Decision Frameworks and Criteria
Время чтения: 3 мин. 330 просмотров
Many teams pick a modeling approach too early—often based on preference or familiarity—only to hit roadblocks later. You might start with UML for its rich object modeling, only to realize your system’s complexity lies in how data transforms across processes. Or you might begin with a DFD to map data movement, only to find you need to model object interactions. This section helps you avoid that trap.
After mastering the fundamentals of DFDs and UML, it’s time to ask: which one fits my project, my team, and my goals? This section gives you four structured criteria—data vs. object focus, team capability, project phase, and quality attributes—to make that choice with confidence. You’ll walk through decision trees, evaluation matrices, and real-world examples where one notation clearly outperforms the other.
By the end, you’ll have a repeatable, evidence-based process to guide your modeling decisions, not just a tool or diagram type.
This section breaks down four key decision dimensions to help you choose between DFD and UML effectively.
  • Primary Decision Factors: Data vs. Object Focus – Learn when to prioritize data movement (DFD) versus object behavior and relationships (UML), with evaluation questions and real-world examples.
  • Team and Organization Decision Factors – Assess team skills, tooling, training costs, and enterprise standards to determine which notation your organization can sustainably adopt.
  • Project Lifecycle Stage Decision Factors – Discover how modeling choice should evolve from early requirements (DFD) to detailed design (UML), and how to manage handoffs between notations.
  • Quality Attributes Decision Matrix – Compare DFD and UML across auditability, maintainability, performance, and real-time behavior—using a weighted matrix for objective evaluation.
  • Apply a structured notation selection criteria to evaluate whether DFD or UML aligns better with your project’s core focus.
  • Identify whether your system’s complexity stems from data transformation or object collaboration—critical for choosing DFD vs UML effectively.
  • Assess your team’s modeling maturity and training readiness using a practical skillset checklist.
  • Match the right modeling approach to each project lifecycle stage, including transition handoffs between DFD and UML.
  • Use a modeling notation decision matrix to weigh quality attributes like auditability and maintainability in your choice.
  • Make deliberate, documented decisions that withstand scrutiny—especially helpful in regulated or high-compliance environments.
These aren’t abstract concepts. Every framework here has been tested in real-world systems, from healthcare data pipelines to enterprise software redesigns. The goal isn’t to master every diagram—it’s to choose the right one at the right time.
Прокрутить вверх
