Coaching New Modelers: Teaching Good Habits Early
Estimated reading: 8 minutes 51 views
When a new modeler opens a BPMN tool for the first time, they don’t start with a blank canvas—they begin with a mental model shaped by past experiences, often built on sketchy flowcharts or hastily drawn process maps. I’ve seen this play out countless times: a junior modeler creates a diagram with no start event, uses a sequence flow to connect two pools without a message flow, and labels activities with vague verbs like “process” or “handle.” These aren’t just mistakes—they’re symptoms of a deeper issue: the absence of foundational structure.
What I look for in early modeling work isn’t perfection. It’s clarity of intent. Can someone unfamiliar with the process follow the logic? Does the model reflect real behavior, or is it a technical artifact dressed up as a business process? The most common red flag? Diagrams that look complex but fail the “5-second test” — where a stakeholder can’t grasp the purpose in under five seconds.
That’s where coaching BPMN modelers begins. It’s not about enforcing rules. It’s about building habits that prevent error before it’s even made. This chapter distills two decades of mentoring experience into actionable guidance for onboarding new modelers, using real examples, peer review practices, and structured feedback.
Start with the Fundamentals: What to Teach First
Never assume that a new modeler understands how BPMN is different from a flowchart. The first lesson must be: BPMN is a business modeling language, not a diagramming tool. Its symbols represent real business phenomena—events, decisions, responsibilities, and handoffs—each with precise semantics.
Begin with these core concepts, in order:
  • Start and End Events: Every process must have a clear trigger and a defined completion condition. A process that begins with a „Start” activity is not a BPMN process—it’s a work breakdown. Teach that the start event must be an event, not a task.
  • Flow Semantics: Sequence flows represent the order of execution. Message flows represent communication between parties. Never use sequence flows to represent communication across pools.
  • Gateways and Decision Logic: A gateway is not a “decision point.” It’s a control point that defines branching logic. Teach the difference between XOR, AND, and OR gateways with simple business examples.
  • Pools and Lanes: A pool defines a participant (department, system, partner). A lane defines a role within that participant. If the same person performs tasks in multiple roles, they belong in separate lanes.
These aren’t just rules—they’re foundational truths. Spend one full day on each concept. Let modelers practice by drawing simple scenarios like “customer order submission” or “loan application approval,” then review them together using a checklist.
Use Real Mistakes as Teaching Tools
One of the most powerful techniques I’ve learned is to present flawed examples not as failures, but as puzzles. Instead of saying, “This is wrong,” ask: “What happens if the customer doesn’t respond?” or “Who owns this task?”
For instance, show a diagram with a single lane containing all tasks, labeled “process,” “check,” “approve,” “send.” Ask: “Who is responsible for sending the email? What triggers the next step?” This forces modelers to question intent and identify missing ownership.
Use this same approach with common errors:
  • Mixed flow types: A sequence flow between two pools with a red dashed line. Ask: “Does a message travel through the air? What does this line actually mean?”
  • Missing end events: A process that ends with a task labeled “done.” Ask: “When does the process truly end? Is there a real completion condition?”
  • Vague activity names: “Handle request,” “update data.” Ask: “What exactly is being done? What outcome does this task produce?”
These are not rhetorical questions. They are diagnostic tools. Each reply reveals a gap in understanding. Use these moments to re-teach, not reprimand.
Pairing Juniors with Experienced Practitioners
Pairing is not about assigning a mentor to a modeler. It’s about creating a shared workspace where the junior models first, and the senior reviews, questions, and refactors in real time.
I’ve found the most effective pairing model is the “whiteboard shadow”:
  1. The junior draws the process from memory, based on a business requirement.
  2. The senior observes without speaking, then asks: “What triggers this step? Who owns it? How do you know it’s complete?”
  3. They co-edit the model, referring to the BPMN standard and real-world examples.
  4. They repeat with a different scenario—this time with the junior leading.
After three to five sessions, the junior begins to internalize the rhythm: intent first, notation second, validation last.
Encourage pairing across roles. A new modeler working with a business analyst learns how to translate business language into BPMN. A modeler paired with a developer learns how their diagram will be implemented—this builds empathy and prevents over-technical modeling.
Build a Mentorship Cycle
Set a simple feedback loop:
  • Modeler creates a diagram based on a real business scenario.
  • Pair reviews it using a shared checklist (see below).
  • Modeler revises it.
  • Both present it to a stakeholder (real or simulated).
  • Feedback is captured and used to refine the checklist.
This cycle embeds validation into the process. It also reveals gaps in training: if two modelers interpret the same scenario differently, that’s a sign the team needs a clearer standard.
Establishing a Lightweight BPMN Modeling Standard
After the first two weeks of training, introduce a minimal modeling standard. Not a 50-page document. A one-page cheat sheet that answers:
  • How to name activities: Verb + Object. “Approve loan application,” not “handle approval.”
  • How to label gateways: Clear, business-friendly condition. “Customer has valid ID?” not “Check 1.”
  • How to handle collaboration: Use message flows for communication. Sequence flows only within a pool.
  • When to use a sub-process: When a step contains more than three actions.
  • When to use a call activity: When reusing a logic pattern across processes.
Post this standard near workstations. Reference it in every review. Update it quarterly based on team feedback.
Key Checklist: Early Modeling Habits
Use this checklist during onboarding reviews. It’s not a pass/fail test—it’s a conversation starter.
Check Why It Matters
Has every process a start event? Without a trigger, the process has no defined entry point.
Are all end events properly defined? A missing end event means the process never terminates.
Are message flows used for cross-pool communication? Sequence flows across pools imply ownership confusion.
Are activity names descriptive and action-oriented? Vague names invite misinterpretation and rework.
Is responsibility clear via lanes? Unclear ownership leads to accountability gaps.
Review each item together. Ask: “What would happen if this weren’t true?” The goal is not to memorize, but to internalize intent.
How do I teach BPMN to someone with no business process experience?
Start with a real-world analogy: “Think of a BPMN diagram like a recipe. The ingredients are inputs. The steps are tasks. The oven is a gateway. The final dish is the end event.” Use simple diagrams—like “make toast” or “order a coffee”—to demonstrate notation and flow before introducing complex models.
What if the junior modeler insists on drawing everything as a single flat process?
Reframe it: “What if this process had 20 steps? Would you read it easily? Would someone else understand it in five seconds?” Then introduce the concept of decomposition: “Let’s group these steps into a sub-process. What’s the name of the group?” This builds the habit of breaking complexity into manageable parts.
How often should I review a new modeler’s work?
Three to five times in the first month. Focus on learning, not perfection. After that, shift to peer review and mentorship. The goal is to reduce dependency on you, not increase oversight.
Can I use AI tools to help train new BPMN modelers?
Yes—but cautiously. AI can generate plausible diagrams, but it often replicates common mistakes. Use AI outputs as teaching examples: “This looks good, but can you find the error?” This teaches modelers to think critically, not rely on automation.
How do I handle a modeler who resists feedback?
Ask: “What part of this feedback is unclear?” Then ask: “What would make this model better in your opinion?” This shifts the conversation from “you’re wrong” to “let’s build a better model together.” Often, resistance comes from feeling misunderstood, not uncooperative.
What’s the best way to measure progress in training new BPMN modelers?
Track two things: clarity and correctness. For clarity, ask a non-technical stakeholder to review a model and explain it in one sentence. For correctness, use the checklist above. After six weeks, compare progress. You’ll see patterns—not just skill, but mindset shifts.
