Unclear Process Boundaries and Handoffs
Estimated reading: 6 minutes 58 views
“Start and end your process clearly.” This advice is everywhere. But in practice, what does “clearly” mean? Too many models begin with “Receive request” and end with “Send response” — vague, unverifiable, and ambiguous. I’ve seen diagrams where the start event is just a vague “Process begins,” and the end event is “Done.” That’s not clarity — it’s a trap.
Unclear BPMN process boundaries undermine trust, confuse stakeholders, and sabotage automation. The real issue isn’t just missing start/end events — it’s the absence of preconditions, postconditions, and explicit handoff semantics. Without these, a model becomes a narrative, not a specification.
Here’s what you’ll learn: how to define process scope with precision, model handoffs between roles or systems with intent, and avoid the traps that turn BPMN into a guessing game. This isn’t theory — it’s what I’ve seen work across 150+ real-world process models, from insurance claims to IT service delivery.
Why Unclear Boundaries Break Models
When process boundaries are fuzzy, you’re not modeling a process — you’re describing a story. The audience can’t tell where the process begins, ends, or who’s responsible.
Common symptoms include:
  • Start events with no trigger — just “Start Process”
  • End events labeled “End” or “Done” without context
  • Activities with no inputs or outputs defined
  • Handoffs described as “pass to next team” without specifying what is passed
These aren’t minor oversights — they’re structural flaws that lead to misalignment between business and IT, failed automation, and audit failures.
Defining BPMN Process Scope with Precision
Every BPMN process must have a well-defined scope — a clear boundary between what’s inside and outside the model. This scope is defined by three pillars:
  1. Preconditions — What must be true before the process starts?
  2. Postconditions — What must be true when the process ends?
  3. Inputs and Outputs — What data or artifacts are consumed and produced?
These are not add-ons. They are the skeleton of your process.
How to Define Preconditions and Postconditions
Use the “Before” and “After” test. Ask: What changes does this process make?
For example, in a loan application process:
  • Precondition: A completed loan application form has been submitted with valid documentation.
  • Postcondition: The applicant receives a decision (approved/rejected) and a formal notification.
These are not arbitrary. They define the contract of the process. If you can’t state these clearly, you haven’t defined the scope.
Documenting Inputs and Outputs
Every process consumes and produces artifacts. Use data objects or annotations to make this visible.
Example:
  • Input: Loan Application Form (document)
  • Output: Loan Decision Notification (document)
Do not assume these are obvious. A “decision” may be a PDF, an API response, or a database update. Be specific.
BPMN Handoff Modeling Mistakes: The Silent Killer
Handoffs — the transfer of work between roles, systems, or departments — are where most process breakdowns occur. But many models treat them as invisible.
Common Handoff Errors
  • Using “Pass to next step” without naming the recipient
  • Using sequence flows between pools without message flows
  • Assuming the next step will “know what to do”
  • Modeling handoffs as tasks, not messages
These are not just design flaws. They create ambiguity in execution and debugging.
Correct Handoff Modeling: The 3-Step Rule
When transferring responsibility, always model it as a message flow between pools or lanes, not a sequence flow.
  1. Identify the sender and receiver — Who is passing what?
  2. Use a message flow — Draw a dashed arrow from sender to receiver.
  3. Label the message — Use a business-friendly name: “Loan Decision Approved,” “Customer Data Ready,” etc.
Example:
     [Loan Officer] --(Message: "Submit Decision")--> [Underwriter]
This isn’t just visual clarity. It’s a contract. The underwriter is only responsible for handling the message, not the entire process.
When to Use Sub-Processes for Handoffs
If the handoff is a complex task, consider modeling it as a call activity to a sub-process — especially if it’s reused across processes.
  • Use case: A “Credit Check” sub-process used in both loan and credit card applications.
  • Why: Avoids duplication, ensures consistency, and simplifies maintenance.
But don’t overuse it. If the handoff is a single, simple action, just label it clearly and use a message flow.
BPMN Boundary Best Practices: A Checklist
Here’s a practical checklist I use with teams to audit process boundaries. Run this on every model before review.
  • ✅ Is the start event triggered by a specific, well-defined event? (e.g., “Customer submits form via portal”)
  • ✅ Is the end event clearly tied to a postcondition? (e.g., “Decision sent to customer”)
  • ✅ Are inputs and outputs explicitly named and linked to activities?
  • ✅ Are handoffs modeled as message flows between pools or lanes?
  • ✅ Is every message labeled with a clear, business-meaningful name?
  • ✅ Does the process have preconditions and postconditions documented?
If any item is “No,” the model has a boundary issue — and it’s not ready for execution.
Real-World Example: Payroll Processing
Consider a payroll process that starts with “Receive timesheets.” Without scope definition:
  • Start: “Receive timesheets” — not clear what triggers this.
  • End: “Payroll sent” — no output defined.
  • Handoff: “Pass to finance” — who is that? What is passed?
Now, with scope defined:
  • Precondition: All employee timesheets for the pay cycle have been submitted and validated.
  • Postcondition: All employees have received their payroll payment and a payslip.
  • Input: Validated Timesheets (document)
  • Output: Paid Payslips (document)
  • Handoff: Send validated timesheets to Finance — [Message Flow]
Now the model is a specification, not a guesswork.
How do I define the start of a process if it’s triggered by a system event?
Use a message start event with a clear name: “Receive payroll data from HR system.” Always specify the source and the data type.
Can I use sequence flow for handoffs between departments?
No. Sequence flows imply control flow within a single process. For handoffs between roles, systems, or departments, use message flows between pools or lanes.
What if my process has no clear end event?
Every process must end. If it appears to loop indefinitely, ask: Is this a sub-process for a recurring task? Use a loop marker or model it as a reusable call activity. If it has no end, it’s not a process — it’s a system.
How do I handle handoffs to external systems?
Model the external system as a separate pool. Use a message flow to represent the handoff. Label it clearly: “Send customer data to CRM.” If the system is well-known (e.g., “PayPal”), you can label it as such.
Should I model handoffs at the activity level or the process level?
Model handoffs at the process level when the transfer involves different roles, departments, or systems. Use message flows to show who is responsible for what.
Can I use a single process for multiple handoffs?
Yes, but only if all handoffs are part of a single, coherent business goal. If you have distinct handoffs to different teams for different tasks, split them into separate processes or use a collaboration diagram to link them.
Remember: unclear BPMN process boundaries aren’t just a visual problem — they’re a functional one. A process with undefined scope is untestable, unverifiable, and unactionable. Fix the boundaries, and you fix the model.
