The Language of DFDs: Symbols, Conventions, and Standards
Geschätzte Lektüre: 8 Minuten 189 Ansichten
One of the most common early missteps I see in novice modelers is not recognizing that a broken DFD isn’t always a flaw in logic—it’s often a failure to speak the language consistently. A single misused symbol or inconsistent flow direction can create confusion, even if the underlying process is correct. This happens because DFDs are not just diagrams—they’re a formal language. The moment you deviate from agreed-upon DFD symbols, the model loses its precision and becomes a barrier to communication.
For over two decades, I’ve worked with teams across banking, healthcare, and government sectors where misunderstandings between business analysts, developers, and stakeholders stemmed not from poor ideas, but from poor notation. The fix? Commit to a consistent, well-documented set of DFD symbols and conventions from day one. This chapter gives you the exact tools to do that—grounded in real-world experience, aligned with Gane & Sarson and Yourdon standards, and designed to make your diagrams both accurate and maintainable.
Core DFD Symbols: The Building Blocks
Every DFD begins with four foundational elements: processes, data stores, external entities, and data flows. These are not arbitrary symbols—they are standardized representations of system behavior and data movement.
Process: The Engine of Transformation
Processes represent actions that transform input data into output. They are always represented as rounded rectangles—never circles or squares. The key is that every process must have at least one input and one output flow.
Why this matters: I once reviewed a DFD where a process had no inputs. The developer claimed it “generated data from nothing.” That’s not a process—it’s a contradiction in logic. Even in a hypothetical system, the data must come from somewhere. The process symbol enforces this rule.
Labeling should be in imperative verb form: “Calculate total,” “Validate user input,” “Generate report.” This ensures consistency and avoids ambiguity.
Data Store: The Persistent Memory
The data store symbol—two parallel horizontal lines with a rectangle above—represents a collection of data that persists over time. It is not a database in the technical sense, but a logical holding area for data.
The data store symbol meaning is critical: it signifies data that is not transient. If data moves through a process and disappears, it’s not stored. If it remains available across multiple transactions, it’s stored.
Common mistake: Drawing data stores as databases. The symbol is abstract. Use it for “Customer Records,” “Invoice Log,” or “Pending Approvals”—not “MySQL Table Orders.” This preserves model integrity.
External Entity: The Source and Sink
External entities (also called actors) are represented by small, square boxes with a label. They represent stakeholders or systems outside the scope of the current DFD.
They are not processes. They cannot act on data—they only send or receive. A user clicking a button is not a process; the action of submitting data is.
If your system receives data from a third-party API, the API is an external entity. If a report is emailed to a manager, the manager is an external entity.
Data Flow: The Path of Movement
Data flows are arrows showing the direction of data movement. The arrowhead is always pointed at the destination.
Every flow must connect a source (process, data store, or external entity) to a destination (process, data store, or external entity). Arrows should never loop back to their source without a clear operational reason.
Flow labels are critical. Not just “data,” but “customer order details,” “payment confirmation,” or “user login request.” Vague labels lead to ambiguity and inconsistent interpretation across teams.
DFD Conventions: The Unwritten Rules
While the symbols are standardized, the way they are applied is governed by a set of conventions. These are not rigid rules, but best practices that ensure clarity and consistency.
  • Left-to-right flow: It’s best practice to design flows from left to right. This aligns with how most people read—top to bottom, left to right. Avoid diagonal or circular data flows unless absolutely necessary.
  • Use of arrows: Arrows should not cross each other. When unavoidable, break the flow into segments or reorganize the layout to maintain readability.
  • Process numbering: In higher-level DFDs, use numbers (e.g., 1.1, 2.3) to maintain traceability when decomposing. This is especially useful for auditing or version control.
  • Consistent labeling: Use the same term for the same data across all levels. If “Order Details” is used in Level 1, don’t call it “Order Items” in Level 2. This ensures consistency and avoids confusion.
