Cross-Notation Glossary and Mapping Reference
Most analysts struggle not with the diagrams themselves, but with the mental shift between two fundamentally different ways of seeing systems. One sees data in motion; the other sees objects in action. The real challenge isn’t learning both notations—it’s understanding how to translate them. This page isn’t a dictionary of symbols. It’s a practical bridge between worlds. In my 20 years working with cross-functional teams, I’ve found that the single biggest barrier to successful modeling isn’t complexity—it’s confusion over terminology. When a „process“ in DFD becomes a „use case“ in UML, and a „data store“ becomes a „class,“ misalignment happens instantly. This glossary resolves that friction. You’ll gain a shared vocabulary to align developers, business analysts, and architects. It’s the essential reference for anyone building models across both DFD and UML.
Core Mapping: Translating DFD Elements to UML
Understanding how elements map across notations is the key to seamless collaboration. The same system can be viewed through different lenses. Here’s the foundational mapping.
DFD Process ↔ UML Use Case
A DFD process represents a transformation of data. It takes inputs, applies logic, and produces outputs. In UML, this maps directly to a use case—a goal-driven interaction between a user (actor) and the system. The distinction lies in focus: DFD highlights *what* data changes, UML highlights *why* the interaction happens.
Example: A DFD process labeled „Calculate Customer Balance“ corresponds to a UML use case named „Generate Account Statement.“ The function is identical, but the stakeholder intent differs.
DFD Data Store ↔ UML Class (with Persistence)
Data stores represent persistent data—files, databases, or queues. In UML, this maps to a class with attributes and persistence. However, not all classes are data stores. Only those with a clear role as a data repository qualify.
Key distinction: A class like „Customer“ may not be a data store unless it’s the primary repository. A „Transaction Log“ file is a data store. The class representing it in UML must include persistence semantics.
DFD External Entity ↔ UML Actor
External entities are sources or sinks of data. UML’s actors represent roles—typically users or other systems—that initiate interactions. The mapping is direct, but the intent differs.
Example: A „Bank“ as an external entity in DFD becomes the „Bank“ actor in UML. But the UML actor may also carry responsibilities like „validate transaction“ or „trigger audit,“ which aren’t captured in DFD.
DFD Data Flow ↔ UML Message / Association
Data flows are the lifeblood of DFDs. They represent data moving between processes, data stores, and external entities. In UML, this becomes a message in a sequence diagram or an association in a class diagram.
When modeling interactions, a data flow like „Customer Order“ becomes a message in a sequence diagram: „Customer sends Order to OrderProcessor.“ In a class diagram, it appears as an association between „Customer“ and „Order“ with multiplicity.
DFD Data Flow (in Context Diagram) ↔ UML Use Case (in Use Case Diagram)
At the system boundary, DFD context diagrams show external entities and data flows. UML use case diagrams show actors and use cases. The data flow between a system and an external entity maps to a relationship between actor and use case.
For example, a „Submit Claim“ data flow from a „Patient“ external entity becomes a „Patient“ actor invoking the „File Insurance Claim“ use case. The flow direction is preserved.
Common Confusion Points: Terminology That Misleads
These terms appear similar but mean different things in context. Confusing them leads to model drift and communication breakdown.
“Process” vs. “Use Case”
Both appear as a rounded rectangle. But a DFD process is *functionally defined*—it transforms data. A UML use case is *goal-oriented*—it describes a user’s objective. A process may not involve a user at all. A use case always involves an actor.
“Data Store” vs. “Class”
All data stores are classes in UML, but not all classes are data stores. A class like „Payment“ may be a data object, but unless it’s persistent and stored, it doesn’t map directly to a data store. The key is persistence, not just existence.
“Data Flow” vs. “Message”
Data flow is a *stateless transfer of data*. Message is a *synchronous or asynchronous request* between objects. A data flow can become a message, but only when the interaction is behaviorally significant. A read from a file is a data flow. Sending an email to trigger a process is a message.
Visual Paradigm Element Linking Guidance
When using Visual Paradigm, you can create live links between DFD and UML elements. This ensures consistency and enables traceability.
- Link a DFD process to a UML use case using the „Traceability“ feature. Right-click the DFD process → „Create Traceability“ → select the corresponding use case.
- Link a DFD data store to a UML class with a „Persistence“ stereotype. In the class, add
«persistence»and link the data store via the „Related to“ property. - Use cross-diagram navigation: Open a DFD, select a data flow → click „Navigate to“ → choose the corresponding UML message or association.
When Mapping Fails: What to Avoid
Mapping is a tool, not a rule. Misuse leads to oversimplification or over-engineering.
- Don’t map every process to a use case. Some processes are internal transformations (e.g., „Validate Input“) that don’t represent user goals. These belong in UML activity or sequence diagrams, not use case diagrams.
- Don’t treat every class as a data store. A class like „OrderItem“ may be part of an object model but not a persistent data store. Only map to data stores if the class represents a file or database table.
- Don’t assume one-to-one mapping. A single DFD process can break into multiple UML use cases. A single UML use case may involve multiple DFD processes.
Summary Table: DFD to UML Mapping Reference
This table is your quick-reference guide for translating between DFD and UML elements.
| DFD Element | UML Equivalent | Key Considerations |
| Process | Use Case (goal-driven) | Only if the process represents a user goal. Otherwise, use activity or sequence diagram. |
| Data Store | Class with «persistence» stereotype | Only if the class is a data repository. Not all classes qualify. |
| External Entity | Actor | Role of user or system. Must be assigned responsibilities. |
| Data Flow | Message (sequence), Association (class) | Represents data transfer. Context determines which UML element. |
| Process (in DFD Level 0) | Use Case (in use case diagram) | High-level interaction. Map to top-level use cases. |
Can I use DFD and UML in the same project?
Yes. In fact, it’s best practice for large systems. Use DFD for data flow analysis in early phases, then UML for detailed design. Maintain traceability between elements.
Is the DFD UML mapping reference always accurate?
It’s accurate when applied with context. Mapping is a tool, not a rule. Always validate: Does the UML element reflect the intended behavior and intent of the DFD element?
How do I handle multiple DFD processes in one UML use case?
Group them under one use case. Use an activity diagram to show internal logic. The DFD processes map to activities, not separate use cases.
Can I convert a DFD to UML automatically?
Tools like Visual Paradigm support basic mapping, but manual validation is essential. Automation helps with structure, not semantics.
Why is cross notation terminology important in team settings?
It prevents miscommunication. Business stakeholders think in data flows. Developers think in objects. A shared vocabulary ensures alignment and reduces rework.
Do I need to learn both DFD and UML to use this glossary?
Yes. This glossary assumes familiarity with both notations. If you’re learning one, start with it. The glossary helps you transition to the other, not replace it.
Ultimately, the goal of this DFD UML glossary isn’t just to define terms—it’s to build a common language between analysts, architects, and developers. When your team speaks the same modeling dialect, complexity becomes clarity. That’s the real power of unified modeling vocabulary.
