Basic Estimation Methods: Getting Accurate Without Complexity
Время чтения: 8 мин. 62 просмотров
Estimation in Scrum isn’t about predicting exact timelines. It’s about aligning team capacity with complexity, not effort. Misunderstanding this early can derail sprint planning, breed frustration, and erode trust in the process.
As someone who’s guided over 30 teams through their first year of Scrum, I’ve seen how even small missteps in estimation—like treating story points as hours—can spiral into scope creep, missed deadlines, or burnout.
My advice? Focus on relative sizing, not absolutes. Let the team’s collective intuition do the heavy lifting. This chapter shows you how to start with story points estimation beginners, use planning poker Scrum guide techniques, and build real confidence without overcomplicating things.
You’ll learn how to avoid common traps, how estimation ties into velocity, and why simplicity beats precision in early adoption. The goal isn’t perfection—it’s consistency and shared understanding.
Why Story Points Matter in Scrum
Story points aren’t hours. They’re a unit of effort, but rooted in complexity, risk, and required coordination—not time.
Once teams grasp that, estimation becomes a conversation, not a math problem. Story points estimation beginners often struggle with this shift. They think, “How long will it take?” instead of, “How hard is it to deliver?”
Consider a user story: “As a user, I want to reset my password.” That task might be a ‘3’—moderate complexity due to security checks, email validation, and rate-limiting.
Compare it to “As a user, I want to upload a 50MB file.” That’s a ‘13’—high complexity from file validation, storage, bandwidth, and error handling.
Relative sizing works because it’s based on shared understanding. If the team agrees that a ‘5’ is medium-high effort, all future stories are sized against that mental model.
Common Misconceptions About Story Points
  • Myth: Story points should match time (e.g., a 5 is 5 days).
  • Reality: They reflect effort, not duration. A 3 might take 1 day or 3 days—depending on context and team velocity.
  • Myth: Estimation must be perfect.
  • Reality: Estimation is about alignment, not accuracy. Good enough is often enough.
Planning Poker: A Collaborative Approach
Planning poker is the gold standard for collaborative story points estimation beginners trust.
Why? It prevents anchoring, encourages dialogue, and surfaces hidden assumptions.
Here’s how I run it with a new team:
  1. Read the user story aloud.
  2. Each team member selects a card representing their estimate.
  3. Reveal cards simultaneously.
  4. If estimates vary, discuss why. Focus on rationale, not consensus.
  5. Revote. Repeat until agreement or clear consensus.
I’ve seen teams go from 1–5 to 5–10 to 13–20 in a single round. That’s normal. The goal is discussion, not agreement.
Many confuse this with vote counting. It’s not. It’s about shared understanding.
When to Use Planning Poker
Use it for:
  • New or complex backlog items.
  • Items requiring cross-functional input.
  • When team members have differing experience levels.
It’s especially useful in planning poker Scrum guide environments where transparency and team autonomy are key.
Story Points vs. Ideal Days: Choosing the Right Method
Ideal days are tempting. “This will take 3 days.” But they’re fragile. One person’s ideal day isn’t another’s. And what about holidays? Meetings? Context switches?
Story points avoid that. They don’t assume a fixed unit of time. Instead, they reflect effort relative to the team’s experience.
Method Pros Cons
Story Points Time-independent, encourages team alignment, scalable across teams Less intuitive for new teams, requires practice
Ideal Days Easy to communicate, intuitive for non-technical stakeholders Subject to interpretation, fragile under change
As a Scrum Master, I recommend starting with story points. Ideal days can be introduced later, but only after teams understand relative sizing.
That said, if your team is just starting, you can temporarily use ideal days—but be ready to transition. The goal is to move from predicting time to estimating effort.
Affinity Estimation: A Faster Alternative
When you have many items to estimate—say, 30+ in a sprint planning session—planning poker can slow things down.
Affinity estimation is a powerful alternative. It groups stories by size, then assigns story points based on relative placement.
