Epics, Features, and Stories: Understanding the Hierarchy
Estimated reading: 8 minutes 256 views
Most teams start by writing user stories in isolation—often treating each as a standalone task. But when scaling beyond a single team, this approach quickly becomes brittle. Without a structured hierarchy, alignment breaks down, dependencies multiply, and tracking value becomes nearly impossible.
My first decade in enterprise Agile taught me this: the real challenge isn’t writing stories—it’s organizing them so they reflect real business outcomes, connect across teams, and scale with clarity.
Here, you’ll learn how to use the epics-features-stories hierarchy not just as a classification system, but as a strategic tool for flow, traceability, and shared understanding. You’ll see how the agile hierarchy enables transparency, avoids requirement bloat, and ensures even complex systems deliver value incrementally.
By the end, you’ll know exactly how to break down large work, distinguish between an epic and a story, and build a backlog that scales with your organization—without adding bureaucracy.
The Foundation: Understanding the Agile Hierarchy
The epics-features-stories structure isn’t arbitrary. It reflects a natural progression from strategic vision to tactical execution.
Each level serves a distinct purpose:
  • Epics represent large bodies of work that deliver significant business value but can’t be completed in a single iteration.
  • Features are sub-components of epics—deliverable chunks that often span multiple teams or require integration.
  • User stories are the smallest unit of work, written from the user’s perspective and sized for delivery in a sprint.
It’s not just about size. It’s about intent. An epic isn’t just a “big story”—it’s a strategic initiative that may involve multiple teams, long-term planning, and cross-functional delivery.
Consider this: a single epic like “Enable 2FA across all customer-facing services” may include features such as “Implement 2FA login flow,” “Integrate with MFA provider API,” and “Update user onboarding guides.” Each feature is then broken into stories like “As a user, I want to receive a TOTP code via SMS so I can verify my identity.”
Why the Hierarchy Matters
Without a clear hierarchy, teams drift into siloed story writing. One team thinks they’re working on “login improvements,” another on “security enhancements,” and no one knows how these connect—until delivery fails.
The hierarchy acts as a shared map. It ensures that every story contributes to a feature, every feature to an epic, and every epic to a strategic goal. This is what enables traceability—the ability to answer: “What business value is being delivered, and how does this story support it?”
When teams align to this structure, planning becomes less about task completion and more about value delivery.
Breaking Down the Levels: Real-World Examples
Let’s take a concrete example from a banking application trying to modernize account access.
High-Level Epic
Epic: Upgrade to Multi-Factor Authentication (MFA) for all customer accounts
Value: Enhance security, reduce fraud, meet compliance requirements.
Feature-Level Breakdown
  • Feature: Implement SMS-based MFA for login
  • Feature: Integrate with third-party MFA provider (e.g., Twilio)
  • Feature: Add fallback authentication via recovery codes
  • Feature: Update user onboarding flow to include MFA setup
Each feature is independently testable, deliverable in a sprint, and owned by a specific team or pair of teams.
User Story Examples
For the feature “Implement SMS-based MFA for login”:
  • As a customer, I want to receive a 6-digit code via SMS when I log in, so I can verify my identity.
  • As a customer, I want to re-request the code if I don’t receive it within 60 seconds, so I’m not locked out.
  • As a customer, I want to see a countdown timer before I can re-send the code, so I don’t spam the system.
Notice how each story focuses on a single user action and outcome. No technical jargon. No assumptions.
Agile Hierarchy vs. Agile Bloat: Avoiding the Epic Trap
I’ve seen teams write 500+ epics in a single backlog. Not because they were large, but because they didn’t understand what an epic truly is.
A common mistake: treating every large story as an epic. That’s not how it works.
Key rule: An epic should represent a strategic initiative, not just a big story. If you’re breaking down a story into 20 smaller ones, you might need a feature—or even an epic—between the two.
Ask yourself: “Can this be delivered in a single sprint or release?” If not, it likely belongs in a higher category.
