Project Kickoff Notation Checklist
Geschätzte Lektüre: 5 Minuten 61 Ansichten
In my 20 years of guiding teams through system modeling, I’ve seen the same mistake repeat in nearly every project: picking a notation before understanding the actual problem. I once led a healthcare system initiative where a team chose UML without assessing data flow complexity—only to discover post-deployment that patient record transfers were misaligned. The fix required a full rework of the business logic, costing months. The real issue wasn’t in the tools—it was that no one paused to evaluate the core nature of the system’s data movements versus object behaviors. That’s why this 18-point notation checklist exists: to help you make a deliberate, evidence-based decision before a single diagram is drawn.
Use this checklist to evaluate whether DFD or UML better suits your project’s requirements, team capabilities, compliance needs, and stage in the lifecycle. Each question is grounded in real projects, not theory. Answer honestly. Score each response to reveal a clear recommendation.
18-Point Notation Selection Checklist
For each question, assign a score from 1 to 5:
  • 1 = Strongly Disagree
  • 2 = Disagree
  • 3 = Neutral
  • 4 = Agree
  • 5 = Strongly Agree
Requirements Characteristics
  1. Is the primary goal to understand how data moves through the system and transforms across processes?
    Score: 1–5
  2. Are most system stakeholders business analysts, auditors, or compliance officers rather than software developers?
    Score: 1–5
  3. Does the system involve batch processing, data warehouse pipelines, or regulatory reporting flows (e.g., SOX, HIPAA, PCI-DSS)?
    Score: 1–5
  4. Is the workflow governed by data dependencies rather than object state or user interactions?
    Score: 1–5
Team Skills and Culture
  1. Does the team have strong experience with structured analysis and data flow decomposition?
    Score: 1–5
  2. Is the team primarily composed of developers with object-oriented training or experience in UML modeling?
    Score: 1–5
  3. Is there resistance or confusion when using UML diagrams in stakeholder meetings?
    Score: 1–5
  4. Are there established enterprise modeling standards favoring DFD or UML?
    Score: 1–5
Compliance and Lifecycle Stage
  1. Is this a legacy modernization project where you’re reverse-engineering a procedural system?
    Score: 1–5
  2. Is the system subject to audit requirements that demand traceable data lineage from source to output?
    Score: 1–5
  3. Is the project in the early requirements phase and focused on gathering data exchange needs?
    Score: 1–5
  4. Will this system be used in real-time or embedded environments with timing-critical behavior?
    Score: 1–5
System Complexity and Design Intent
  1. Is the core logic centered around data transformations (e.g., financial calculations, data cleansing, report generation)?
    Score: 1–5
  2. Does the system involve complex object lifecycles, state changes, or message exchanges between services?
    Score: 1–5
  3. Is the system designed as a microservices architecture with independent, collaborating components?
    Score: 1–5
  4. Are there multiple external partners or systems exchanging data in a distributed, non-interactive way?
    Score: 1–5
Scoring and Recommendation Mapping
Sum your scores across all 18 questions. Use the following guide to determine the most suitable notation for your project:
Total Score Recommended Notation Guidance
18–30 Data Flow Diagram (DFD) Strongly prioritize DFD. The system is data-centric, audit-focused, or in early analysis. Use DFD Level 0 (context) to begin.
31–40 Hybrid: DFD + UML Both notations are valid. Use DFD for end-to-end data flows and UML for detailed design. Ensure traceability between models.
41–50 Unified Modeling Language (UML) Object behavior and collaboration dominate. The system requires state modeling, real-time behavior, or complex interactions.
Pro Tip: If your score falls near a boundary (e.g., 30 or 40), consider a dual-notation approach. Start with DFD to validate data flow, then use UML to detail system behavior. This is standard in financial systems, healthcare workflows, and enterprise software.
Remember: DFD doesn’t preclude UML—it complements it. The key is not which tool is better, but which one aligns with your system’s actual purpose. When you start with clarity, your model becomes a true representation of the system, not just a diagram.
Should I use DFD or UML for a financial transaction system?
For most financial systems, DFD is ideal in early phases for auditability and end-to-end transaction flow. Use UML only for detailed design of transaction validation logic or real-time risk checks. A hybrid approach with a DFD context diagram and UML sequence diagrams is optimal.
Absolutely. Many teams use DFD for business analysis and UML for development. The key is traceability: link DFD processes to UML use cases and data stores to classes. Tools like Visual Paradigm support this cross-referencing.
What if my team prefers UML but the project is data-heavy?
Start with DFD for initial requirements gathering. Then, use UML to model the implementation. This reduces misalignment and ensures business stakeholders understand the data path before developers dive into object design.
Is DFD still relevant in the era of microservices?
Yes. DFD excels at mapping data flows between microservices, especially when services exchange data via file, message queues, or APIs. It provides clarity that UML alone often lacks in distributed systems.
Do I need to learn both DFD and UML to use this checklist?
No. This checklist helps you determine which one to focus on. If your system is data-driven, prioritize learning DFD. If it’s object-driven, focus on UML. The checklist guides your learning path, not your workload.
Can I use this checklist for non-technical stakeholders?
Yes. Share the questions with stakeholders and gather feedback. Their answers reveal whether the system is driven by data logic or interaction logic. This insight is more valuable than any diagram.
© 2024 Data Flow Diagrams vs. UML: When to Use Each. All rights reserved.
