DFD Data Stores vs. UML Class/Object Diagrams: Data Persistence
Время чтения: 8 мин. 64 просмотров
Imagine a hospital’s patient records system. The data flows from registration to diagnosis to billing. In a DFD, that entire flow is captured as a single data store: “Patient Records.” It’s a clean, functional view—no need to define patient ID as a class with inheritance, methods, or relationships. But if the same system needs to model how a patient’s condition evolves through time, how medications interact, or how staff access rights change with role shifts, you quickly realize that a data store alone isn’t enough.
The real divide isn’t just about diagrams—it’s about mindset. DFD treats data as a passive entity moving through processes. UML treats it as a living object with identity, behavior, and state. This difference shapes how we model persistence. I’ve seen teams waste weeks trying to force UML into a DFD-style model for a reporting system, only to realize the data wasn’t meant to be complex—just tracked. Conversely, I’ve seen a CRM project collapse because someone treated a “Customer Data Store” as a simple table, ignoring the need for object identity, versioning, and ownership rules.
This chapter breaks down the practical trade-offs between DFD data stores and UML class diagrams. You’ll learn when to use the simplicity of a data store for batch processing and reporting, and when to embrace full object modeling for systems with rich behavior, state transitions, and complex relationships. You’ll also understand the critical difference between data identity and object identity—something that can silently break a system if misunderstood.
Understanding Data Stores vs. Class Diagrams
At its core, a DFD data store is a repository for data that persists across process executions. It’s a conceptual container—like a file or database table—used to represent where data resides during a system’s lifecycle. It has no behavior, no methods, and no state beyond what’s stored in its attributes.
A UML class diagram, on the other hand, models objects as full-fledged entities with attributes, operations, relationships, inheritance, and encapsulation. It defines not just what data exists, but how it behaves and how it interacts with other objects.
The choice isn’t about which is “better.” It’s about which model aligns with the problem domain. A data store models what data is needed. A class diagram models how that data is used, evolved, and governed.
When a Data Store Suffices
Simple data stores are perfect for systems where persistence is the only concern. Think batch processing, data warehouse ETL pipelines, or legacy systems that only need to read, process, and write data.
  • Batch reports that run nightly
  • Legacy system data exports
  • Simple transaction logging
  • Configuration data stored as flat files
In these cases, modeling the data store as a single entity with attributes like “file name,” “last updated,” and “record count” is sufficient. There’s no need to define a ReportGenerator class with methods like generate() or validate().
When a Class Diagram Becomes Essential
When data begins to behave, a class diagram is not just helpful—it’s mandatory. Consider a patient management system where:
  • A patient can have multiple diagnoses over time
  • Each diagnosis has a status (active, resolved, pending)
  • Medications interact based on drug classes and timelines
  • Only certain staff can modify records based on role and shift
Here, treating “Patient Records” as a data store would hide critical business logic. The data isn’t static. It evolves. It has a history. It’s governed by rules that only a class diagram can express.
Use UML class diagrams when:
  1. There’s state change over time (e.g., status, workflow)
  2. Objects have methods that govern behavior (e.g., calculateBill())
  3. There are complex relationships like inheritance, composition, or association
  4. Multiple roles or access levels affect data handling
  5. Versioning, audit trails, or concurrency controls are required
Data Identity vs. Object Identity
This is where the confusion often arises. A DFD data store doesn’t distinguish between data identity and object identity. It simply holds data. A UML class diagram, however, draws a sharp line between the two.
Data identity is about the data itself—the what. A record with ID “P1001” is the same regardless of how it’s accessed.
Object identity is about the how. An object with the same ID might behave differently based on its state, its role, or who owns it. For example, a Prescription object might be pending in one context and expired in another—based on time, role, or status transitions.
For systems where behavior depends on context (e.g., insurance claims, financial transactions), object identity must be modeled explicitly. A data store cannot capture this.
Real-World Example: Financial Transaction System
In a payment processing system, a simple DFD data store like “Transaction Log” might be enough for auditing purposes—track every transaction by time, amount, and ID.
But if the system must model:
  • Transaction reversals with rollback logic
  • Multi-step authorization workflows
  • Dispute handling with escalation paths
  • Role-based access (e.g., only managers can reverse)
Then a class diagram becomes essential. You need classes like Transaction, Dispute, Reversal, and AuthorizationChain, each with their own methods, state, and relationships.
Here, the data store is still used—but only as the persistent storage layer. The behavior lives in the class model.
Comparing Data Store vs Class Diagram: A Practical Table
Aspect DFD Data Store UML Class Diagram
Primary Use End-to-end data flow tracking Behavioral modeling, object relationships
Identity Based on data content or ID Based on object instance (object identity)
State & Behavior None Yes — methods, lifecycle, state transitions
Complexity Low (simple storage) High (inheritance, polymorphism, associations)
Best For Batch processing, reporting, legacy systems Real-time systems, workflows, rule engines
When to Choose Which: A Decision Flow
Use this flow to guide your choice:
  1. Ask: Is this system focused on data movement, or object behavior? If it’s data movement—DFD data store.
  2. Ask: Does the data change state based on business rules? If yes—UML class diagram.
  3. Ask: Are there rules about who can access or modify the data based on role or context? If yes—UML is essential.
  4. Ask: Is the data reused across multiple processes with different logic? If yes—model it as an object.
  5. Ask: Will the data be versioned, audited, or modified in parallel? If yes—use object modeling.
When in doubt, start with DFD. If you find yourself adding behavioral logic, it’s time to migrate to UML. The key is not to over-model early—just model what the system actually needs.
Common Pitfalls to Avoid
  • Over-modeling with UML: Don’t create a class diagram for a simple inventory list. It adds overhead without benefit.
  • Under-modeling with DFD: Don’t model a patient’s medical history as a single data store if it evolves through time and requires rules.
  • Confusing data storage with object behavior: A data store is not a class. A database table is not a class. They are related, but not equivalent.
  • Ignoring identity: In systems with multiple roles or versions, treat object identity as a first-class concern.
What is the main difference between a DFD data store and a UML class diagram?
A DFD data store is a passive container for data—used to show where data resides. A UML class diagram models objects with attributes, methods, relationships, and behavior. The data store is about storage; the class diagram is about behavior and identity.
When should I use a DFD data store instead of a UML class diagram?
Use a data store for systems focused on data movement—batch processing, reports, or legacy systems where data is only read, processed, and written without rules or state changes. Use UML when behavior, state transitions, or complex relationships are involved.
Can I use both DFD and UML together in the same project?
Absolutely. Use DFD for high-level data flow and audit trails. Use UML for detailed object modeling. Map DFD data stores to UML classes during design, but keep them as separate models unless you’re in a hybrid tool like Visual Paradigm.
Are DFD data stores still relevant in modern software development?
Yes. DFDs remain valuable for understanding data lineage, especially in compliance, audit, and legacy modernization projects. They help teams visualize where data comes from and where it goes—without getting lost in object details.
How do I handle versioning or audit trails in a UML class diagram?
Model it explicitly. Add properties like versionNumber, createdBy, lastModified, and auditTrail. Use associations to link to a LogEntry class. Consider using a VersionedObject base class with inheritance.
Is there a rule for when to use inheritance in a UML class diagram for data persistence?
Use inheritance when multiple classes share common attributes or behaviors—like InsurancePolicy, HealthcarePlan, and RetirementAccount all inheriting from FinancialProduct. Avoid overusing it for simple data types. Inheritance is about behavior, not just structure.
