How Story Writing Differs from Specification Writing
Время чтения: 7 мин. 63 просмотров
“We just need to write the story and move on.” That’s the phrase I hear most often from teams in their first sprint. It’s a red flag. It means the team still sees the story as a task, not a conversation starter. Writing a user story isn’t about documentation—it’s about creating a shared understanding.
When story writing is treated as specification writing, teams miss the core Agile principle: a story is a placeholder for a conversation. It’s not a contract. It’s an invitation. And if you skip the dialogue, you’re not building software—you’re building assumptions.
This chapter cuts through the confusion. You’ll learn the fundamental differences between story writing and specification writing, why mixing them leads to rework and misalignment, and how to use each correctly. By the end, you’ll know when to write a story, when to write a specification, and how to keep your backlog focused on value.
The Core Misconception: Stories Are Not Documents
Agile storytelling is about conversation, not content. A well-written story invites questions, clarifies intent, and opens the door to collaboration. A specification, on the other hand, is meant to be a complete, standalone artifact—often detailed, precise, and static.
When teams write stories like specifications, they’re treating them as if they must contain every detail. That defeats the purpose. It’s like giving someone a map with every turn labeled before they’ve even left home.
Here’s the truth: stories are incomplete. They are placeholders. They are meant to be filled in through conversation—between product owner, developer, tester, and designer. That’s the entire point.
Agile Storytelling Is About Intent, Not Completeness
Agile storytelling thrives on ambiguity. Not chaos—intentional ambiguity. The role, the goal, and the outcome are clear. The how is left open.
This isn’t a flaw. It’s a feature. You don’t need to know the implementation to understand the value. The story says: “As a user, I want to reset my password so I can access my account.” You don’t need to know whether it’s a link, a form, or a mobile confirmation. You know what it’s for.
But if you demand a full flowchart, a detailed interface mockup, and a list of edge cases in the story itself, you’ve turned it into a specification—and lost the value of flexibility.
Key Differences: Story Writing vs Specification Writing
The table below summarizes the key differences in mindset, purpose, and usage.
Aspect Story Writing Specification Writing
Purpose Trigger conversation about value Define exact behavior for implementation
Form Short, focused, value-driven Long, detailed, behavior-specific
Ownership Product owner, with team input Often QA or technical lead
Timing Created early, refined over time Written after story agreement
Flexibility High – evolves with feedback Low – fixed once written
Use Cases For Each
Understanding when to use which is critical. Here’s how to decide:
  1. Use stories when: you’re exploring value, aligning stakeholders, or planning sprints. The focus is on “what” and “why” — not “how”.
  2. Use specifications when: you’re in development, need to test behavior, or the implementation is complex and error-prone. This is where you define “how” it should behave.
Think of stories as the “why” and specifications as the “how.” You need both. But you must know which is which.
Why Teams Confuse the Two
Here are the most common reasons why story writing drifts into specification territory:
  • Pressure to deliver: Teams feel they must write “everything” upfront to avoid rework. But that’s backwards. Writing too much too soon introduces rigidity.
  • Lack of conversation: If the story is written by a single person and handed over, it’s already dead. A story written in isolation is not a story—it’s a task.
  • Misunderstanding of acceptance criteria: Acceptance criteria are not specifications. They’re examples of what success looks like. They should be testable, but not exhaustive.
I once worked with a team that had 20-page “user stories” that included every possible screen flow, error message, and validation rule. The product owner didn’t understand why no one was working on them. The answer? They were written like specifications, not stories. The team couldn’t start because the story wasn’t a conversation—it was a contract.
When to Write What: A Practical Decision Guide
Use this decision tree to clarify whether you’re writing a story or a specification.
  1. Is the goal to clarify value or functionality?
    • Value → Story
    • Functionality → Specification
  2. Will this be discussed with the team?
    • Yes → Story
    • No → Consider if it’s better as a specification or task.
  3. Is this needed for testing, or to inform design?
    • Yes → This is likely a specification.
    • No → It’s probably a story.
Remember: a story should be small enough to be discussed in a single meeting. A specification should be detailed enough to verify behavior.
Best Practices for Agile Storytelling
Here’s how to write stories that invite conversation, not confusion.
  • Start with “As a” — but don’t stop there. Identify the user role clearly. But don’t let the role become an excuse for vagueness.
  • Use the “So That” clause to drive value. If you can’t answer “Why?” it’s not a real story.
  • Keep it to one sentence. If it’s longer, break it down. A story isn’t a paragraph—it’s a focus.
  • Write it collaboratively. The product owner writes it, but the team refines it. That’s where the understanding grows.
  • Use acceptance criteria to guide, not define. They’re examples of success, not every possible case.
When written right, a story is not a document. It’s a spark.
What’s the difference between story writing and specification writing in Agile?
Story writing is about sparking conversation around user value. Specification writing is about defining precise behavior for implementation. Stories are incomplete by design; specifications are complete by intent.
Can I write a user story with acceptance criteria instead of a specification?
Yes, but only if the acceptance criteria are clear, testable, and limited to key scenarios. This is acceptable for simple features. For complex flows, a full specification is still needed.
Why do teams treat stories like specifications?
They’re afraid of rework. But writing everything upfront creates rigidity. The real risk isn’t changing the plan—it’s building the wrong thing because the conversation never happened.
Should acceptance criteria replace specifications?
No. Acceptance criteria are meant to be examples, not exhaustive rules. They support the story. They are not a substitute for deeper specification when the behavior is complex or error-prone.
Is story writing vs specification writing a matter of team size or maturity?
It’s more about mindset than scale. Even mature teams can slip into specification mode when under pressure. The key is to preserve the conversation. Size doesn’t determine the approach—it’s the team’s culture around collaboration that matters.
How do I know when to use a story vs a specification?
If you’re planning, aligning, or exploring value—use a story. If you’re implementing, testing, or documenting behavior—write a specification. The story comes first. The specification comes second.