Why DFD Conventions Matter
When I worked on a financial system audit, we found that three different analysts used different terms for the same data element—“Invoice,” “Bill,” and “Statement.” The data flow diagram notation wasn’t wrong, but the inconsistency caused major delays during integration. Had they followed a consistent labeling convention from the start, the entire project would’ve been more efficient.
These conventions are not about aesthetics. They are about minimizing ambiguity. A DFD is not just a diagram—it’s a contract between developers, analysts, and stakeholders.
Comparing Notation Standards: Gane & Sarson vs. Yourdon
Two major standards govern DFD notation: Gane & Sarson and Yourdon. They are functionally equivalent but differ in visual style.
Element Gane & Sarson Yourdon
Process Rounded rectangle with process number Circle with process name
Data Store Two parallel lines with box above Two parallel lines with label inside
External Entity Small rectangle Small rectangle with a label
Data Flow Arrow with label Arrow with label
Both standards are valid. The key is consistency. If your team uses Gane & Sarson, stick with it across all diagrams. Don’t mix styles within the same model.
My advice: Choose one standard and document it in your team’s modeling guide. This prevents confusion and ensures all new members can contribute accurately from day one.
Data Flow Diagram Notation in Practice
Let’s walk through a real-world example: a university registration system.
Level 0 (Context Diagram): The external entities are “Student” and “Registrar System.” The process is “Register Student.” Data flows: “Registration Form” (from student to process), “Enrolled Course List” (from process to registrar).
Level 1: Break down “Register Student” into sub-processes:
  • “Validate Student Eligibility” – input: “Student Record,” output: “Eligibility Status”
  • “Check Course Availability” – input: “Course List,” output: “Available Courses”
  • “Enroll Student in Course” – input: “Available Courses,” output: “Enrollment Confirmation”
Notice how each process has at least one input and one output. The data flow “Eligibility Status” is not arbitrary—it’s a specific data object defined in the data dictionary.
This example illustrates how DFD symbols and conventions work together to enforce logic. You can’t have a process that consumes data but produces nothing. That violates the principle of data balance.
Even experienced modelers make these mistakes. Here’s how to avoid them:
  1. Creating processes with no inputs: Every process must have at least one input. If a process seems to generate data from nothing, re-evaluate: is there a data store or external entity providing the base data?
  2. Confusing data stores with data flows: A data store holds data over time. A flow is movement. If data is being transferred, it’s a flow. If it’s being preserved, it’s a store.
  3. Using the same label for different data objects: “Invoice” might mean a document in one context and a number in another. Use precise, unambiguous labels.
  4. Overloading processes with too many flows: If a process has more than 5–6 flows, it’s likely too complex. Decompose it into smaller, focused processes.
Remember: clarity isn’t just about looking good. It’s about being interpretable by people who didn’t build the model.
What is the correct symbol for a data store in DFD notation?
The data store symbol is two horizontal parallel lines with a rectangle or label above. It represents a persistent collection of data. The symbol is consistent across both Gane & Sarson and Yourdon conventions.
Can data flows connect to external entities only?
No. Data flows can originate from or terminate at a process, data store, or external entity. A flow from process to data store means data is being written. A flow from data store to process means data is being read.
How do I choose between Gane & Sarson and Yourdon conventions?
Choose based on your organization’s standard. Gane & Sarson is more common in business analysis. Yourdon is often used in academic settings. Pick one and apply it consistently.
Why is the data store symbol meaning so important to understand?
Because it defines data persistence. If you think a data store is just a database, you’ll incorrectly model transient data as stored. Understanding the data store symbol meaning ensures you represent data correctly across time.
Do DFDs require a data dictionary?
Yes. A data dictionary defines every data flow, data store, and process. It’s essential for DFD consistency, especially during balancing and decomposition.
What’s the difference between a process and an external entity?
A process performs work on data. An external entity sends or receives data but does not process it. For example, a “Student” is an external entity; “Validate ID” is a process.
