Appendix: Glossary of Large-Scale Agile Story Terms
Temps estimé :7 minutes 54 vues
When I first stepped into enterprise-scale Agile, I was handed a dozen acronyms and no clear way to distinguish between them. The confusion wasn’t just in names—it was in meaning, ownership, and flow. That moment taught me something critical: scaling isn’t about adding more layers—it’s about creating shared understanding across complexity.
This glossary is built from over 20 years of experience working with global enterprises, where alignment isn’t a document—it’s a daily practice. I’ve distilled the most critical terms into precise, actionable definitions that reflect real-world usage, not just textbook theory.
Here, you’ll find clear distinctions between epics, features, and stories; how dependency modeling shapes delivery; and what a “valid” acceptance criterion looks like at scale. Whether you’re in a SAFe team, a LeSS-based structure, or a custom agile setup, these definitions help align your language, reduce ambiguity, and improve cross-team collaboration.
Use this as a living reference. Revisit it during PI planning, backlog refinement, or when new teams join. Let it be the common ground that allows complex systems to evolve with agility and clarity.
Core Elements of Large-Scale Agile Storying
Epics
An epic is a large body of work that delivers significant value but is too big to be completed by a single team in one sprint. It’s typically broken down into features and stories.
In enterprise environments, epics often originate from strategic objectives, OKRs, or portfolio-level initiatives.
Key insight: Not every large story is an epic. An epic must represent a meaningful, cohesive piece of business value—often spanning multiple teams and systems.
  • Originates from portfolio or program backlog
  • Typically spans multiple iterations
  • Must be decomposable into features
  • Tracked via epic ID or reference in tools
Features
A feature is a specific function or capability that delivers measurable value to the user or customer. It’s a logical grouping of related stories and is often owned by a single team or domain.
Features are typically planned at the program level and are used to organize work that crosses multiple teams or involves integration testing.
Practical example: “User Authentication via Third-Party Identity Providers” is a feature that may involve backend, frontend, and security teams.
  • Owned by a single Agile Release Train (ART) or team
  • Grouped under a program increment (PI)
  • Has acceptance criteria that define completion
  • May include multiple stories
User Stories
A user story is a concise, informal description of a feature from the user’s perspective. It follows the format: “As a [type of user], I want [some goal] so that [some reason].”
At scale, stories must be small enough to be completed in one sprint but large enough to deliver tangible value.
My rule of thumb: If a story takes more than three sprints to complete, it’s not a story—it’s an epic in disguise.
  • Written in plain language, not technical jargon
  • Each story should be testable and independent
  • Estimates should reflect effort, not time
  • Acceptance criteria must be specific
Advanced Concepts and Cross-Team Coordination
Dependency Mapping
Dependency mapping identifies how stories, features, or epics rely on one another across teams. This is crucial in large systems where one team’s work affects another’s delivery.
Dependencies aren’t just technical—they include shared services, data models, APIs, or shared user journeys.
Pro tip: Use visual dependency diagrams in story mapping or Kanban boards to surface hidden risks early.
Dependency Type Example Impact if Delayed
Technical API contract not ready Frontend team blocked
Data Shared database schema change Integration testing fails
Business Payment gateway approval needed Feature cannot be tested
Shared Acceptance Criteria
When multiple teams contribute to a single feature or user journey, acceptance criteria must be shared and agreed upon.
These criteria ensure that all pieces of the story are tested and validated as a whole—especially important in integrated systems.
Best practice: Use BDD (Behavior-Driven Development) syntax with Gherkin to write shared, executable criteria.
Given the user is logged in
When they submit the payment form
Then the transaction should be confirmed within 3 seconds
And a confirmation email should be sent
Definition of Done (DoD) at Scale
The Definition of Done is a shared standard that a story must meet before it’s considered complete. At scale, this becomes a cross-team agreement.
Each team may apply its own internal DoD, but the overall program DoD includes shared requirements like integration testing, security scanning, and deployment readiness.
Common elements in a scaled DoD:
  • Code reviewed and merged
  • Unit and integration tests passing
  • Security scan passed (SAST/DAST)
  • Documentation updated
  • Deployed to staging environment
  • Validated in end-to-end tests
Scaling Frameworks and Their Story Language
SAFe User Story Structure
The Scaled Agile Framework (SAFe) introduces a clear hierarchy: Portfolio → Program → Team.
Stories are the smallest unit of work at the team level, derived from features, which stem from epics.
Each story must be traceable back to a feature or epic. This traceability is essential for program-level reporting and PI planning.
SAFe Tip: Use “As a [role], I want [capability] to [benefit]” with a clear business value statement.
LeSS and Nexus
LeSS (Large-Scale Scrum) and Nexus (the scaling framework for Scrum) emphasize minimal process overhead and maximum transparency.
Story writing remains simple and user-focused. However, LeSS introduces the concept of « Product Owners » and « Scrum Masters » at multiple levels, which affects how stories are refined and prioritized.
Unlike SAFe, LeSS doesn’t require features as a formal level. Instead, stories are grouped by theme or user journey.
Disciplined Agile (DA) Story Approach
Disciplined Agile emphasizes adapting story practices based on context. It supports a range of techniques from simple anecdotes to full modeling.
DA encourages lightweight, adaptive story writing—especially in complex or regulated environments.
Key principle: Don’t force a model on a team. Let the nature of the work determine the level of detail.
Advanced Story Patterns and Practices
Reusable Story Patterns
Organizations with multiple products or product lines often reuse common story fragments.
For example, “As a user, I want to reset my password via email” appears across banking, e-commerce, and SaaS products.
Benefit: Reuse reduces duplication, speeds up refinement, and ensures consistency.
Store these in a central story library with versioning and usage notes.
Business-Driven Story Writing
Stories should reflect business outcomes, not just technical features.
Instead of: “Add a dropdown menu”
Write: “As a customer, I want to filter my order list by status so I can quickly find pending deliveries.”
This links directly to business value and enables better prioritization.
Non-Functional Requirements (NFRs) in Stories
NFRs—like performance, security, and availability—are often hidden in acceptance criteria.
Include them explicitly in the story to avoid rework.
Example: “The system must process 1,000 login attempts per second with 99.9% uptime.”
These are not just technical specs—they are acceptance criteria.
What’s the difference between an epic and a feature in SAFe?
An epic is a large initiative originating at the portfolio level, often spanning multiple PIs. A feature is a capability that delivers value and is planned at the program level. Epics must be decomposed into features before being broken into user stories.
How do I ensure consistency in story writing across teams?
Establish a shared story template, common acceptance criteria format, and a central story library. Use regular story workshops and peer reviews to enforce standards.
Can a story be owned by multiple teams?
Yes, but only when it involves shared responsibilities. Use cross-team story ownership with a single Product Owner and clear dependency mapping. Avoid splitting ownership too thinly—this leads to accountability gaps.
What is a “valid” acceptance criterion?
A valid criterion is specific, testable, unambiguous, and tied to actual user value. It should be written in plain language and executable (e.g., via BDD). It must pass verification in integrated testing.
How do I handle dependency risks in large-scale Agile?
Map all dependencies early using visual models. Flag high-risk dependencies in the backlog. Use dependency guards in PI planning, and reinforce shared ownership to reduce bottlenecks.
Why do we need a scaled agile glossary?
Because agility at scale isn’t about more processes—it’s about shared language. A common glossary prevents misunderstandings, reduces rework, and ensures all teams align on core concepts like “epic,” “feature,” and “definition of done.”
agile glossary enterprise is not just a tool—it’s a foundation for alignment, transparency, and sustainable agility across complex organizations.
