Crafting a Strong Product Backlog: Essential Techniques
Время чтения: 7 мин. 64 просмотров
One of the most common missteps I’ve seen in new Scrum teams? Starting with a chaotic, vague, or overly detailed backlog that becomes a dumping ground instead of a strategic roadmap. I remember a team that spent weeks refining dozens of “features” without clear ownership or value—only to realize too late that they were building what users didn’t want.
The truth is, a well-structured product backlog isn’t about volume. It’s about clarity, alignment, and continuous refinement. It’s the single source of truth where value meets execution.
This chapter walks you through how to create and maintain a product backlog that actually works—using real techniques, practical examples, and the principles from the Scrum Guide. You’ll learn how to write effective user stories, apply the INVEST criteria, and prioritize with confidence, even when resources are limited.
If you’re just starting with Scrum, this is your foundation. It’s the difference between guessing what to build and knowing exactly what matters.
Start with the Right Mindset: Backlog as a Living Document
Think of the product backlog not as a list—but as a strategic living document. It evolves with feedback, market shifts, and team insights.
It’s not a static to-do list. It’s a dynamic, prioritized roadmap shaped by continuous discovery, stakeholder input, and empirical data from previous sprints.
The Product Owner isn’t just a “planner.” They’re a value navigator—responsible for guiding the team toward outcomes, not just outputs.
What a Healthy Backlog Looks Like
  • Items are small, clear, and actionable.
  • Prioritization reflects business value, risk, and effort.
  • Each item answers: “What problem are we solving?”
  • It’s regularly refined—never left untouched for weeks.
  • It lives in a shared space where the team can see, discuss, and own it.
How to Create a Product Backlog: Step-by-Step
Step 1: Use the User Story Format (As a… I want… so that…)
One of the most effective ways to describe a requirement is through a user story. This format keeps the focus on the user, their need, and the business outcome.
Use this template:
As a [type of user],
I want [an action],
so that [a benefit is achieved].
Let’s say you’re building a task management app. Instead of “Add a reminder feature,” write:
As a team member, I want to set due dates on tasks, so that I don’t miss important deadlines.
This format helps avoid technical jargon and keeps the team focused on user value. It also becomes a natural starting point for conversations during refinement.
Step 2: Apply the INVEST Criteria
Not every backlog item qualifies as a good story. Use INVEST to evaluate whether an item is worth including and refining.
Criterion What It Means Example
Independable Can be implemented without blocking other items. “Add login with Google” can be done independently.
Negotiable Open to discussion—details can be added later. “Improve performance” is negotiable; “Reduce page load time to under 2s” is more specific.
Valuable Delivers real value to the user or business. “Allow users to export reports” adds measurable utility.
Estimable Can be estimated in story points or time. “Add search bar” can be estimated as 3 points.
X small Small enough to fit in a sprint. A 13-point story needs splitting.
Testable Can be verified with clear acceptance criteria. “User can reset password via email” can be tested.
Step 3: Break Down Large Items (Sizing & Splitting)
If an item is too large—say, over 8 story points—you’ll likely need to split it. Use these techniques:
  • Feature Splitting: Break by functionality. “User registration” → “Sign-up email validation,” “Password strength check,” etc.
  • Workflow Splitting: Split by process stages. “Order checkout” → “Add item to cart,” “Apply discount code,” “Enter shipping details.”
  • Horizontal Splitting: Split by layers (UI, logic, data). Useful for complex technical stories.
Remember: a story that can’t be tested, delivered, or verified in a sprint isn’t truly ready.
Prioritization Techniques That Work (Without the Guesswork)
Start with Value vs. Effort (Impact/Effort Matrix)
Evaluate each backlog item using two dimensions: business value and effort required.
Effort Level Low Value High Value
Low Do later — low effort, low impact. Do now — quick win, high impact.
High Reconsider — high effort, low value. Prioritize carefully — high impact, high effort.
Use this to guide your sprint planning. The “Do now” quadrant is your priority zone.
Use MoSCoW for Clear Categorization
MoSCoW is a simple but powerful method to label items:
  • Must have: Core functionality. If it’s not there, the product doesn’t work.
  • Should have: Important, but not critical. Can be deferred.
  • Could have: Nice to have. Low priority, but improves product.
  • Won’t have: Not in scope—may be reconsidered later.
Apply this during backlog refinement. It’s especially useful in stakeholder meetings to manage expectations.
Try the Impact Mapping Exercise
Start with your goal: *“Increase user sign-ups by 20% in Q3.”*
Then ask: What would help us achieve it?
  • Improve onboarding flow
  • Offer a free trial
  • Add social login options
Next: What prevents it?
  • Too many form fields
  • Slow load times
Now map features to outcomes. This turns abstract goals into concrete, prioritized items.
Refinement: The Heartbeat of a Healthy Backlog
Backlog refinement isn’t just a task—it’s a continuous conversation. I recommend holding it regularly, ideally before each sprint.
Here’s how to run an effective refinement session:
  1. Time-box it: 60–90 minutes per sprint.
  2. Keep it small: 3–5 items per session.
  3. Focus on clarity: Ensure every item has acceptance criteria.
  4. Invite the team: Developers and testers contribute to estimation and clarity.
  5. Use visual tools: A physical or digital whiteboard helps everyone see the big picture.
Don’t aim to refine everything. Focus on the top 2–3 sprint’s worth of items. That’s enough to set a team up for success.
Visualize with User Story Mapping (Recommended Tool: Visual Paradigm)
User story mapping helps you see the big picture. It turns the backlog into a visual journey of user experience.
Start with the user’s goal at the top. Break it down into activities. Then map stories to each step.
For example, “Order a meal online” includes:
  • Find a restaurant
  • View menu
  • Add items to cart
  • Pay and confirm
Each step becomes a column. Stories go under each.
Using tools like Visual Paradigm makes this easy. It offers templates for story maps, swimlanes, and timeline views—great for team alignment and stakeholder sharing.
Common Pitfalls to Avoid
  • Over-documenting: Don’t write 500-word user stories. Keep them focused and concise.
  • Ignoring acceptance criteria: A story without acceptance criteria is a promise, not a commitment.
  • Letting the backlog become stale: If it hasn’t been refined in two weeks, it’s likely not helping anyone.
  • Not involving the team: The development team must understand and participate in refinement to ensure feasibility.
  • Over-prioritizing technical work: While refactoring is important, prioritize features that deliver value first.
How do I create a product backlog as a beginner?
Start with user stories using the “As a… I want… so that…” format. Focus on small, valuable items. Prioritize based on business impact and effort. Refine regularly with your team. Use tools like Visual Paradigm or a simple Kanban board.
What are user stories in Scrum guide?
According to the Scrum Guide, a user story is a short description of a feature told from the user’s perspective. It captures what the user wants and why. It’s meant to spark conversation, not replace detailed requirements.
How do I prioritize a product backlog with limited time?
Use the impact vs. effort matrix. Focus on high-impact, low-effort items first. Use MoSCoW to categorize: Must-haves go first. Keep stakeholder input but stay focused on value delivery.
Should I write acceptance criteria for every user story?
Yes. Acceptance criteria clarify when a story is “done.” They should be specific, testable, and agreed upon by the team. Start with three to five per story.
Can I use the product backlog for non-software projects?
Absolutely. The concept applies to any complex, adaptive work—marketing campaigns, product launches, internal tools. The key is to focus on outcomes, not outputs.
How often should I refine the backlog?
Refine it regularly—ideally once per sprint, or even weekly. The top 1–2 sprints of work should be well-refined. The rest can be less detailed.
