Principles of Process Decomposition
Время чтения: 7 мин. 67 просмотров
Most modeling teams waste hours chasing inconsistencies because they treat process decomposition as a mechanical task—breaking down a system into smaller parts without first clarifying intent. The real issue isn’t complexity; it’s ambiguity in purpose. I’ve seen teams decompose a single “Process 3” into seven sub-processes, only to discover that none of them actually produce a distinct output or satisfy a clear input requirement. That’s not decomposition—it’s over-engineering.
The shift that eliminates this waste is simple: think in terms of **functional decomposition**, not just structural breakdown. Every sub-process must answer one question: what unique transformation does it perform on its inputs to generate a measurable output? If it can’t, it either isn’t a process, or it’s part of a larger function that needs redefining. This mindset is the foundation of accurate DFD modeling.
This chapter teaches you how to apply this principle with precision. You’ll learn how to identify processes that are truly atomic, how to define unambiguous input-output relationships, and how to avoid the common pitfalls of over-decomposition and under-decomposition. By the end, you’ll have a reliable, repeatable method for breaking down complex systems—without losing traceability or introducing contradictions.
Foundations of Functional Decomposition
What Makes a Process “Atomic”?
Atomic processes are the smallest units of transformation in a DFD. They can’t be meaningfully broken down further without losing their functional integrity.
Ask yourself: can this process be described in a single, clear action verb phrase (e.g., “validate user credentials” or “calculate tax”) that results in a distinct data output?
If yes, it’s atomic. If no, it likely involves multiple actions and should be split into logical sub-processes.
Key Indicators of Non-Atomic Processes
  • Requires multiple input data flows but produces only one output.
  • Contains conditional logic (e.g., “if-then”) but doesn’t separate branching into distinct processes.
  • Relies on internal decision-making not reflected in the data flows.
  • Named with vague or compound verbs (e.g., “process and update” or “handle payment and notify”).
Practical Rule: One Output, One Transformation
Every atomic process must have exactly one output, even if it’s a complex data structure. This ensures clarity, traceability, and alignment with the principle of functional decomposition.
If a process generates multiple distinct outputs (e.g., a report and a confirmation), they should be separated into two atomic processes unless they are functionally inseparable (e.g., a batch of output is generated as a single unit).
Identifying Processes: A Systematic Approach
Step 1: Start with the Parent Process
Begin by reviewing the parent process. What is its purpose? What data does it consume, and what new data does it produce?
Then ask: “What specific action transforms this input into that output?” The answer is your candidate for a sub-process.
Step 2: Apply the Input-Output Test
For each candidate process, verify the following:
  • Does it consume at least one input from the parent process?
  • Does it generate at least one output that becomes part of the parent’s output?
  • Is the transformation logically complete and independent of other processes?
If any test fails, the process is not atomic and should be re-evaluated or split.
Step 3: Name with Action Verbs
Use active, precise verbs. Avoid nouns or passive phrasing.
Incorrect: “Payment processing” → Too broad, lacks action.
Correct: “Validate payment details” → Clear, measurable.
Step 4: Check for Duplicates and Overlap
Compare all sub-processes. Do any perform the same transformation on the same inputs? If so, they’re redundant and should be merged.
Are there gaps in data flow? If an input is consumed but no output is produced, the process is incomplete.
Avoiding Common Pitfalls in System Breakdown DFD
Over-Decomposition: When More Isn’t Better
Breaking a process into more than five sub-processes often indicates over-decomposition. Ask: “Could this be a single decision point, or are we treating control logic as process logic?”
For example, splitting “validate input” into “check format,” “verify length,” and “compare to rules” is unnecessary unless each step produces a distinct intermediate output.
Under-Decomposition: The Hidden Logic Trap
One of the most frequent errors I’ve seen is combining distinct transformations into a single process labeled “process data.” This hides critical logic and makes balancing and validation nearly impossible.
Every decision point requires a process. If data changes based on a condition (e.g., “if valid, proceed; if invalid, return error”), then the decision and both outcomes must be modeled as separate processes.
Table: Signs of Over- or Under-Decomposition
Issue Signs Fix
Over-Decomposition More than 5 sub-processes for one parent; similar-sounding names; shared inputs but no outputs. Group small, related transformations; ensure each sub-process has a unique output.
Under-Decomposition One process handles multiple logic paths; no clear output from decision-making. Break into separate processes for each branch; model decisions as processes.
Ensuring Data Flow Integrity in Decomposition
Use the “Input-Output” Filter
Before finalizing any DFD level, apply this filter:
  1. Every input to a sub-process must come from a parent output or a data store.
  2. Every output from a sub-process must be used by a parent output, another sub-process, or a data store.
  3. Do not introduce data flows that aren’t traceable from the parent.
Violations here indicate either missing decomposition or incorrect data flow design.
Traceability Through the Data Dictionary
Each process name and data flow must be defined in the data dictionary. This ensures consistency across levels.
Example:
Process: Validate User Credentials
Inputs: User ID, Password (from Login Request)
Outputs: Validated User Record, Error Message (if invalid)
Data Store: User Database (read only)
Without a data dictionary, even small naming changes can break traceability.
Best Practices for Sustainable DFD Modeling
Checklist: Validating Process Decomposition
  • Each sub-process has a single, well-defined output.
  • All inputs are derived from parent outputs or data stores.
  • No process produces output without consuming input.
  • All process names use active verbs and are unique.
  • Decision-making is modeled as a process, not implied in flow lines.
Practical Tip: Use Process Labels Consistently
Always number processes hierarchically (e.g., 2.1, 2.2). This makes it easy to trace their origin and validate consistency across levels.
Remember: Decomposition Is Not Simplification
Decomposition isn’t about making a model smaller—it’s about making it more transparent. The goal is not fewer boxes, but clearer logic.
Each sub-process should be understandable on its own. If you can’t explain it in a sentence or two without referencing other processes, it’s not decomposed properly.
How do I know when I’ve decomposed enough?
When each sub-process performs one distinct transformation, consumes defined inputs, and generates a measurable output. If the process name includes “and” or “then,” it’s not atomic. Stop when you can describe the function in one sentence using an active verb.
Can I break down a data store into processes?
No. Data stores represent persistent information, not transformations. However, operations on data stores (e.g., “read user profile,” “update record”) are processes and should be modeled as such.
What if two processes produce the same output?
This is acceptable only if both processes are independent and serve different purposes. But if the output is functionally identical, they should be merged into one process unless there’s a clear reason for separation (e.g., different data sources).
How do I handle conditional logic in process decomposition?
Model each decision outcome as a separate process. For example, “if valid → approve; if invalid → reject” should be two processes: “Validate Application” and “Reject Application.” The decision itself is not a process but triggers the output.
Should I use the same name for a parent and child process?
No. Avoid naming conflicts. Use descriptive hierarchy: e.g., “Process 2.1: Validate ID” instead of “Process 1: Validate ID.” This prevents confusion and supports traceability.
What’s the difference between functional decomposition and structural decomposition?
Functional decomposition focuses on *what* the system does—breaking it into processes by function. Structural decomposition focuses on *how* it’s built (e.g., components, modules). DFD modeling is functional decomposition. The focus is always on data transformation, not physical components.
