Ignoring Customer Journeys in Collaboration Models
Estimated reading: 8 minutes 47 views
One of the most persistent sources of misalignment between process models and actual business outcomes is the silent omission of customer touchpoints in collaboration diagrams. I’ve seen teams spend weeks refining back-office workflows—only to realize the process they’ve mapped doesn’t reflect how customers experience the service. The real cost isn’t just in miscommunication; it’s in designing performance metrics that don’t matter to the user.
Here’s the shift that eliminates most of this waste: treat every collaboration model as a journey, not a function. When you model the process from the customer’s perspective—their entry, actions, expectations, and exit—you automatically expose gaps in service logic, handoff delays, and unmet needs.
This chapter guides you through identifying customer journey gaps in BPMN, then correcting them with clear, actionable steps. You’ll learn how to add customer lanes, define meaningful touchpoints, and align internal steps with customer-facing interactions—so your process models reflect both operational reality and customer experience.
Why Customer Journeys Matter in BPMN Collaboration Models
Too many BPMN collaboration diagrams start with a back-office process and stop there. They show internal tasks—“validate claim,” “assign to agent”—but never show the customer placing the claim, receiving confirmation, or waiting for resolution.
That’s not a process model. That’s a system log, stripped of context.
Customer journey gaps in BPMN lead to models that are technically correct but irrelevant to business outcomes. If your process performance is measured in “minutes to resolve,” but customers are waiting days for updates, you’re measuring the wrong thing.
When you map the full customer journey, you uncover real bottlenecks: long wait times between steps, unclear communication, or lack of feedback loops. These aren’t just inefficiencies—they’re experience problems.
Modeling Customer in BPMN: The First Step
Start by asking: who owns the customer’s experience? Not IT, not operations. It’s the process itself—when modeled correctly.
Always begin collaboration diagrams with a customer pool. Even if the customer doesn’t perform any active tasks, their journey must be visible. Use a dedicated lane labeled “Customer” or “End Customer” to reflect their presence.
When you see a process that starts with “Agent receives request,” but never shows the customer sending it, you’ve found a classic customer journey gap in BPMN.
Adding a customer lane forces you to ask: what did the customer do before this step? Did they submit a form? Call a number? Log in? The answer shapes not just the flow, but the entire service model.
Adding Customer Touchpoints to BPMN: A Step-by-Step Approach
Customer touchpoints are not just activities—they’re moments of interaction, perception, and expectation. They’re where the process meets the user.
Here’s how to embed them meaningfully into BPMN collaboration models.
Step 1: Define the Customer Journey Sequence
Before touching a tool, sketch the customer’s journey on paper:
– What did they do before the process started?
– What do they expect at each stage?
– How do they receive updates?
Use this to identify critical touchpoints: submission, confirmation, feedback, resolution, complaint, follow-up.
Step 2: Add a Customer Pool or Lane
In your BPMN tool, add a new pool labeled “Customer” or “End User.” If the customer interacts with multiple departments, use lanes within that pool.
For example:
– Lane 1: “Customer” (initiates request)
– Lane 2: “Customer” (receives confirmation)
– Lane 3: “Customer” (provides feedback)
This visual separation makes responsibility and timing much clearer.
Step 3: Map Touchpoints with Message Flows
Use message flows to connect customer actions to internal processes:
  • “Customer sends form” → “System receives application”
  • “Customer receives email” → “Customer reviews status”
  • “Customer replies with documents” → “Agent reviews submission”
Message flows clearly show who initiates what, and when.
Step 4: Use Send and Receive Tasks to Model Interaction
Instead of generic “Task” nodes, use:
  • Send Task: “Send confirmation email to customer”
  • Receive Task: “Wait for customer confirmation”
  • User Task: “Customer completes form”
These tasks are not just about what the system does—they signal a moment of interaction.
Step 5: Align Internal Timing with Customer Experience
Now, ask: how long does it take the system to respond after the customer acts? If the customer submits a form, does the system send a confirmation in 5 seconds or 3 days?
Model this delay explicitly. Use a delay event or a message flow with a timestamp to show real-world latency.
This turns a technical workflow into a live experience model.
