Too Many Processes on One Diagram Without Decomposition
Время чтения: 6 мин. 65 просмотров
When a DFD has more than six or seven processes, it’s usually too complex to be useful. I tell teams: “If you can’t explain the flow in under a minute, you’ve got too many processes.” That’s the rule I’ve lived by for over two decades.
Too many DFD processes hide logic, obscure decisions, and make reviews nearly impossible. I’ve seen diagrams with 15+ processes that looked like tangled circuit boards. No one could trace a data flow without losing context.
This chapter walks through real-world strategies to identify when a diagram is overloaded, how to split it effectively, and what to do with the resulting sub-diagrams. You’ll learn how to apply DFD process count guidelines and decomposing large DFDs with confidence.
When a DFD Becomes Unmanageable
The Reality of Overloaded Diagrams
Most DFDs start small—three to five processes. But as requirements grow, analysts often just add more processes instead of decomposing.
Consider a process labeled “Handle Customer Order Workflow.” It might contain steps like “Validate order,” “Check inventory,” “Apply discount,” “Generate invoice,” “Send confirmation.” Each step is a potential process—but if they’re all on one diagram, you’re in trouble.
When you see more than seven processes on a single Level 1 diagram, pause. You’re past the point of readability. This isn’t about rigid rules—it’s about cognitive load.
Heuristics for DFD Process Count Guidelines
Here are the practical thresholds I use in real projects:
  • Level 0 (Context): 1 process + 3–5 external entities. More than that and you’re not modeling a system—you’re listing everything.
  • Level 1: 3 to 7 processes. This is your sweet spot. More than 7 and you’re asking for trouble.
  • Level 2+: 2 to 5 processes per child diagram. Larger processes are acceptable only if they’re well-contained.
These aren’t hard limits. They’re guardrails. If a process is doing more than one clear transformation and can be explained in one action, it might be fine. But if it has multiple inputs, decisions, or data stores, it’s begging to be split.
How to Split Complex DFD Diagrams: A Step-by-Step Approach
Step 1: Identify the Core Processes
Start by reviewing the diagram. Circle processes that handle a single responsibility—say, “Calculate Tax,” “Validate Customer,” or “Send Email.” These are your candidates for keeping.
Then highlight processes that do multiple things. “Process Order” might be a red flag—it’s likely doing validation, routing, and notification. That’s a prime candidate for decomposition.
Step 2: Group by Subsystem or Workflow Phase
Ask: “What’s the natural boundary here?” Is there a logical grouping?
For example, in an order processing system, you might split into:
  • Order Validation
  • Inventory Reservation
  • Pricing and Discounting
  • Invoicing and Payment Processing
Each becomes a child diagram under the parent “Process Order” process. This is how you decompose large DFDs into manageable pieces.
Step 3: Rebuild Inputs and Outputs
For every child diagram, ensure its inputs and outputs match the parent’s flow.
For example, if the parent process “Process Order” sends “Validated Order” to “Inventory Reservation,” that flow must appear as an input in the child diagram.
Check that no new data flows appear or disappear without explanation. This is the heart of DFD balancing—and a key step in splitting complex DFD diagrams.
Step 4: Use Consistent Numbering and Naming
Use a hierarchical numbering scheme:
  • Parent: 1.0
  • Child 1: 1.1
  • Child 2: 1.2
  • Grandchild: 1.1.1
Never skip numbers. Never use names like “Process A” or “Step 1.” Be specific: “Validate Order Data,” “Reserve Inventory,” etc.
Before and After: A Real-World Example
Before: A Monolithic Level 1 Diagram
A retail system’s Level 1 DFD had 12 processes:
  • Receive Order
  • Validate Customer
  • Check Inventory
  • Apply Discount
  • Generate Invoice
  • Send Email
  • Update Warehouse
  • Log Transaction
  • Notify Accounting
  • Check Payment
  • Update Customer Status
  • Update Order Status
The diagram was cluttered. Flows crossed over each other. Reviewers gave up after five minutes.
After: Decomposed into Four Child Diagrams
Split into:
  • 1.1 Order Validation: Validates data, checks customer status. Inputs: Order data. Output: Validated order.
  • 1.2 Inventory Management: Checks stock, reserves items. Inputs: Validated order. Output: Reserved inventory.
  • 1.3 Pricing and Billing: Applies discount, calculates tax, generates invoice. Inputs: Reserved inventory, order data. Output: Invoice.
  • 1.4 Payment and Fulfillment: Accepts payment, updates systems. Inputs: Invoice, payment confirmation. Output: Order fulfilled.
Now each child diagram has 3–5 processes. Traces are clear. Stakeholders can review them independently.
When to Split — And When to Keep It Together
Use Cases Where Splitting Is Critical
  • Any Level 1 DFD with more than 7 processes.
  • A process with more than 3 input flows or 3 output flows.
  • Processes involving multiple data stores, especially across different domains.
  • Diagram uses more than 3 colors or 10 annotations to explain what’s happening.
When You Might Not Need to Split
  • When all processes are tightly coupled and share the same data flow path.
  • For high-level executive views where brevity is more important than detail.
  • When the system is small and the entire model fits on one page.
But if you’re writing for developers, testers, or system designers—split it. Clarity trumps brevity.
Best Practices for Maintaining DFD Health
  • Review after every major change: If you add more than 3 processes, reassess whether decomposition is needed.
  • Use modeling tools with hierarchy support: Visual Paradigm can help visualize and manage child diagrams.
  • Document your decomposing logic: Add a short note: “Split to clarify risk areas: payment, inventory, and billing.”
  • Link diagrams with traceability: Use cross-references: “See 1.2 for inventory tracking.”
Decomposing large DFDs isn’t just about aesthetics. It’s about making logic visible, testable, and shareable.
What’s the maximum number of DFD processes I should allow?
For Level 1 diagrams, aim for 3–7 processes. Exceeding 7 is a red flag. Use decomposition if you’re near or above 8.
Can I keep a DFD with 10 processes if it’s well laid out?
Not really. A clean layout helps, but cognitive load still increases. Even well-organized diagrams with more than 7 processes become hard to review or verify.
How do I decide which process to split first?
Start with the most complex one—highest number of inputs, outputs, and data stores. Or the one that’s most likely to change.
Do I need to decompose every process?
No. Only decompose those that are ambiguous, involve multiple data stores, or contain complex logic. Not every process needs a child diagram.
What if my team resists splitting diagrams?
Run a side-by-side review. Show the cluttered version and the decomposed one. Let stakeholders compare how long it takes to understand each. Use real project examples: “This bug came from a missing flow we missed because the diagram was too busy.”
How do I keep track of all the child diagrams?
Use a simple model index. List each child diagram with its purpose and parent process. In tools like Visual Paradigm, use a “Diagram Hierarchy” view to navigate. Keep a one-page summary for each main process.
