Splitting Large Epics into Manageable Stories
Temps estimé :7 minutes 322 vues
Large systems demand large thinking—but not large stories. The key insight is this: a well-formed epic is not a container of work, but a promise of value. When that promise is broken down, it must remain tied to measurable user outcomes. I’ve led dozens of teams through this exact transformation, and the most common mistake isn’t lack of effort—it’s misaligned decomposition.
Splitting epics into stories isn’t about creating more work. It’s about making value visible at the team level. If your teams aren’t building toward a tangible outcome, you’re not scaling agility—you’re scaling bureaucracy.
Here, you’ll learn proven agile splitting techniques that preserve meaning, flow, and ownership. These are not theoretical patterns. They’re field-tested methods used in global enterprises, with real examples from banking, healthcare, and SaaS platforms. You’ll understand when to use each approach, how to avoid common dependency traps, and how to keep story slicing at scale aligned with business goals.
Why Decomposition Matters in Large-Scale Agile
At scale, every story must answer two questions: Who benefits? And how do we know it’s done?
When epics become too large, teams often lose sight of the user. The result? Stories with ambiguous acceptance criteria, unclear ownership, and alignment drift.
Agile splitting techniques are designed to prevent this. They ensure every story delivers a piece of value that can be tested, demonstrated, and measured—regardless of which team or domain owns it.
The Value Drift Problem
Consider an epic titled “Secure Online Payment Experience.” Without proper splitting, teams might produce stories like:
  • “Implement payment gateway integration”
  • “Add fraud detection module”
  • “Design user interface for payment form”
These are technical tasks, not user stories. They don’t start with “As a user…” and fail to show how value is delivered.
Correct decomposition starts with the user. The real story is: “As a customer, I want to complete a payment securely so I can finish my purchase without fear of fraud.” That’s the anchor.
Core Agile Splitting Techniques
There’s no single way to split an epic. But there are patterns that work across contexts. Use them with intent, not as templates.
1. By User Flow (Use Case Driven)
Break the epic by the user journey. This is one of the most reliable methods for story slicing at scale.
Example: “Secure Payment Experience” can be split into:
  • As a customer, I want to enter my payment details so I can proceed to checkout.
  • As a customer, I want to verify my identity via 3D Secure so my payment is protected.
  • As a customer, I want to receive a confirmation email after payment so I know it was successful.
These are not features—they are atomic interactions that a user would experience in sequence. Each delivers a piece of value and can be tested independently.
2. By Business Function (Capability-Based)
Group stories by the business capability they serve. This works well when multiple teams are involved in a single domain.
Example: “Customer Onboarding” can be split into:
  • As a new user, I want to create an account so I can access the platform.
  • As a new user, I want to verify my email so I can unlock full features.
  • As a new user, I want to upload my ID so I can pass identity verification.
Each story maps to a distinct function. This allows teams to own and deliver independently while still integrating into a full user journey.
3. By Data or State (State-Based)
Use this when the epic involves transitions between system states.
Example: “Order Management” can be split by order lifecycle stages:
  • As a customer, I want to place an order so I can receive my products.
  • As a customer, I want to track my order status so I can plan for delivery.
  • As a customer, I want to return a defective product so I can get a refund.
Each story corresponds to a state transition: Order Created → Order Shipped → Order Returned. This is ideal for systems with complex workflows.
4. By Technical Layer (Architecture-Driven)
Use with caution. This is often a trap for teams that focus on implementation over value.
Example: “Secure Payment Experience” split by layers:
  • As a developer, I want to implement encryption at rest so data is protected.
  • As a developer, I want to add JWT token validation so only authenticated users can access the API.
These are not user stories. They’re internal technical improvements. They should be in the backlog, but not as primary stories. Instead, they support the real user value.
Decision Matrix for Splitting Epics
Use this checklist to evaluate whether a story is truly independent, valuable, and testable.
Criteria Check Why It Matters
Starts with “As a [user]” ✅ Ensures user-centric focus
Delivers measurable value ✅ Prevents invisible work
Testable with one acceptance criterion ✅ Enables clear Done definition
Can be delivered by one team in one sprint ✅ Supports flow and predictability
Independent of other stories ✅ Reduces dependency risk
Apply this to every story. If it fails more than one criterion, reconsider the split.
Common Pitfalls in Story Slicing at Scale
Even with the best intentions, teams fall into traps. Here are the most frequent.
Over-Engineering the Split
Some teams believe every story must be “small.” But size isn’t the only measure—value and independence matter more.
Example: Breaking “Order Processing” into 20 stories that only cover input validation is not helpful. Focus on end-to-end value, not technical minutiae.
Creating “Epics by Proxy”
Teams sometimes split an epic into smaller epics. That doesn’t solve the problem. It just defers it.
Ask: Is this still a user-focused story? If not, it’s an epic in disguise.
Over-Reliance on Technical Categories
Splitting by framework, language, or database is not a valid user story. These are implementation details.
Always ask: Does the user care about this? If not, it belongs in the technical backlog or as a non-functional requirement.
Practical Workflow for Splitting at Scale
Here’s how I’ve run it in real programs:
  1. Start from the user journey. Map the end-to-end experience. Who is involved? What do they do?
  2. Identify key decision points. Where does the user pause, confirm, or react? Each is a potential story.
  3. Write as a user. Every story must begin “As a [role], I want… so I can…”
  4. Validate with acceptance criteria. Can the story be tested? Is there a clear “Done”?
  5. Assign to teams. Ensure ownership is clear. Avoid ambiguous “shared” ownership.
  6. Review for dependency risk. Use a dependency map to flag coupling between stories.
This workflow ensures that splitting epics into stories is not just a task—but a collaborative design process.
How do I know when a story is small enough?
A story is small enough when it can be completed by one team in one sprint without blocking others. If it requires coordination across more than two teams, reconsider the split. Aim for stories that take 1–5 days of effort.
Can a story span multiple teams?
Yes—but only if it’s a shared capability and the teams are aligned on scope and delivery. Use cross-team story workshops to define common goals, acceptance criteria, and handoff points. Avoid “ghost ownership.”
What if my epic is too complex to split?
Break it into sub-epics. Then apply the same rules. Never deliver a story that can’t be tested or doesn’t deliver user value. Use story mapping to visualize the flow and find natural breakpoints.
How do I avoid story bloat in large programs?
Enforce a story quality audit. Use checklists like the one above. Hold regular refinement sessions with all teams. If a story takes more than 30 minutes to explain, it’s not ready.
Do I need a central story owner?
No. Instead, assign story ownership based on domain and delivery responsibility. Use community of practice meetings to align on shared concepts and templates. Avoid top-down mandates.
How does story slicing at scale affect estimation?
Smaller, well-defined stories improve estimation accuracy. Teams can use story points or time-based estimates based on past velocity. Avoid estimating at the epic level—only at the story level.
Retour en haut
