Writing Stories That Can’t Be Tested
Время чтения: 7 мин. 63 просмотров
A user story that can’t be tested is a story that has already failed. I’ve seen teams commit to features that no one can verify, only to discover weeks later that the outcome didn’t match the intent. The root cause? Vague acceptance criteria. The fix? Rewriting with concrete, testable conditions.
Testability isn’t a bonus—it’s the baseline. If a story can’t be tested, it can’t be delivered. I’ve worked with teams who thought “I’ll know it when I see it” was enough. It’s not. The moment you say that, you’ve invited ambiguity, rework, and misaligned expectations.
This chapter shows you how to diagnose a story that can’t be tested, rewrite it using criteria-based story writing, and ensure test scenario coverage from day one. You’ll learn how to define acceptance not as a wish, but as a contract.
Why stories become untestable
Untestable stories aren’t born—they’re built. They start with a vague goal, a fuzzy “I want it to work,” and a lack of shared understanding. The problem isn’t the story format. It’s the absence of measurable outcomes.
When acceptance conditions are missing or ambiguous, developers guess. QA tests become heuristic. The product owner can’t say “yes” or “no.” The team ships something that doesn’t solve the real problem.
Here’s a common pattern: a story says “The system should be fast.” That’s not testable. Speed is relative. What’s fast? 1 second? 500ms? On what device? With what load?
Another red flag: stories that rely on subjective terms like “user-friendly,” “seamless,” or “intuitive.” These may describe experience, but they can’t be tested. A story must define success in objective, observable terms.
Common traits of untestable user stories
  • Uses vague verbs: “improve,” “enhance,” “optimize”
  • Relies on subjective adjectives: “easy,” “fast,” “beautiful”
  • Lacks measurable outcomes or acceptance criteria
  • Describes behavior but not the expected result
  • Implies a feature without defining what “working” means
How to rewrite untestable stories with testable acceptance
Every user story must answer one question: “How will we know it’s done?” If you can’t answer that, the story isn’t testable.
Start by asking: “What does success look like?” Then write it down. Use the Given-When-Then format to structure testable acceptance criteria.
Here’s a real example from my experience: a team wrote:
As a user, I want the dashboard to load quickly so I can see my data.
That’s untestable. Now, here’s how we fixed it:
Step-by-step rewrite using criteria-based story writing
  1. Identify the core behavior: The dashboard must load after a user logs in.
  2. Define measurable outcomes: Load time must be under 2 seconds on a standard desktop.
  3. Create acceptance criteria using Given-When-Then:
    • Given the user is logged in and on the dashboard page,
    • When the page loads,
    • Then the total load time must be less than 2 seconds.
  4. Validate testability: Can a QA engineer run this test? Yes. Is the threshold clear? Yes.
This version is now testable. It allows for precise measurement, automated testing, and clear pass/fail logic.
Key principles for testable acceptance criteria
  • Be specific, not broad: “Show all data” → “Display at least 100 rows of transaction history.”
  • Use clear metrics: “Fast” → “under 1.5 seconds,” “many” → “at least 5 items.”
  • Focus on observable results: “The user gets help” → “The help modal appears within 0.5 seconds of clicking the help icon.”
  • Separate functionality from experience: “The system feels responsive” is not a testable condition. “The button changes color within 0.1 seconds of hover” is.
Checklist: Is your story testable?
Check Yes/No Why?
Does the story state a measurable outcome? Example: “Load in under 2 seconds.”
Are acceptance criteria written in Given-When-Then format? Helps structure testable scenarios.
Could a tester execute this without asking for clarification? If yes, it’s testable.
Does the story avoid subjective terms like “easy,” “fast,” “nice”? Subjective language = untestable.
Trade-offs in testability and practicality
Not every acceptance must be automated. But every acceptance must be testable. The goal isn’t automation—it’s verification.
Some teams over-engineer acceptance criteria with micro-conditions. That leads to bloated, fragile tests. The sweet spot? Focus on the critical path of validation.
Ask: “If this fails, will the user be blocked?” If yes, it needs a test. If no, maybe it’s a nice-to-have and can be verified manually.
Here’s a real-world trade-off: a story says “The form should validate inputs.” That’s vague. But “When the user submits the form with an invalid email, an error message appears in red text within 0.3 seconds” is testable and actionable.
Don’t confuse complexity with comprehensiveness. Testable doesn’t mean detailed. It means clear, objective, and repeatable.
Integrating test scenario coverage into story writing
Test scenario coverage is not a QA task—it’s a team responsibility. Every story should come with at least one testable scenario that covers the main success condition.
Use this simple rule: For every story, ask, “What’s the one test that proves it’s working?” If you can’t name it, the story isn’t ready.
Here’s how to embed coverage early:
  1. Write acceptance criteria during story creation, not after.
  2. Review with QA from day one. They’ll spot gaps.
  3. Use the “three amigos” session to align on what “done” means.
  4. Mark stories as “testable” in the backlog—no exceptions.
Teams that skip this step pay the cost in rework, late defects, and missed sprints. The fix isn’t more effort—it’s better upfront clarity.
Real-world example: From untestable to testable
Original (untestable):
As a customer, I want the payment system to work so I can complete my purchase.
Issues: “Work” is undefined. No metric. No behavior.
Revised (testable):
As a customer, I want to complete a payment so that I can receive immediate confirmation.
Acceptance Criteria:
- Given I’m on the checkout page,
- When I click “Pay Now” with valid credit card details,
- Then the system must display “Payment successful” within 2 seconds.
- And the order status must change to “Confirmed” in the database.
- And I must receive a confirmation email within 1 minute.
Now, every part is testable. The team knows exactly what to build and how to verify it.
How do I know if a story is testable?
Ask: Can a tester run a test based on this? If yes, and it has a clear pass/fail condition, it’s testable. If the answer depends on opinion, it’s not.
What if the acceptance criteria are too complex?
Break it into smaller, focused scenarios. One story, one main test case. Use multiple criteria to cover edge cases, but keep the primary condition simple.
Should acceptance criteria be automated?
Not every one. But every testable criterion should be automatable if possible. Automation isn’t the goal—verification is. If a test can be run reliably, automate it.
Who should write acceptance criteria?
Collaboratively. The product owner defines the goal, the developer defines feasibility, and QA verifies testability. The three amigos should review together.
Can a story be testable without automation?
Yes. Testability means the outcome can be verified. Automation improves speed and consistency, but a manual test with clear steps counts as testable.
How do I teach my team to write testable stories?
Start with examples. Show bad vs good versions. Run workshops where teams rewrite untestable stories. Use the checklist above. Make testability a non-negotiable part of Definition of Ready.
Final takeaway
Untestable user stories are the most expensive kind. They promise value but deliver uncertainty. The fix is simple: write acceptance criteria that are specific, measurable, and verifiable. Use criteria-based story writing and ensure test scenario coverage from day one.
When every story can be tested, teams ship faster, with fewer defects, and with confidence. That’s not a dream. It’s the reality of disciplined Agile.
