Connecting OKRs to KPIs, Strategy Maps, and Scorecards
Leitura estimada: 7 minutos 85 vistas
Many leaders confuse OKRs and KPIs—mistaking them for interchangeable tools. But they serve fundamentally different purposes. OKRs are about direction, ambition, and alignment. KPIs are about ongoing performance tracking. I’ve seen teams fail not from poor execution, but from misapplying these tools. Confusing a key result with a KPI leads to tracking activity instead of outcomes.
OKRs and KPIs are not rivals. They’re partners. OKRs define the “what” and “why”—the stretch goals that move the needle. KPIs measure the “how” and “when”—the ongoing health checks that confirm progress.
In this chapter, you’ll learn how to use OKRs to drive strategy, embed KPIs for real-time monitoring, and map both into a unified view using strategy maps and balanced scorecards. You’ll walk away with a practical framework to align team energy with organizational vision—without getting lost in metrics overload.
Understanding the Difference: OKRs vs KPIs
OKRs are not KPIs. That’s not a nuance—it’s a foundational truth.
Key Results define measurable progress toward an objective. KPIs, by contrast, are ongoing metrics that reflect health, efficiency, or performance.
Let’s say your objective is: “Increase customer retention in Q3.”
  • A Key Result might be: “Achieve a 15% increase in retention rate from 70% to 85%.”
  • A KPI relevant to this might be: “Monthly retention rate,” tracked weekly.
One measures progress toward a goal. The other measures performance over time.
Use Case: Marketing Campaign
Objective: Increase qualified leads by 30% in Q4.
  • Key Result 1: Generate 1,500 new qualified leads via content and paid ads.
  • Key Result 2: Achieve a lead-to-customer conversion rate of 20%.
Relevant KPIs:
  • Cost per lead (CPL)
  • Lead quality score
  • Website bounce rate
  • Time on page for content assets
OKRs set the goal. KPIs help you diagnose and adapt. You don’t need to track every KPI—just the ones that signal whether you’re on course.
Creating a Strategy Map with OKRs and KPIs
A strategy map turns abstract vision into a visual, actionable chain of cause-and-effect relationships.
OKRs fit naturally into the strategy map as the “objective” layer—what you want to achieve. KPIs provide the performance indicators that validate each step.
Step-by-Step: Map Your Strategy
  1. Start with the Vision: Define long-term outcomes—e.g., “Become the #1 trusted SaaS platform in healthcare.”
  2. Define the Strategy: Break vision into strategic themes—e.g., “Expand enterprise adoption,” “Improve user retention,” “Enhance security compliance.”
  3. Connect to OKRs: Assign OKRs to each strategic theme. For example:
    • Objective: Increase enterprise customer acquisition by 40%.
    • Key Result: Close 12 new enterprise deals by Q4.
  4. Link to KPIs: For the above, track:
    • Deal pipeline value
    • Conversion rate from demo to close
    • Customer success engagement score
This creates a clear line from vision to execution. Every team can see how their work contributes to the bigger picture.
Integrating OKRs with the Balanced Scorecard
The balanced scorecard offers a structured way to evaluate performance across four perspectives: Financial, Customer, Internal Processes, and Learning & Growth.
OKRs and the balanced scorecard work in concert. OKRs provide the ambition. The scorecard ensures balance.
Example: Aligning OKRs with the Balanced Scorecard
Perspective OKR Objective Key Result Relevant KPIs
Financial Increase annual revenue by 30% Close $3.6M in new ARR by year-end Monthly Recurring Revenue (MRR), ARR growth rate
Customer Improve customer satisfaction to 90% Attain Net Promoter Score (NPS) of 85 NPS, CSAT, Support ticket resolution time
Internal Processes Reduce customer onboarding time from 14 to 7 days Implement new onboarding workflow by Q2 Onboarding completion rate, time to first feature use
Learning & Growth Upskill 80% of product team in AI-powered features Complete 5 internal upskilling workshops by Q3 Training completion rate, team engagement survey
This integration ensures that stretch goals are not just about growth—they’re aligned with customer value, process efficiency, and team capability.
