child.
  4. Check for orphans—any processes in the child that have no traceable link to the parent.
  5. Confirm no new responsibilities appear in the child that weren’t implied in the parent.
This is not just about matching names. It’s about functional coherence. If the parent says “Process Order,” the child should break down what that process actually does—not what happens after.
Example: Correct vs Incorrect DFD Level Progression
Let’s compare two Level 1 views of “Process Order.”
Parent Process Correct Child Processes (Aligned) Incorrect Child Processes (Misaligned)
Process Order Validate Inputs
Check Inventory
Create Order Record
Trigger Payment
Send Email
Update Dashboard
Log Error
Process Order
Process Order ✔ All functions are parts of order processing ✖ Email and dashboard updates are external to order processing
The second example introduces processes that are not decomposition steps—they are side effects. This breaks the DFD decomposition alignment principle and creates a misleading model.
Why Some Decompositions Fail
Even when teams mean well, certain patterns undermine DFD level progression:
  • Confusing action verbs – Using “Update” or “Send” as process names often indicates that the process is about side effects, not data transformation.
  • Introducing external actors too early – If a child diagram shows “Send Email to Customer,” but the parent process doesn’t mention customers, the flow is disconnected.
  • Splitting unrelated functions – Breaking “Process Order” into “Create Record” and “Notify Customer” without a shared context creates two independent processes.
  • Reusing a process name – “Process Order” used in a different context (e.g., a reporting process) can cause confusion if not clearly separated.
These are not trivial. They create a fragmented mental model. When stakeholders see different meanings for the same process name, trust in the DFD erodes.
Practical Tips to Maintain Logical Progression
Here’s how to keep your DFDs aligned and meaningful:
  1. Use process names that reflect transformation – Replace “Send Email” with “Generate and Dispatch Confirmation.” The verb should describe data change.
  2. Define a process contract – For each process, write a short statement: “This process transforms input X into output Y.” If you can’t, the process may be too broad or misaligned.
  3. Apply the “So what?” test – Ask: “Why does this process exist?” If the answer isn’t tied to the parent process’s purpose, reconsider its place.
  4. Map each child process back to the parent – Use a simple traceability table to track which parent process each child contributes to.
  5. Use modeling tools with validation – Diagrams in Visual Paradigm or similar can flag orphan processes or missing flows during review.
These practices aren’t just about correctness—they’re about creating a model that people can actually use. A DFD with proper linking level 0 and level 1 DFD relationships becomes a living guide, not a static diagram.
What happens if I decompose a process but miss a key function?
Missing functions create blind spots. In development, that function might be forgotten, leading to bugs or data loss. In audits, the flow appears incomplete. Always cross-check child processes against the parent’s purpose.
Can a parent process have multiple child diagrams?
Yes—but only if they represent different logical parts of the same process. For example, “Process Order” might have one child diagram for validation and another for payment processing. Ensure the decomposition is cohesive, not scattered.
Is it okay to have a child process that doesn’t directly feed into the parent?
No. Every child process must be functionally part of achieving the parent’s outcome. If it’s not, it’s either a separate process or an orphan—both of which break DFD integrity.
How do I know when decomposition is complete?
When all child processes are small enough to be easily testable and maintainable. A rule of thumb: if a process does more than one clear transformation (e.g., “validate,” “calculate,” “store”), it should be split.
Do I need to decompose every process in a DFD?
Only if it’s complex or critical. For low-risk processes, a high-level description may suffice. But if the process affects data integrity, compliance, or performance, decomposition is essential. Use risk-based judgment.
Can a single process at Level 0 map to multiple processes at Level 1?
Yes—this is normal and expected. A complex process must be broken into logical steps. The key is that each step must contribute directly to the outcome of the parent process. No side effects.
