From Personas and Scenarios to BPMN Models
Время чтения: 7 мин. 47 просмотров
Too many organizations stop at journey maps or persona decks, treating them as final deliverables instead of springboards. The real value emerges only when you connect those human-centered ideas to operational clarity. That’s where BPMN comes in—not as a technical artifact, but as a bridge between empathy and execution.
Over two decades of experience in customer experience design taught me this: no matter how vivid the persona or how rich the scenario, it’s only a starting point. The real work begins when you ask: *How does this play out in process? Who owns what? What happens when things go sideways?*
Mapping personas to BPMN isn’t about copying a narrative into a diagram. It’s about extracting intent, triggers, goals, and failure modes—and turning them into structured, traceable workflows that align customer expectations with internal operations.
This chapter walks you through the exact steps I’ve used in 30+ client engagements: how to take a scenario, identify the hidden logic, and build a BPMN skeleton that preserves customer behavior while revealing operational gaps.
From Narrative to Process: The Extraction Framework
Every customer journey starts as a story—sometimes brief, sometimes detailed. The key is not to preserve the story, but to decode it.
Start with this simple framework: identify the trigger, goal, main steps, decision points, and exception paths.
Let’s say you have a scenario: “A customer signs up for a digital bank account but gets stuck when the identity verification fails.” That’s not just a pain point—it’s a roadmap.
Step 1: Identify the Trigger and Goal
Begin by isolating the event that starts the journey. In this case: «Customer submits identity verification form.»
The goal? «Successfully complete identity verification and proceed to account activation.»
These become your start event and end event in BPMN. The flow between them is where the real work happens.
Step 2: Break Down the Main Steps
List the actions the customer takes—and the systems or teams that support them.
  • Customer uploads ID and selfie
  • System validates document format
  • AI checks for tampering
  • Human reviewer confirms identity
  • System sends approval or rejection
These map directly to activities in BPMN. Each step is a task—simple, clear, and measurable.
Step 3: Map Decision Points and Exceptions
Where does it go wrong? Where does the customer pause? Where is escalation needed?
Use gateways to model these. For example:
  • Does the document pass format check? → Yes → AI verification → No → Return to customer with feedback
  • Is AI confidence above 90%? → Yes → Auto-approve → No → Route to human reviewer
These are exclusive gateways—they split the path based on a condition.
Now, add boundary events for exceptions: “Verification timeout after 5 minutes” or “User abandons form.” These capture the moments when the customer gives up—not a failure of process, but a signal that something needs to improve.
Step 4: Assign Roles and Channels
Who does what? Use lanes to assign responsibilities:
  • Customer: uploads documents, receives feedback
  • System: validates format, runs AI check
  • Human Reviewer: confirms identity, approves/rejects
Now, ask: Is this interaction online? A mobile form? A call center? Use channels to clarify.
For example, if the same verification step can be done via mobile app or web portal, model both paths under one process, but label the channel in the activity description or use colored swimlanes.
From Story to Skeleton: A Real Example
Let’s walk through the full transformation of a scenario into a BPMN skeleton.
Scenario:
“Maria, a 42-year-old freelance designer, wants to open a checking account online. She starts the application, uploads her driver’s license and a recent utility bill, and proceeds to verify her identity. The system flags her ID as “partially expired” and requests a second form of ID. She uploads a passport, but the AI detects a mismatch in names. The system sends her a message: ‘We’re unable to verify your identity. Please contact support.’ She doesn’t reply.”
Extracted Elements:
  • Trigger: Customer clicks “Continue to Identity Verification”
  • Goal: Complete identity verification and proceed to account setup
  • Main Steps:
    • Upload ID and proof of address
    • System validates file types and size
    • AI checks for fraud indicators
    • AI detects possible mismatch (name)
    • System requests second ID
    • Customer uploads passport
    • AI re-checks; still no match
    • System sends rejection message
  • Decision Points:
    • Is file valid? (Yes/No)
    • Is AI confidence > 90%? (Yes/No)
    • Is name match confirmed? (Yes/No)
  • Exceptions:
    • Form abandoned after 5 minutes
    • System timeout
    • Customer does not respond to follow-up
BPMN Skeleton Outline:
  1. Start Event: Customer submits verification form
  2. Activity: Upload ID and proof of address
  3. Exclusive Gateway: File valid? → No → Send feedback → Back to upload
  4. Activity: Run AI fraud and data validation
  5. Exclusive Gateway: Confirmed match? → No → Request second ID
  6. Activity: Upload second form of ID (e.g., passport)
  7. Activity: Re-run AI validation
  8. Exclusive Gateway: Match confirmed? → Yes → Approve → End
  9. → No → Activity: Send rejection message
  10. End Event: Verification failed
Now, add boundary events:
  • Timer Event (on “Upload ID”): After 5 min → Abandonment
  • Message Event (on “Send rejection”): Customer replies → Escalate to support
This skeleton captures the customer’s journey, the logic of the system, and the moments of friction—all in BPMN form.
Practical Tips for Success
Here are the five rules I’ve learned from working across industries:
  1. Start with the customer’s view—not the system’s. The journey begins and ends with the customer. Never lose that perspective.
  2. Use swimlanes to clarify ownership. A lane labeled “Customer” keeps the focus on behavior. “Team X” or “System” should come second.
  3. Label activities with verbs. “Verify identity” is better than “Identity verification” — it signals action.
  4. Use consistent gateways. Always use exclusive (diamond) for decision points, inclusive only when multiple outcomes can happen.
  5. Don’t over-model exceptions. Include only critical ones—abandonment, escalation, failure—to keep the flow readable.
Mapping Personas to BPMN: A Checklist
When turning a persona into a BPMN model, ask:
  • Does the journey start with a trigger that matches the persona’s goal?
  • Are the steps aligned with the persona’s behavior and expectations?
  • Do responsibilities match real roles, not just job titles?
  • Are exceptions mapped to moments where the customer might give up?
  • Can the model be used in workshops with CX, operations, and IT teams?
If you can answer “yes” to all five, you’re ready to move from narrative to process.
How do I handle multiple personas in one BPMN model?
Model the journey once, but use annotations to show how different personas might experience it differently. For example, a young user may prefer mobile; a senior user may need phone support. Keep the core process the same, but highlight touchpoints where behavior diverges.
Can I use BPMN for both self-service and assisted journeys?
Absolutely. Use gateways to branch after key decisions. For example: “Can the issue be resolved via help center?” → Yes → Self-service path; No → Route to agent. This keeps the model unified while showing both paths.
Should I model every small step in the customer journey?
No. Focus on steps that impact customer experience—especially decision points, handoffs, and waiting times. Avoid modeling internal subroutines unless they directly affect the customer’s perception of speed or quality.
What if the journey is too complex for one BPMN model?
Use subprocesses or collaboration diagrams. Break the journey into stages (e.g., Onboarding → Verification → Activation), and link them. Keep each model under 15–20 activities. Use swimlanes to show cross-functional handoffs.
How do I ensure BPMN models stay in sync with journey maps?
Use traceability. Link each BPMN activity to a stage in the journey map. Add a legend or annotation showing which journey phase it belongs to. When the journey map updates, revisit the model.
Can BPMN models be used for automation or orchestration?
Yes—especially when they’re clear, modular, and contain well-defined decision points. BPMN is the ideal blueprint for workflow engines. But remember: automation should not replace empathy. Use it to reduce errors and wait times—not to remove human judgment when it’s needed.