Here’s a simple decision tree:
  1. Does it deliver significant business value? → Yes → Consider an epic.
  2. Can it be completed in one sprint? → Yes → Write as a feature.
  3. Is it a single user action with a clear outcome? → Yes → Write as a story.
Use this to avoid the epic vs story difference confusion.
Practical Guidelines for Maintaining the Hierarchy
Structure alone isn’t enough. The hierarchy must be maintained with discipline.
1. Use Consistent Naming Conventions
Standardize prefixes to signal category:
  • Epic: Enable secure login for all customers
  • Feature: Add SMS-based 2FA
  • Story: As a user, I want to receive a code via SMS so I can verify my identity
Teams that use this approach report 30% faster backlog refinement and fewer alignment meetings.
2. Link Stories to Features, Features to Epics
Every story must reference its parent feature. Every feature must link to its epic.
3. Reassess at PI Planning
At each Program Increment (PI), review your epics. Are they still valid? Are dependencies resolved? Should any be split or merged?
Some epics become obsolete. Others may need to be broken into smaller initiatives. Regular reassessment prevents stagnation.
4. Avoid Over-Granularity
Don’t create stories like “Add a button to the screen.” It’s not a story—it’s a task.
Every story must deliver user value. Ask: “Who benefits? What do they gain?” If you can’t answer clearly, it’s likely not a story.
Common Mistakes and How to Avoid Them
Even experienced teams struggle with this hierarchy. Here are the most frequent issues:
  • Epics too small: A “Build login page” epic doesn’t deliver business value. Break it into features like “Design login flow” and “Integrate with auth service.”
  • Stories too large: “As a user, I want to log in securely” is too broad. Split into specific interactions: code receipt, retry logic, etc.
  • Missing traceability: Without links between epics, features, and stories, it’s impossible to report on value delivery.
  • Ownership confusion: Features often involve multiple teams. Clarify which team owns which aspect of the feature.
Fix these through peer reviews, sprint retrospectives, and regular backlog health checks.
Summary: The Three-Part Framework for Scaled Agility
Use this model to structure any large-scale backlog:
Level Size Owner Delivery Time Focus
Epic Large Product Management / Enterprise Several PI (6–12 weeks) Strategic Value
Feature Medium Feature Team / Squad 1–2 Sprints Integrated Functionality
User Story Small Development Team 1 Sprint User-Centric Value
When teams use this, they stop chasing work and start delivering outcomes.
What’s the difference between an epic and a user story?
An epic is a large body of work that delivers significant business value and typically spans multiple sprints or PI. A user story is a small, testable unit of work from the user’s perspective, designed to be completed within a single sprint. The epic vs story difference lies in scale, scope, and delivery timeframe.
Can a user story be an epic?
No. A user story is the smallest unit of work and should represent a single, deliverable user action. If a story is too large to be completed in a sprint, it should be split or elevated into a feature or epic.
How do I know when to create a new feature instead of a story?
Create a feature when you have a group of related user stories that collectively deliver a cohesive capability. Features are often owned by a single team and require integration testing. If the stories can be delivered independently and serve a single user role, they can remain as stories.
Can an epic include multiple features?
Absolutely. Epics are composed of features. Think of an epic as a container for multiple features that together deliver a strategic outcome.
Should every story be linked to an epic?
Yes, in a scaled environment. Every story should trace back to a feature, and every feature to an epic. This ensures alignment with strategy and enables value reporting.
How do I manage dependencies between stories in different epics?
Visualize dependencies using dependency maps or story mapping. Flag high-risk dependencies early. Use cross-team sync meetings or PI planning to negotiate timelines and coordination.
Mastering the epics-features-stories hierarchy isn’t about documentation. It’s about creating a shared mental model that keeps teams aligned, focused, and delivering real value—no matter how large the organization.
Start small. Use the structure. Refine it. Let it grow with your teams.