Here’s how I use it:
  1. Place a “0” card on the table.
  2. Place a “1” card next to it.
  3. Ask the team to place each story card relative to these anchors.
  4. Reveal final groupings. Assign points based on placement.
It’s faster, visual, and excellent for backlog refinement or sprint planning when time is tight.
But use it with caution. It’s not for complex or novel stories. For those, go back to planning poker.
Introducing Velocity: Measuring Team Capacity
Velocity is not a performance metric. It’s a measure of team capacity over time.
It’s calculated by summing the story points completed in each sprint.
For example:
  • Sprint 1: 15 points
  • Sprint 2: 17 points
  • Sprint 3: 16 points
Average: 16 points per sprint.
That’s your team’s average velocity. Use it to guide future sprint planning—not to pressure the team.
Remember: velocity isn’t about speed. It’s about predictability.
Don’t try to increase velocity just because it’s low. Look at the work. Was the backlog poorly defined? Did the team face impediments? Was scope changed mid-sprint?
Improving velocity comes from better estimation, stable team size, and consistent Definition of Done.
Best Practices for Story Points Estimation
These are the habits I’ve seen lead to lasting success:
  • Keep the backlog refined. Unrefined items are hard to estimate. Prioritize backlog refinement.
  • Revisit estimations in sprint review. Did the team deliver what they thought they would? Why or why not?
  • Use reference stories. Define 1–2 stories as benchmarks. “This is a 5.” “This is a 13.”
  • Limit estimation to 15–20 minutes per story. Timeboxing keeps focus.
  • Encourage questions. “What makes this harder than the last one?”
When estimation becomes a ritual, not a chore, the team starts to trust the process.
Practice Scenarios: Estimating in Real Life
Let’s walk through a few real-world examples:
Scenario 1: A Simple UI Update
“Change the login button from blue to green.”
Estimate: 1 or 2. No logic changes. Just a color update. Low risk. Small scope.
Why not 0? Because even small tasks require time to test and deploy.
Scenario 2: Adding a New Feature
“Allow users to upload profile pictures with size and format validation.”
Estimate: 5. Requires new components, file validation logic, backend storage setup, and error handling.
Not a 13, because it’s not a full file management system—just a single feature.
Scenario 3: Integrating a Third-Party API
“Connect to payment gateway and process one-time payments.”
Estimate: 8. Involves authentication, error handling, security, and testing with sandbox.
Why not 5? It’s more complex due to external dependencies and compliance.
These aren’t rules. They’re starting points. Let your team discuss and agree.
Scrum estimation isn’t about being right. It’s about being consistent and aligned.
Story points estimation beginners can start with simple, relatable examples. Planning poker Scrum guide techniques foster collaboration, empathy, and shared understanding. Velocity isn’t a target—it’s a tool for future prediction.
Focus on improvement, not perfection. Trust your team’s judgment. And remember: estimation is not a task. It’s a conversation.
Now go estimate something—today.
How do I start estimating story points as a beginner?
Start by selecting two or three reference stories. Size them (e.g., 1, 3, 5). Then compare new stories to these. Use planning poker to discuss differences in effort, complexity, and risk.
Why should I use story points instead of ideal days?
Story points remove the illusion of precision. Ideal days vary based on individual availability and focus. Story points reflect team effort relative to known work, making them more reliable over time.
What if team members disagree during planning poker?
Disagreement is expected. Ask each member to explain their reasoning. The goal isn’t to convince someone to change, but to surface assumptions. Re-vote. If still divergent, break into sub-teams or split the item.
Can velocity increase over time? Is that a good sign?
Yes, but only if the team improves estimation and delivery without sacrificing quality. Increases due to scope creep, technical debt, or burnout are not sustainable. Focus on stable, high-quality delivery.
How many story points should a sprint contain?
There’s no fixed number. Use your average velocity. If your team’s velocity is 16, aim for 15–18 points of work per sprint. Adjust based on team size, capacity, and impediments.
Do I need story points for small teams or simple projects?
Yes. Even small teams benefit from relative estimation. It builds shared understanding, prevents overcommitment, and supports long-term predictability—even on simple projects.
