Backlog Prioritization in Multi-Team Environments
Время чтения: 7 мин. 45 просмотров
When multiple teams depend on a shared backlog, arbitrary ordering leads to wasted effort, misaligned delivery, and delayed value. Agile prioritization at scale isn’t about ranking stories—it’s about ensuring the right work flows to the right teams at the right time.
Too many organizations default to relative story point size or arbitrary sprint goals. That breaks down when dependencies span teams, domains, or even business units.
I’ve worked with enterprise teams where the backlog was a graveyard of unvaluable features because priority was determined by seniority, not impact. The solution? Use economic frameworks grounded in real-world value, not politics.
Here, you’ll learn how to apply WSJF prioritization and cost of delay agile to ensure that the highest-value work flows first—across teams, domains, and timelines.
Why Traditional Prioritization Fails at Scale
In small teams, a simple MoSCoW or MoSCoW-style ranking may suffice. But in large programs, what’s “urgent” for one team may be “low value” for the customer. Prioritization must reflect real business impact.
When teams prioritize in isolation, they often end up building features that satisfy internal milestones but don’t deliver measurable user value. This creates what I call “alignment theater”—teams working hard but in different directions.
The root problem: many backlogs are managed as lists, not dynamic flow systems. Without economic signals, teams can’t distinguish between “important” and “high-impact” work.
Common Pitfalls in Multi-Team Prioritization
  • Ranking by team capacity instead of business value
  • Allowing stakeholders to assign priority based on influence, not outcome
  • Using arbitrary labels like “High,” “Medium,” “Low” without measurable criteria
  • Letting dependencies drive priority instead of value
  • Ignoring the cumulative cost of delay across multiple teams
Introducing WSJF: The Economic Engine of Agile Prioritization
WSJF—Weighted Shortest Job First—is the gold standard for prioritizing work at scale. It’s not a framework. It’s a decision-making model rooted in economic theory and proven in complex programs.
WSJF calculates the cost of delay per unit of job size. The higher the WSJF score, the higher the priority.
Formula: WSJF = Cost of Delay / Job Size
The cost of delay isn’t just about time. It includes revenue loss, compliance risk, competitive disadvantage, and customer retention. Job size refers to the relative effort to deliver the feature.
Breaking Down the Cost of Delay
Cost of delay agile isn’t a guess. It’s derived from four key components:
  1. Time criticality – How quickly must this deliver to avoid impact?
  2. Customer value – What benefit does the user receive?
  3. Business value – How much revenue or cost avoidance does it enable?
  4. Risk reduction – Does delaying work increase exposure to risk or regulatory penalty?
When I guided a financial services program through PI planning, we used cost of delay agile to re-prioritize 300+ features. The top 15% of stories by WSJF delivered 70% of the projected business value. The rest were deferred until a future PI.
Step-by-Step WSJF Prioritization
Here’s how to apply WSJF in your enterprise backlog:
  1. Define each story’s cost of delay using one of the four components above. Assign a numeric value (e.g., 1–10).
  2. Estimate job size using story points or relative effort units (e.g., 2, 5, 8).
  3. Calculate WSJF score by dividing cost of delay by job size.
  4. Sort by WSJF score in descending order.
  5. Assign to teams based on capacity and dependency alignment.
Pro tip: Don’t over-analyze. A 1–5 scale for cost of delay is sufficient. Accuracy matters less than consistency.
WSJF Prioritization Example
Story Cost of Delay (1–10) Job Size (SP) WSJF Score
Reset failed login lockout 9 3 3.0
Dashboard redesign 7 8 0.875
Export data to PDF 5 2 2.5
Even though the dashboard redesign has higher business value, the login fix has a higher WSJF score because it delivers value faster with less cost.
When to Use WSJF vs. Cost of Delay Agile
WSJF and cost of delay agile are deeply connected. WSJF is the calculation. Cost of delay agile is the philosophy behind it.
Use cost of delay agile when:
  • You’re aligning multiple teams on a shared value stream
  • Dependencies span business and technical domains
  • You need to justify delayed work to leadership
  • You’re running PI planning and need to sequence features
Use WSJF when:
  • Ranking individual stories in the backlog
  • Deciding which items to pull into the next sprint
  • Comparing work across different teams with different effort estimates
They’re not alternatives. They’re complementary.
Practical Application: Scaling Across Teams
At scale, you can’t apply WSJF to every story. Instead, apply it at the feature or capability level, then break down dependencies.
Example: A feature like “Enable Multi-Factor Authentication” may include:
  • Backend: User authentication service (cost of delay: 9)
  • Frontend: UI implementation (cost of delay: 6)
  • Compliance: Audit log integration (cost of delay: 8)
Each piece gets a cost of delay based on shared risk. Then, apply WSJF per team to sequence delivery.
Don’t let a single team’s capacity override the economic signal. If a low-impact story blocks high-impact work, restructure the flow.
Common Misunderstandings About WSJF
  • “It’s too complex for our teams.” It’s actually simpler than many alternatives. Start with one team, use cost of delay on a 1–5 scale, and track outcomes.
  • “We can’t measure cost of delay.” You don’t need perfect data. Use stakeholder input, market research, or past PI results to estimate.
  • “It prioritizes small items only.” No—it favors high impact per unit effort. A large story can win if its cost of delay is high enough.
  • “It ignores dependencies.” It doesn’t ignore them—it makes them visible. High-impact stories with blocking dependencies get flagged for early resolution.
Integrating WSJF into Your Agile Artifacts
Make WSJF visible across your workflow:
  • Display WSJF scores in the product backlog
  • Show risk of delay in sprint planning: “If we delay this, what’s the business impact?”
  • Use WSJF scores to inform PI planning and release sequencing
  • Include WSJF in backlog refinement sessions to guide decisions
Don’t make it a spreadsheet-only tool. Embed it in your planning ceremonies.
Measuring Success: What to Watch For
Agile prioritization at scale isn’t complete without feedback. Track these metrics:
  • Value delivered per sprint – Compare against WSJF ranking
  • Backlog volatility – Frequent changes signal poor prioritization
  • Story completion rate by WSJF tier – Are high-WSJF stories delivered?
  • Dependency resolution time – High-wait time for dependencies indicates misalignment
If high-WSJF stories are left behind, re-evaluate your cost of delay estimation model.
How often should we re-calculate WSJF scores?
Re-calculate at each PI planning or major backlog refinement cycle. Adjust if business context changes—like new regulations, market shifts, or customer feedback.
Can WSJF be used for technical debt?
Yes, but assign a cost of delay based on risk: potential outages, security vulnerabilities, or compliance exposure. Technical debt with high cost of delay should be prioritized.
What if two stories have the same WSJF score?
Use dependency alignment. If one blocks the other, prioritize the blocker. If both are independent, use team capacity or delivery risk.
How do I handle stories with no clear cost of delay?
Use stakeholder consensus. Ask: “What happens if we delay this by 3 months?” Be specific—do not rely on “it’s important.” Translate to risk, cost, or revenue impact.
Is WSJF suitable for non-technical stakeholders?
Yes. Explain it as: “We’ll deliver the most impactful work first, so you get value sooner.” Use simple visuals—like a leaderboard of features by WSJF score.
Can WSJF replace story point estimation?
No. Use story points for effort estimation. WSJF is for prioritization. They serve different purposes. Think of story points as a “cost,” and WSJF as a “return.”