When to Use OKRs vs KPIs: Practical Guidance
Not every goal needs an OKR. Not every metric is a KPI. Use this decision tree:
  1. Is the goal ambitious and time-bound? → Use an OKR.
  2. Is the metric used for ongoing monitoring? → It’s a KPI.
  3. Does it reflect a strategic outcome? → It may be a Key Result.
  4. Is it repeated weekly/monthly? → Likely a KPI.
OKRs are best for quarterly goals. KPIs are operational. Use KPIs to fine-tune execution. Use OKRs to set direction.
Common Pitfalls to Avoid
Even experienced teams stumble when integrating OKRs and KPIs. Here are three frequent mistakes:
  • Mistaking KPIs for Key Results: “We’ll increase website traffic by 20%” sounds measurable—but if traffic is just a KPI, it’s not a valid Key Result. Ask: “Does achieving this directly move us toward a strategic outcome?” If not, reconsider.
  • Overloading KPIs: Tracking 20 metrics is noise. Focus on 3–5 KPIs per strategy area. Choose those that signal health and momentum.
  • Forgetting to Review the Map: A strategy map is not a one-time artifact. Revisit it quarterly. Update it when strategy shifts. Keep it alive.
Clarity comes from simplicity. Prioritize. Focus. Let KPIs serve, not overshadow.
Real-World Example: A SaaS Company’s OKR and KPI Integration
At a mid-sized SaaS company, leadership wanted to improve customer retention. They launched a 90-day pilot using both OKRs and KPIs.
Objective: Improve retention of customers who signed up for the premium tier by Q3.
Key Results:
  • Reduce churn by 10% in the premium segment.
  • Onboard 90% of new premium users within 5 days.
  • Drive 50% adoption of advanced features within 30 days of sign-up.
Relevant KPIs Tracked Weekly:
  • Churn rate (by customer tier)
  • Time to first value (TTFV)
  • Feature adoption rate per cohort
  • Support ticket volume related to onboarding
By week 6, the team noticed TTFV was rising. KPIs revealed users were skipping the guided tour. They adjusted the onboarding flow—restarting the funnel. By week 12, churn dropped by 8%.
This wasn’t luck. It was the power of combining OKRs and KPIs. The OKR set the goal. The KPIs revealed the bottleneck. The team adapted in real-time.
What is the main difference between OKRs and KPIs?
OKRs are goal-setting tools that define ambitious, time-bound objectives and measurable outcomes. KPIs are ongoing performance indicators used to monitor business health. OKRs drive change; KPIs track consistency.
Can a KPI be a Key Result in an OKR?
Yes—only if the KPI directly measures progress toward a strategic outcome. For example, “Reduce customer churn to 5%” is a valid Key Result if churn is a strategic priority. But “track monthly churn” as a KPI is not an OKR—unless it’s tied to a goal.
How do I use OKRs strategy map to align teams?
Start with your vision. Break it into strategic themes. Assign OKRs to each. Then link each objective to KPIs that reveal health. Share the map widely. Use it in planning meetings. Update it quarterly.
What is a balanced scorecard OKR?
It’s a framework that uses OKRs as the strategic ambition and maps them across the four balanced scorecard perspectives: Financial, Customer, Internal, and Learning & Growth. This ensures goals are not just revenue-driven but also customer-centric, process-efficient, and people-focused.
How often should I review my OKR and KPI integration?
Review your strategy map quarterly. Reassess your KPIs every 6 months. Update your OKRs every quarter. Use monthly check-ins to monitor KPIs and adjust tactics.
Can OKRs and KPIs coexist in one company?
Absolutely. OKRs define strategic direction. KPIs measure operational performance. They are complementary. In fact, the most effective organizations use both—OKRs for ambition, KPIs for execution.
