Building a Complete Multi-Level DFD: Guided Exercise
Время чтения: 7 мин. 69 просмотров
Most analysts start with a context diagram and jump to Level 1. That’s efficient—but risky. In the field, I’ve seen teams lose months rebuilding because a missing data store in Level 1 broke the entire chain. The real key isn’t just decomposition, but consistency. Starting with the top-down structure ensures every layer reflects the same data logic.
This chapter walks you through a real-world scenario: a university’s course enrollment system. We’ll build a Level 0 (context), Level 1 (high-level processes), and Level 2 (atomic functions), making every data flow traceable and balanced.
You’ll gain hands-on experience in DFD balancing, data store management, and process decomposition—skills that separate competent analysts from those who just draw diagrams.
Step 1: Define the System Scope and External Entities
Begin with the system boundary. Ask: Who or what interacts with this system?
For our university enrollment system:
  • Student – registers for courses, views schedules.
  • Faculty Member – inputs grades, views class lists.
  • Registrar Office – manages course offerings and capacity.
These entities are critical. Any data flow to or from them must be clearly defined in the context diagram.
Pro Tip: Use the «Who Sends or Receives?» Rule
Every data flow must originate from or terminate at an external entity. If a flow appears without one, it’s a red flag—either a missing entity or an internal loop that violates the DFD model.
Step 2: Build the Level 0 Diagram (Context Diagram)
Level 0 is a single process: the entire system. It shows only the main data flows between the system and external entities.
Here’s the core flow:
  • Student → System: Course Registration Request
  • System → Student: Confirmation & Schedule
  • Registrar → System: Course Offerings & Capacity
  • System → Registrar: Enrollment Report
  • Faculty → System: Grade Submission
  • System → Faculty: Class List
At this stage, focus on clarity and completeness. Avoid naming the process “Enrollment System” — use a verb-noun format: “Process Enrollment.”
Check for Balance: Level 0 Inputs and Outputs
Before moving to Level 1, verify that all inputs and outputs in Level 0 are fully accounted for in the next level. If a flow is not decomposed, your model is incomplete.
Now that we’ve defined the context, we’re ready to decompose.
Step 3: Decompose into Level 1 – High-Level Processes
Level 1 breaks the single process into 3–6 major functions. Use the input-process-output rule: each process must transform input data into output data.
For the enrollment system, we define these top-level processes:
  1. Register Student for Course
  2. Manage Course Availability
  3. Submit and Process Grades
  4. Generate Enrollment Reports
Key Principle: No New Flows
Every data flow in Level 1 must come from or go to a Level 0 flow. If a new flow appears, you’ve violated the leveling rule. That means the process isn’t properly connected to the original system scope.
Let’s check:
Level 0 Flow Level 1 Process Replaces?
Course Registration Request Register Student for Course Yes
Enrollment Report Generate Enrollment Reports Yes
Grade Submission Submit and Process Grades Yes
Each Level 0 flow is now accounted for. Good.
Step 4: Decompose Level 1 into Level 2 – Atomic Processes
Now, drill down into each Level 1 process. The goal is atomicity: no further decomposition should be possible without losing meaning.
Process 1: Register Student for Course
  • Check Course Availability – query data store: Course Schedule
  • Verify Student Eligibility – check academic record, prerequisites
  • Allocate Seat – update Course Schedule, create Enrollment Record
  • Send Confirmation – email or portal notification
Each step is atomic. No further breakdown is needed.
Process 2: Manage Course Availability
  • Update Course Offering – add new course, modify schedule
  • Set Capacity Limits – define max students per section
  • Notify Registrar – send updated course list
Notice how the data store “Course Schedule” is shared across processes. This is essential for consistency.
Process 3: Submit and Process Grades
  • Receive Grade Submission – from faculty
  • Validate Grade Format – check codes: A, B, F, etc.
  • Store Grade in Student Record – update Grade Database
  • Send Grade Notification – to student and advisor
Each process must have at least one input and one output. If not, it’s incomplete.
Process 4: Generate Enrollment Reports
  • Extract Enrollment Data – from Enrollment Records
  • Aggregate by Course/Section – count students, identify over-enrollment
  • Format and Export Report – PDF or CSV for Registrar
These processes are now fully decomposed. You’ve achieved Level 2.
Step 5: Perform DFD Balancing – The Critical Step
Leveling only works if data flows match across levels. This is balancing. If a flow appears in Level 1 but not in its parent Level 0, or vice versa, you’ve made a structural error.
Here’s how to verify:
  • Every input to a Level 1 process must come from either a Level 0 flow or a data store.
  • Every output from a Level 1 process must be a Level 0 flow or go to a data store.
  • No data flows should be created or lost between levels.
Example: The «Check Course Availability» Process
Input: Course Schedule (data store) – OK, valid.
Output: Course Availability Status – this flow must be traceable to Level 0.
But in Level 0, we only had “Course Registration Request.” No mention of availability status. So we must ask: is this output meant to be sent back to the student?
Yes. So we must update Level 0: add “Course Availability Check” as a new flow from the system to the student.
This is how balancing reveals hidden requirements.
Final Balancing Checklist
Before finalizing, use this checklist:
  • Are all Level 1 inputs covered by Level 0 or data stores?
  • Are all Level 1 outputs traceable to Level 0 or data stores?
  • Has any data flow been added or removed between levels?
  • Are data stores consistently named across all levels?
  • Do all process names follow verb-noun format?
Passing this checklist means your model is balanced. If not, go back and fix the flow discrepancies.
Why This Matters in Real Projects
I once worked on a hospital system where Level 2 processes didn’t align with Level 1. A data flow to “Patient Records” was missing from Level 1, yet it existed in Level 2. The result? A critical data gap. The system failed audit because it couldn’t trace patient data across layers.
That’s why DFD tutorial isn’t just about drawing diagrams. It’s about validation. Each level must stand on its own, yet remain connected.
Now that you’ve built a full model, you’ve completed a true multi-level DFD practice exercise. You’ve seen how proper decomposition and balancing ensure system integrity.
Can I skip Level 0 and go straight to Level 1?
No. Level 0 defines the system boundary and scope. Skipping it leads to off-model flows and boundary confusion. Always start with the context diagram.
How many processes are too many in Level 1?
More than 6 processes usually indicate over-decomposition. If you’re at 7 or more, re-evaluate whether any processes can be grouped or simplified. Aim for 3–5.
What if my Level 2 processes don’t match the data flows in Level 1?
That’s a red flag. Recheck the inputs and outputs. If a flow is missing, your decomposition is incomplete. Use the balancing checklist to fix it.
Should I use the same data store names across all levels?
Yes. Consistent naming is essential. For example, “Student Record” in Level 1 must be “Student Record” in Level 2. Name changes break traceability.
Is DFD balancing required for all diagrams?
Yes. Balancing ensures the model is logically sound. Even if you’re using a tool like Visual Paradigm, manual review is essential. Automation helps, but doesn’t replace judgment.
Can I reuse the same process name in multiple levels?
No. Each process must be unique within its level. You can have “Register Student” in Level 1 and “Register Student for Course” in Level 2, but not the same name in two levels.
Now you’re ready to apply this DFD practical exercise to your own projects. Practice with different domains—e-commerce, payroll, inventory—to master the balance between clarity and completeness.
