Over-Decomposition: When Every Step Becomes a Process
Время чтения: 8 мин. 56 просмотров
“I just broke it down into smaller parts—this way, it’s easier to understand.” That’s the most common phrase I hear from analysts in their first few months of DFD work. And it’s almost always the first sign of trouble.
Over-decomposition turns a single functional unit into a chain of micro-processes, each handling a minor action. The result? A diagram that reads like a procedural script, not a model of data movement.
Let me be clear: decomposing a process is essential. But doing so without purpose or structure leads to noise, confusion, and a loss of meaning. The goal isn’t more processes. It’s better clarity.
This chapter will help you recognize DFD over decomposition patterns, understand when a step deserves its own process, and apply practical refactoring techniques to restore logical integrity. I’ve seen teams spend weeks on a Level 1 diagram full of 20+ processes—only to realize they were modeling a single workflow. Let’s fix that.
What Is DFD Over Decomposition?
DFD over decomposition occurs when unnecessary granularity breaks a single logical function into multiple small, low-level processes. These are often “micro processes” that perform atomic actions—like “validate customer ID” or “format date”—but don’t represent meaningful transformations.
The danger isn’t just visual clutter. Over-decomposition hides the system’s real function. A process labeled “Send confirmation email” might be split into “Retrieve email template,” “Insert customer name,” “Generate timestamp,” and “Send via SMTP.” Each is technically valid—but now you’ve lost the narrative.
Think of it like this: a car repair manual shouldn’t break “change the oil” into “remove dipstick,” “check oil level,” “unscrew oil cap,” “drain oil,” and “replace cap.” That’s not precision. That’s noise.
Signs of Over-Decomposition
  • More than 6–8 processes on a Level 1 diagram.
  • Processes with only one input and one output, doing minimal transformation.
  • Processes named with verbs like “check,” “format,” “validate,” or “send” as the primary action.
  • Processes that don’t change the data’s structure or meaning—just reorganize or repackage it.
  • Diagrams that require a flowchart or script to understand the intended logic.
When Does a Step Need Its Own Process?
Not every small action deserves its own DFD process. The key is functional significance—does this action represent a meaningful transformation of data, or just a procedural detail?
Here’s my rule of thumb: if the process can be removed without changing the data’s purpose, it doesn’t belong at the process level. Instead, it should be part of a larger process or handled in documentation.
Decision Criteria for Decomposition
  1. Does it transform data in a non-trivial way? For example: “Convert pounds to kilograms” is a valid transformation. “Convert to string” isn’t—unless it’s part of a larger logic like “format for export.”
  2. Does it involve a decision or branching? If a process contains conditional logic (e.g., “if payment approved”), it should be a standalone process. But if it’s just “check if field is empty,” it may belong inside another process.
  3. Does it involve a distinct business rule or policy? For example: “Apply discount based on customer tier” is a function. “Check customer tier” is not—unless the tier affects the next step.
  4. Is it a system-level operation or a technical task? “Write to database” or “call external API” should be modeled at the technical level, but not as a process in a logical DFD unless it changes data meaning.
Ask: “Would removing this process alter the outcome of the data flow?” If no—don’t make it a process.
Case Study: Refactoring a Micro Process DFD Issue
Let’s walk through a real example from a retail system.
Before: Over-Decomposed Diagram
Here’s the original Level 1 DFD for “Process Order”: 12 processes, all under 100 characters long. Each handles a single data manipulation:
  • Retrieve order ID
  • Validate customer ID
  • Check stock availability
  • Format order date
  • Calculate subtotal
  • Apply tax
  • Apply discount
  • Calculate total
  • Generate invoice number
  • Store in database
  • Send confirmation email
  • Log transaction
Each has one input and one output. The data flows are trivial: “order data” → “valid order.” The narrative is lost. Stakeholders can’t see the real function—just a list of tasks.
