Bridging Data Flow and Database Design Using ERD
Geschätzte Lektüre: 7 Minuten 62 Ansichten
When modeling systems, the flow of data through processes must align with how that data is stored. The leap from DFD to ERD isn’t a leap in logic—it’s a translation. Every data flow you model represents a real-world entity or relationship. I’ve seen teams miss critical entities because they treated DFDs as isolated process maps, not as blueprints for database design.
The rule is simple: if a data item appears consistently in multiple flows and isn’t a transient value, it’s likely an entity. This principle holds whether you’re modeling a retail inventory system or a hospital admissions workflow. The key is learning to read flows like a database architect.
This chapter guides you through translating logical DFDs into a robust ERD. You’ll learn how to extract entities, identify relationships, and avoid common pitfalls that distort structure. You’ll gain the ability to trace data from flow to schema with confidence—no guesswork, just method.
From Flow to Entity: The Core Translation Rule
Identify persistent data items across flows
Start by reviewing input and output flows in each process. Ask: “Is this data item created, modified, or referenced across multiple processes?” If yes, it may represent a persistent entity.
For example, a flow labeled “Customer Order Details” likely includes a customer ID, order date, and status. These are not transient; they’re persistent. That’s a red flag: these items belong in a table.
Use a checklist to validate:
  • Does the data appear in multiple processes?
  • Is it used for decision-making or reporting?
  • Does it have attributes (e.g., name, address, ID)?
If two or more items pass, they’re candidates for entity modeling.
Normalize with flow behavior
Not every flow that seems like a table actually is. A flow like “Payment Confirmation” might seem to represent a table, but if it only contains transient data (e.g., “Payment processed successfully”), it’s a message, not an entity.
Use flow context to decide:
Flow Example Entity? (Yes/No) Rationale
Customer Order Yes Contains ID, date, status—consistent across processes
Order Processing Message No Transitory notification; no persistent attributes
Invoice Approval Yes Has approval timestamp, approver ID, status
Only flows with attributes that persist across time belong in the database.
Mapping Flows to Relationships
Trace data dependencies to discover relationships
Relationships in ERD emerge not from guesswork—but from how data flows between processes.
For example, if Process 2.1 “Process Order” consumes “Customer Order” and produces “Invoice,” and Process 2.2 “Generate Invoice” uses the same “Customer Order” data, then both processes depend on the same entity. That’s a clue: the invoice is related to the order.
Ask: “Does the output of one process become input to another via a shared data item?” If yes, you’ve found a relationship.
Use cardinality from flow volume
Cardinality isn’t arbitrary. Look at flow volume and frequency:
  • If one “Customer Order” creates multiple “Order Items,” the relationship is one-to-many.
  • If “Payment” is always tied to one “Order,” it’s a one-to-one or one-to-many (depending on whether a payment can apply to multiple orders).
Use real-world rules to define cardinality. A system that allows partial payments on a single order implies one-to-many.
Build relationships step by step
Start with the most stable flows—those that recur across processes. Then map their dependencies. Example:
  1. Identify “Order” as an entity from flows in “Create Order” and “Process Order.”
  2. Find “Order Item” as a sub-component of “Order” in “Add Item to Order.”
  3. Link “Order” to “Payment” via “Payment for Order” flow.
  4. Verify: Can one order have multiple payments? Yes → one-to-many.
This logical flow from DFD to relationship is how you build trust in your model.
From DFD to ERD: A Step-by-Step Translation Guide
Here’s how I’ve successfully guided teams from DFDs to ERDs in real projects:
  1. Extract entities from data flows that contain persistent attributes.
  2. Map attributes by analyzing which data items appear consistently in flows.
  3. Draw relationships based on shared data between processes.
  4. Apply cardinality using business rules and flow frequency.
  5. Validate with data structure from DFD—ensure no flow implies a missing entity or incorrect relationship.
One client tried skipping step 2. Their model missed the “Payment” entity because payments weren’t isolated in a flow—they were embedded in “Process Order.” After re-examining flows, they found the payment data was passed between processes. That was the cue to create the entity.
Assuming all flows are entities
Not every data flow corresponds to a database table. Transient flows like “Error Message” or “System Response” are messages, not entities. They don’t persist and aren’t stored.
Fix: Use the “persistent data” test. If it’s not stored, it’s not an entity.
Mistaking flows for relationships
A flow like “Customer Order” might look like a relationship, but it’s actually a data structure. The relationship is between “Customer” and “Order,” not the flow itself.
Fix: Use the flow to identify the two entities involved. Then determine how they connect.
Overcomplicating cardinality
Cardinality should reflect business rules, not flow complexity. A flow with multiple data items doesn’t mean multiple relationships.
Fix: Ask: “Can one X have many Y?” If yes, it’s one-to-many. If only one, it’s one-to-one. If no, recheck the flow.
Real-World Case: Retail Order System
Consider a DFD model of a retail system. Key flows include:
  • “Customer Order”
  • “Order Line Items”
  • “Payment Details”
  • “Shipping Address”
From these, we extract:
  • Customer – from “Customer Order” and “Shipping Address”
  • Order – from “Customer Order” and “Order Line Items”
  • Order Line Item – from “Order Line Items”
  • Payment – from “Payment Details”
Relationships:
  • Customer → Order (one-to-many)
  • Order → Order Line Item (one-to-many)
  • Order → Payment (one-to-many)
This mapping preserves the logical flow while creating a normalized database structure. The DFD told us what data was moving. The ERD tells us how to store it.
How do I know which DFD flows to turn into ERD entities?
Only flows that contain persistent, named data items should become entities. Ask: “Is this data stored, referenced, or used in decisions?” If yes, model it as an entity. Transient flows like “System Error” or “Processing Complete” are not.
Can I build an ERD directly from a Level 1 DFD?
Yes—but only if the DFD is logically complete and the data flows are well-defined. Level 0 (context diagram) contains too little detail. Use Level 1 or Level 2 for meaningful mapping. Avoid skipping levels.
What if a data flow appears in multiple processes but doesn’t seem to represent an entity?
Re-examine the data. If it’s a list of values (e.g., “Product List”), it may be a lookup table. If it’s a transaction record (e.g., “Invoice”), it’s an entity. If it’s a message (e.g., “Payment Verified”), it’s not. Focus on persistence, not just appearance.
How do I validate that my ERD fully reflects the DFD?
Use a traceability matrix. List every data flow in the DFD and map it to the corresponding entity or relationship in the ERD. Ensure all flows are accounted for and no entity is implied but missing.
What if the DFD shows a flow that doesn’t map to a database table?
That’s okay. Some flows are transient—like confirmation messages or error logs. They don’t require storage. But if they carry data that’s used in later processes, they may imply a need for a table. The key is to ask: “Does this data persist?”
Should I use the same naming for DFD flows and ERD entities?
Yes, but with care. Use consistent naming (e.g., “Customer Order” → “Order”) but ensure it reflects database conventions (e.g., singular for tables). Avoid “process” in names—focus on data, not action.
