How to Validate Balanced Data Inputs and Outputs
Время чтения: 7 мин. 52 просмотров
In three different banking system projects last year, I found the same issue: a Level 1 process showed a data flow in, but the corresponding Level 2 diagram had no incoming flow from the parent. The root cause? A failure to validate DFD balance. This isn’t just a technical oversight—it’s a breakdown in system integrity.
As someone who’s built and audited DFDs for over two decades, I’ve learned that balancing isn’t a one-time task. It’s a continuous discipline. The most common mistake? Assuming consistency happens automatically when you decompose a process.
This chapter gives you a clear, field-tested method to check DFD consistency across levels. You’ll learn how to inspect inputs and outputs systematically, using real-world patterns and a step-by-step checklist. This is not theory—it’s what works in actual projects.
Step 1: Map Parent and Child Diagrams Side-by-Side
Start by placing the parent diagram and its child diagram adjacent to each other. Use a digital tool or large paper layout to ensure visibility.
Focus on the process being decomposed. Every input and output in the parent must either appear directly in the child, or be accounted for through other flows.
This is the foundation. If you skip this step, you risk missing a flow that’s embedded in multiple child processes.
Step 2: List Inputs and Outputs in the Parent Process
Write down all incoming and outgoing data flows from the parent process. Be precise: use the same data names as in your data dictionary.
For example, if the parent process «Process Payment» takes in «Payment Request» and outputs «Payment Confirmation,» list each exactly as defined.
Do not assume that a flow like «Payment Details» is the same as «Payment Request.» If they’re not in your data dictionary, you’re working with ambiguity—this is where validation fails.
Step 3: Verify Each Flow in the Child Diagram
Now go through each flow listed in the parent. Check whether it appears in the child diagram.
If the flow is incoming, ensure it either:
  • Enters a process in the child diagram directly.
  • Originates from a data store that’s part of the child.
  • Is generated by another process in the child that then passes it on.
If the flow is outgoing, confirm it:
  • Leaves a process in the child.
  • Enters an external entity, data store, or another process.
  • Is the result of a transformation or aggregation of data from multiple flows.
Remember: a flow can be split across multiple processes. But if the parent shows «Payment Confirmation» as an output, the child must show how it’s produced.
Step 4: Identify Discrepancies Using a Comparison Table
Use a table to summarize your findings. This makes discrepancies easy to spot.
Data Flow Parent Level Child Level: Present? Status
Payment Request Input Yes, from Customer Valid
Payment Confirmation Output No direct flow Invalid
Transaction Log Output Yes, stored in Data Store Valid
Any «No» or «Not found» indicates a gap. This is a red flag in your DFD validation process.
Common Flow Mismatches to Watch For
Discrepancies often stem from subtle mismatches. Be alert to:
  • Flow names that differ by only one word (e.g., «Payment Confirmation» vs. «Confirmation of Payment»).
  • Flows that are implied but not explicitly drawn.
  • Flows that are created in the child but not documented in the parent.
These small differences compound across levels. If you don’t validate DFD balance early, you’ll waste weeks debugging logic errors later.
Step 5: Resolve Gaps with a Traceability Log
When a flow is missing, create a traceability log. Ask:
  • Where does this data come from in the child?
  • How is it transformed?
  • Which process generates it?
Document the answer. Then update either the parent or child diagram to reflect the truth.
If the child process generates a flow not in the parent, you’ve likely over-decomposed. The parent must reflect all valid outputs.
Conversely, if a flow appears in the parent but not the child, you may have under-decomposed. Re-examine the child for hidden processes.
Step 6: Run a Final Cross-Level Audit
After all adjustments, run a final audit using a checklist:
  1. Every input in the parent must appear in the child (directly or via transformation).
  2. Every output in the parent must be produced by the child processes.
  3. No new flows appear in the child without a source or logical explanation.
  4. All flows use consistent naming and are defined in the data dictionary.
  5. External entities and data stores are properly referenced.
Run this checklist for every decomposed process. Even one unverified flow can invalidate the entire model.
Real-World Example: Payment Processing Flow
Consider a bank’s «Process Payment» flow. The Level 1 diagram shows:
  • Input: Payment Request (from Customer)
  • Output: Payment Confirmation (to Customer)
But in Level 2, the processes are:
  • Validate Request → Store in Temp Queue
  • Check Funds → Send Approval
  • Update Account → Send Summary
Now ask: Where is «Payment Confirmation»? It’s not a single flow—it’s a combination of «Approval» and «Summary.» This is acceptable. But the output must be explicit: «Payment Confirmation» must be the result of a process that aggregates these flows.
If the child doesn’t produce a flow named «Payment Confirmation,» you must either:
  • Re-name the output to match the parent.
  • Or add a final process that combines the data into a single confirmation.
This ensures the DFD validation passes. It’s not about matching exactly—it’s about logical consistency.
Why This Matters: The Cost of Ignoring DFD Consistency
When data flows are unbalanced, you risk:
  • Incorrect system behavior in development.
  • Missing requirements in user stories.
  • Compliance failures during audits.
  • Confusion in stakeholder communication.
One client lost 40 hours of rework because a payment flow was split incorrectly between Level 1 and Level 2. The root cause? No DFD validation process was in place.
That’s why checking DFD consistency isn’t optional. It’s a quality gate.
Can I validate DFD balance without a data dictionary?
No. A data dictionary ensures consistent naming and definitions. Without it, you can’t verify whether flows are truly the same. I’ve seen teams waste days on “missing” flows that were just named differently.
What if a flow appears in multiple child processes?
This is allowed if each process contributes to the same output. But the flow must be traceable. For example, «Transaction Details» might come from «Validate Request» and «Check Funds,» then be combined in «Generate Confirmation.» The parent must still show it as a single output.
Do I need to validate every single flow in a large system?
Yes. Even a single unbalanced flow can lead to data loss or logic errors. Prioritize high-risk areas—like financial processing or regulatory reporting—but never skip validation.
Can DFD validation be automated?
Yes. Tools like Visual Paradigm can flag flows that don’t appear in child diagrams. But automation can’t catch semantic mismatches (e.g., «Payment Request» vs. «Request for Payment»). Always review automation results manually.
What if the parent flow is a composite, but the child doesn’t produce it?
Then the child is incomplete. You must break down the composite flow into its components. Or, if it’s a summary output, add a process to aggregate the data. The child must produce the same data structure as the parent.
Should I validate DFD balance before or after stakeholder review?
Before. If you present a model with unbalanced flows, stakeholders will question the entire system. Fix inconsistencies early to maintain credibility and trust.
