How to Create UML Use Case Diagram in Visual Paradigm
Visual Paradigm Desktop provides a powerful yet user-friendly environment for creating UML diagrams, including the widely used Use Case Diagram. This diagram type is essential for capturing functional requirements by illustrating interactions between users (actors) and the system through specific functionalities (use cases). In this chapter, we use a Use Case Diagram as a practical example to guide you through the entire creation process.
Whether you’re documenting system boundaries for a new application, refining requirements in an agile project, or communicating with stakeholders, Visual Paradigm makes it easy to produce clear, professional UML Use Case Diagrams with full UML 2.5 compliance, automatic layout, and rich documentation features.
Step 1: Start a New UML Project and Diagram
Open Visual Paradigm Desktop and create a new project by selecting File > New Project. Name it something descriptive, like «Online Banking System UML».
To create the Use Case Diagram:
- Go to Diagram > New in the main menu.
- In the New Diagram window, select Use Case Diagram.
- Enter a name such as «Use Case Diagram – Online Banking System».
- Click OK to open a blank Use Case Diagram canvas.
The toolbar on the left now displays all standard UML Use Case Diagram elements.
Step 2: Add Actors to the Diagram
Actors represent users or external systems that interact with your system.
- From the toolbar, drag the Actor icon (stick figure) onto the canvas.
- Double-click the actor and rename it (e.g., «Customer», «Bank Teller», «ATM Machine»).
- Add additional actors as needed (e.g., «System Administrator»).
- Position actors outside the system boundary for clarity.
Step 3: Define the System Boundary
The system boundary clearly separates what is inside your system from external actors.
- Drag the System (rectangle) shape from the toolbar onto the canvas.
- Resize it to enclose the area where use cases will be placed.
- Double-click the boundary and name it (e.g., «Online Banking System»).
All use cases should appear inside this rectangle.
Step 4: Create Use Cases
Use cases describe the functionalities the system provides to actors.
- Drag the Use Case oval shape inside the system boundary.
- Name each use case clearly and concisely using verb-noun phrasing (e.g., «Login», «Transfer Funds», «View Account Balance», «Pay Bill»).
- Add more use cases based on the system’s functional requirements.
Step 5: Connect Actors to Use Cases with Associations
Show which actors can perform which use cases.
- Select the Association connector (solid line) from the toolbar.
- Click an actor, then click a use case to draw the connection.
- Repeat for all relevant actor–use case relationships.
- Use Generalization (solid line with hollow triangle arrow) if one actor inherits from another (e.g., «Premium Customer» generalizes «Customer»).
Step 6: Add Relationships Between Use Cases
Use <<include>> and <<Extend>> to show dependencies between use cases.
- Drag the Include relationship (dashed arrow with <<include>>) from one use case to another (e.g., «Transfer Funds» includes «Authenticate User»).
- Use the Extend relationship (dashed arrow with <<Extend>>) for optional or conditional behavior (e.g., «Pay Bill» extends «Transfer Funds» with «Schedule Payment»).
- Label relationships clearly if needed.
Step 7: Polish and Document Your Diagram
- Right-click any element > Specification to add detailed descriptions, preconditions, postconditions, or scenarios.
- Generate documentation via Tools > Doc. Composer for requirements specifications.
Best Practices for UML Use Case Diagrams in Visual Paradigm
Keep use case names action-oriented and focused on user goals. Avoid technical implementation details. Use consistent naming conventions. Leverage Visual Paradigm’s model element reuse, reference projects, and diagram layers for large-scale systems.
Creating effective Use Case Diagrams with Visual Paradigm Desktop helps you capture and validate requirements early, reduce misunderstandings, and set a strong foundation for detailed design and development.
Ready to model your system’s interactions like a pro? Download Visual Paradigm Desktop now and start building UML Use Case Diagrams today. Try it free, then unlock team collaboration, code engineering, and advanced UML features with a full license. Visit our site or reach out to our team for guidance!
