Support Journey: From Issue to Resolution and Follow-Up
Время чтения: 7 мин. 65 просмотров
“Start with the customer’s first point of contact and move step by step.” This advice appears everywhere. But in practice, it often leads to tangled, overly detailed models that miss the real pain points.
When you model support journeys, the real challenge isn’t capturing every step. It’s identifying where the gaps are—where delays happen, where handoffs break down, where empathy fades.
My years building BPMN models for support teams taught me this: a solid support journey BPMN doesn’t just map actions. It reveals who’s responsible, when time matters, and how decisions affect experience.
You’ll walk through how to model the full lifecycle of a support issue—across self-service, chat, and phone—using BPMN to highlight touchpoints, decision gates, escalation paths, and follow-up loops. You’ll learn to balance clarity with realism, so your model becomes a tool for improvement, not just documentation.
This chapter turns abstract concepts into clear, actionable diagrams. You’ll see exactly how to represent the customer support process BPMN, track a single ticket through escalation paths, and model outcomes that matter: resolved, unresolved, or repeated.
Mapping the Full Support Journey: From Issue to Resolution
Every support journey begins with a friction point: a failed login, a missing shipment, a confusing error message. The moment the customer reaches out, a new process begins—not just a sequence of actions, but a path where experience is shaped by response time, clarity, and care.
Start by defining the journey’s scope. The trigger is clear: a customer reports an issue. The end? A confirmed resolution, a follow-up, or a closure with feedback. But the path between is where things diverge.
Use BPMN to model the customer as a first-class participant. Place them in their own pool or lane, clearly separated from internal teams. Then, map the channels they use: self-service help, live chat, phone support.
Each channel has its own rhythm and outcome. Self-service resolves simple cases fast, but can leave customers feeling stuck. Chat offers real-time help but may delay escalation. Phone support builds trust but can introduce delays.
Modeling Multi-Channel Support Entry Points
Begin with a message flow from the customer pool to a central support lane. Use a gateway to route the case based on channel.
Here’s a practical structure:
  • Self-Service Path: Customer searches a help center. If resolved, the journey ends. If not, they can escalate to a chat or phone ticket.
  • Chat Path: A support agent responds in real time. If resolved, close the ticket. If not, escalate via message flow to the next level.
  • Phone Path: The agent logs the issue, checks the system, and determines next steps. If unresolved, the ticket is escalated.
Use send/receive tasks to represent interactions. For example:
Customer → [Send: Issue Report] → Support Lane
Support Lane → [Receive: Issue Report] → Triage
Keep the customer visible throughout. Even when they’re waiting, their presence should be implied through time-based events or wait states.
Decision Logic: Triage, Escalation, and Resolution Paths
At the heart of any support journey BPMN model is decision-making. The ability to route tickets correctly determines how fast and fairly customers are served.
Use gateways to model branching logic. The first decision is triage:
  • If issue is common and documented → Route to self-service or knowledge base.
  • If issue is complex or high-risk → Escalate to Tier 2.
  • If issue is time-sensitive → Flag for immediate attention.
Now, model the ticket escalation journey. This is where many models fail: they assume escalation is a single path. In reality, it’s a decision tree with multiple conditions.
Escalation Trigger Response BPMN Pattern
Unresolved after 48 hours Auto-escalate to Tier 2 Timer event + gateway
High-priority label Immediate assignment to senior agent Message event with priority flag
Customer escalates via email Reopen and re-route Boundary event (exception)
Use boundary events to capture exceptions: a customer sending a hostile message, a response time exceeding SLA, or a repeated issue from the same user.
These events don’t just signal failure. They trigger recovery actions: reassurance, management review, or a service recovery protocol.
Modeling Resolved, Unresolved, and Repeated Issues
Not all issues end in resolution. Some remain open. Some get reopened. A good issue resolution BPMN model must reflect these outcomes.
After resolution, include a follow-up task:
  • Wait 48 hours
  • Send customer satisfaction survey (CSAT)
  • Evaluate feedback
  • If CSAT is low → Reopen ticket and escalate to quality team
Use a loopback to previous steps if the customer reports the issue persists. This isn’t a flaw—it’s a feature. It shows the journey isn’t linear.
Here’s a simple loop logic:
Resolution → [Wait: 48h] → [Send Survey]
Survey → [CSAT ≥ 4] → [Close Ticket]
Survey → [CSAT < 4] → [Reopen Ticket] → [Escalate to Quality]
Reopening isn’t a mistake. It’s a signal the process needs improvement.
Integrating KPIs and SLAs into the Model
Every BPMN model should answer: what does success look like?
Attach SLAs to key steps:
  • First response: within 4 hours
  • Resolution: within 3 business days
  • Follow-up: within 48 hours
Use timer events to represent time limits. If a task exceeds SLA, a boundary event triggers an alert.
Label each activity with a KPI. For example:
  • “Triage: Average time: 1.2 hours (KPI: SLA 4h)”
  • “Escalation: Average time: 2.4 hours (KPI: SLA 48h)”
These annotations aren’t decorative. They turn the BPMN model into a performance dashboard.
Even experienced modelers fall into traps. Here are the most frequent:
  1. Overloading the diagram: Too many gateways, nested subprocesses, or too many lanes. Simplify. Use subroutines for repeated logic.
  2. Hiding the customer: When the customer isn’t in the model, it becomes a back-office flow. Always keep the customer lane visible.
  3. Missing exception paths: A “happy path” model doesn’t reflect reality. Always include escalations, complaints, and reopens.
  4. Ignoring time: Waiting states, response delays, and SLAs are part of the customer experience. Use timers and annotations to reflect them.
Remember: the goal isn’t to document every detail. It’s to reveal where improvements are needed.
Final Thought: The Model as a Tool for Change
When you’ve built a support journey BPMN model that includes all channels, decisions, escalations, and follow-ups, you’re not done. You’ve just begun.
This model becomes a shared language. Product teams see where friction occurs. Support leads understand bottlenecks. CX leaders can measure impact.
A strong support journey BPMN isn’t just about process. It’s about responsibility, empathy, and continuous improvement. And it all starts with a single decision: to put the customer at the center of every line of code, every handoff, every task.
How do I represent self-service and live chat in the same BPMN model?
Use a gateway to split the flow based on channel. Create separate lanes for “Self-Service,” “Live Chat,” and “Phone Support,” but keep the customer pool connected across all. Use message flows to show escalation between lanes.
What’s the best way to model ticket escalation in BPMN?
Use a decision gateway after triage. Include triggers like time elapsed, priority level, or customer feedback. Then use timer events and boundary events to capture SLA breaches or exceptions.
Can I model repeated issues in a BPMN diagram?
Absolutely. Use a loopback from the follow-up step to resolution if the customer reports the issue persists. Label it clearly: “Reopen if issue not resolved.” This shows the journey isn’t linear.
Should I include the customer in every BPMN diagram?
Yes, especially when modeling the end-to-end support journey. Represent them as a separate pool or lane. This keeps the focus on experience, not just operations.
How do SLAs and KPIs fit into BPMN?
Use annotations or labels on activities. For example: “Resolution: Target 48h (SLA).” Use timer events to trigger alerts if time limits are exceeded. This turns BPMN into a performance tracker.
What if my support team uses different tools across channels?
Don’t model the tools. Model the process. Use a single “Support” lane and annotate it with channel-specific steps. The tool is irrelevant—what matters is the handoff, response time, and resolution outcome.