After: Function-Oriented Refactoring
I restructured it into four core processes:
  1. Validate and Prepare Order: checks customer, stock, and formats data.
  2. Calculate and Apply Pricing: computes subtotal, tax, discount, and total.
  3. Generate and Store Invoice: creates invoice, assigns ID, saves to database.
  4. Notify and Log: sends confirmation and records transaction.
The new diagram is cleaner, more readable, and reflects actual business logic. Each process now represents a distinct phase in the order lifecycle.
And the data flows? Still balanced. The model is now easier to test, audit, and extend.
How to Simplify Over-Detailed DFDs: A Step-by-Step Guide
When you spot a DFD with too many processes, follow this process to simplify and clarify:
  1. Identify the main function: What is the process supposed to do? (e.g., “Process customer order”)
  2. Group by phase or purpose: Cluster steps into logical phases (e.g., validation, calculation, storage, notification).
  3. Ask: What changes the data?: Remove processes that only reformat or repackage—move them to notes or documentation.
  4. Reassign inputs and outputs: Ensure each new process has a clear transformation. If not, merge or remove it.
  5. Verify balance: Cross-check that all original data flows are preserved in the new structure.
  6. Document assumptions: Add a brief note explaining why certain steps are internal to a process.
Use this checklist during reviews:
  • Are all processes performing a meaningful transformation of data?
  • Could any process be merged without losing clarity?
  • Is the diagram readable at a glance?
  • Would a new analyst understand the system without reading a script?
Even experienced analysts fall into these traps. Here’s how to avoid them:
  • Confusing procedural steps with process functions: Just because you do something in sequence doesn’t mean it’s a process. Sequence is for flowcharts. DFDs are about transformation.
  • Modeling technical implementation details: “Call API,” “Write to file,” “Retry on failure” belong in technical documentation, not logical DFDs.
  • Overusing passive verbs: Avoid “is validated,” “is formatted,” “is sent.” Use active verbs: “validate,” “format,” “send.”
  • Forgetting that DFDs are about intent, not execution: A DFD should answer: “What happens to the data?” not “How does it happen?”
When in doubt, ask: “If this process were removed, would the data still be usable?” If yes, it’s likely not a process.
Why Simpler Is Better: The Benefits of Proper Decomposition
Well-structured DFDs are not just cleaner—they’re more powerful.
  • Better communication: Stakeholders grasp the system’s function quickly.
  • Easier testing: Each process can be tested as a black box.
  • Improved maintainability: Changes to a single function don’t require reworking the entire diagram.
  • Clearer risk identification: Critical steps are visible, not buried in a list.
Think of it like a map: too many roads make it hard to find the route. Too few, and you miss the exits. The right number of processes shows the path clearly.
How many processes is too many on a DFD level?
Generally, more than 8 processes on a single Level 1 diagram indicates over-decomposition. If you find yourself needing to label processes with numbers like “1.1.3,” consider grouping them into higher-level functions.
Can I use a flowchart instead of a DFD for detailed workflows?
Yes—use flowcharts for control logic, decision paths, or procedural steps. DFDs should focus on data transformation, not process flow. Use both, but keep them separate.
What should I do if a stakeholder insists on splitting every action into a process?
Explain that DFDs model data movement, not task lists. Show them the difference between a logical model and a procedural script. Use a before-and-after example to demonstrate clarity and maintainability gains.
Is it okay to have a process with no inputs but only outputs?
No—every process must have at least one input. If a process generates data from nothing, it should be a data store or external entity. A process must transform input data into output data.
How do I handle validation steps like “check if email is valid”?
Don’t make it a process. Instead, include it as a condition or constraint in the parent process. For example: “Validate customer contact details (email, phone).” Validation is part of the data preparation step.
When should I break a process into sub-processes instead of merging?
Break it down when the function is complex, involves multiple data types, or is prone to errors. But always ask: “Does this breakdown improve understanding, or just add noise?” If the answer is the latter, keep it as one.
Remember: the goal of DFD modeling is not to list every action. It’s to reveal the system’s logic with clarity, precision, and purpose. Over-decomposition defeats that goal. Stay focused on transformation, not transaction.