Common Mistakes in Adding Customer Touchpoints
Even with good intentions, teams often fall into traps that undermine the purpose of including customers in BPMN.
Mistake 1: Treating the Customer as a Passive Observer
Some modelers add the customer lane but make it contain only “Wait” or “Receive” steps. That’s not a journey—it’s a placeholder.
Instead, model what the customer does: submits data, reviews a document, confirms an action, gives feedback. Every action should be a visible task.
Mistake 2: Overlooking Asynchronous Touchpoints
Not all customer interactions happen in real time. Emails, SMS, or portal updates may take hours or days. But these delays are part of the journey.
Use a “Wait for Customer Response” task, with a timer or message event. This makes the delay visible and quantifiable.
Mistake 3: Modeling the Customer’s Journey as a Sub-Process
Some teams create a “Customer Experience” sub-process and hide it inside the main process. That’s a red flag.
Customer journey steps should be in the same model, not buried. If a sub-process is needed, use it only to group internal actions—never to hide the customer.
Mistake 4: Ignoring Emotional or Behavioral Triggers
Customers don’t just act—they react. A rejected application may trigger frustration, which leads to a complaint.
Add event sub-processes to model these reactions:
  • “Customer complains” → Trigger a complaint process
  • “Customer abandons form” → Trigger a recovery email
  • “Customer rates service” → Trigger feedback processing
These aren’t just error paths—they’re part of the experience.
When to Use Black-Box vs White-Box Customer Pools
Not every customer interaction needs full detail.
Purpose Use Black-Box Pool Use White-Box Pool
High-level overview
Internal team alignment
Customer experience design
Compliance or audit
Use a black-box pool when the customer’s internal steps are unknown or irrelevant—e.g., in a high-level process view.
Use a white-box pool when you’re modeling the full journey, especially for UX design, support optimization, or automation.
Never mix both in the same diagram unless you’re clearly separating layers.
How BPMN Process and Customer Experience Are Connected
There’s no such thing as a process without a customer. Even internal processes serve a user—whether it’s a manager, a department, or a system.
But if that user is not represented in the model, you’re not mapping a process—you’re mapping a technical workflow.
When you model the customer journey in BPMN, you’re not just documenting steps. You’re connecting process performance to real user satisfaction. Every delay, every error, every unmet expectation becomes visible.
That’s why adding customer touchpoints to BPMN is not an extra step. It’s the foundation of any meaningful process model.
How do I start modeling customer in BPMN when there’s no direct interaction?
Even if the customer doesn’t perform an action, they’re still part of the journey. Model the “Wait for Customer” or “Receive Input” step using a receive task. If they receive a communication (e.g., email), show it as a message flow from the customer pool.
Should I model customer feedback as a separate process or part of the main flow?
Model feedback as a loop or event subprocess. If feedback is rare, use a boundary event on the end task. If it’s a major phase, treat it as a separate subprocess that branches from the main flow.
Can I use BPMN to model customer journey for digital services like apps or websites?
Absolutely. Use pools for “User” and “System.” Model navigation steps as message flows. Use user tasks for actions like “enter email,” “select option,” or “submit form.” This makes UX and process alignment seamless.
What if the customer is external, like a partner or supplier?
Treat them as a separate pool, just like a customer. Use message flows to model their actions and responses. This preserves contractual boundaries and clarifies responsibilities.
How do I handle customer delays (e.g., a customer takes 3 days to reply)?
Use a “Wait for Customer Response” task with a timer event. Define the expected response window. If no reply, trigger a follow-up or escalation.
Is it okay to simplify the customer journey in a high-level BPMN diagram?
Yes—but only if you’re intentional. Remove details in a way that doesn’t hide responsibility or key touchpoints. Use a black-box pool and clearly label the interaction, e.g., “Customer provides input via portal.”
When you model the customer journey in BPMN, you’re not just adding steps. You’re restoring the human element to process design. Every model should answer: who is this for? What do they experience? How does this affect their trust, satisfaction, or decision to continue?
Fixing customer journey gaps in BPMN isn’t about adding more elements—it’s about re-anchoring your process models in reality. When you do, you create diagrams that don’t just run— they resonate.
